Gen 2 bed sags with load
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tailchaser16, Nov 20, 2017.
  1. Nov 20, 2017 at 2:59 PM
    tailchaser16
    tailchaser16 [OP] New Member
    Miami
    08 Prerunner
    Hi All
    I have an 08 TRD Prerunner, 177k miles. Went of over a speed bump with 4 kids and buddy in the bed en route to a park. I go over those long speed bumps and as the rear wheels come over it feels like the bed/rear of the truck never comes back up. I slow down for the next one an it does it again, but, not as bad. Almost like it is bottoming out. Additionally, I do get some sag when I hitch up to my 16' skiff.
    Is this normal? 4 kids maybe 120 pounds each (480 pounds) and one adult around 300 pounds. New Blisteins 5100 installed last year front & back. Any help would be appreciated.
  2. Nov 20, 2017 at 3:21 PM
    TOP TACO
    TOP TACO Well-Known Member
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    leafs are most likely shot with that mileage, sounds like its time for new leafs or maybe some airbags...
  3. Nov 20, 2017 at 3:26 PM
    RenoTacoma
    RenoTacoma Petrol head
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    My 09's leafs were shot after 30k of moving some heavy stuff around.
  4. Nov 20, 2017 at 7:26 PM
    watermelons
    watermelons Member
    2006 white Tacoma 4wd
    A heavy duty leaf pack like Dakar's might be the solution. The Toyota springs are pretty weak
  5. Nov 20, 2017 at 9:06 PM
    Pigpen
    Dan
    Northwest Montana
    Normal for stock springs.
  6. Nov 20, 2017 at 9:11 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Normal with that many people in the back plus a tank of gas and you up front,thats about a thousand pounds.
