Gen 1 Taco "Mid" setting on radio
Discussion in 'Audio & Video' started by Marc M, Jan 21, 2010.
  1. Jan 21, 2010 at 7:46 PM
    Marc M
    Marc M [OP] Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    Back when I had my '03 I did this to my stock radio and it gave me a mid setting. It made the stock stuff sound a bit better.
    Seems to work on the '00 - '04 radio's...
    With the truck on and the radio on, press and hold the tuning knob for approximately 10 - 15 seconds. You will hear an audible beep, now when you go back in to set the audio preferences it gives you the option for "MID" adjustment.
    It will stay this way as long as you turn your radio off before you turn your truck off. If you happen to turn the truck off before you turn the radio off, all you have to do is perform the same sequence and it will come back....
    Marc M
  2. Mar 25, 2013 at 7:03 PM
    169.254.255.201 Well-Known Member
    Interwebs
    I'm trying this on my 01. Do you have a suggestion on what the level of my mid should be?
    I will experiment a bit
  3. Mar 25, 2013 at 7:40 PM
    eric3187
    eric3187 Well-Known Member
    what ever level sounds best to your ears...
    when i was driving an '04 i set bass at -1, mid at 3 and treble at 3/4... sounded best for the music i listened too
