Gen 2 frame swap compatibility
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Motardracer, Sep 22, 2022.
  1. Sep 22, 2022 at 7:22 AM
    Motardracer
    Motardracer [OP] New Member
    2008 TRD sport
    Hope someone can help with answers please.
    My truck:
    2008 double cab, V6, 4x4, 5'bed with horrible rust
    Past the point where Toyota will help at all, so I am going to take on a frame swap myself.
    I have been chasing a newer Gen II frame from a donor with the knowledge that these frames were more properly protected/coated, etc.
    The donor I have found is:
    2015 double cab, V6, 4X4, 5' bed, low miles and no rust
    Toyota shows different part numbers, but that only makes sense as earlier frames were made in US, and 2011-2015 were Mexico with better corrosion resistance.
    My question is if I will have problems fitting the 2015 frame to my truck? I am totally not against modification/cutting/welding if it makes sense as well.
    Thanks for the help!
  2. Sep 22, 2022 at 7:29 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    any standard wheelbase frame should be fine
    as to belter protected, well... 3rd gens are now looking at frame swaps do to rust
  3. Sep 22, 2022 at 7:37 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    That sounds like it should work to me. I dont think the mid-generation facelift would have any impact on that, but cant say for 100%. If you do a lookup on the part number you should be able to see what superseded what. In other words you should see both your P/Ns if one replaced the other.
    BassAckwards likes this.
  4. Sep 22, 2022 at 7:40 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    I don't know what it is but there is a difference is the frames from early 2nd gen to late 2nd gen. There was a post earlier in the year about someone trying to buy a new frame from Toyota for an 06 but the frame is no longer available and since the older 2nd gens are out of the frame warranty Toyota doesn't need to make them anymore.
  5. Sep 22, 2022 at 2:39 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Could be relating to motor mounts. The early 2nd gens had an issue with motor mounts caving into the frame rail, which was remedied in later years
    SR-71A likes this.
  6. Sep 23, 2022 at 11:16 AM
    Motardracer
    2008 TRD sport
    Mmmmm, I wonder if I make sure to get the 2015 motor mounts along with the frame if it all would work out.... Imagine the engine block wasn't changed, more likely just he mount.
    I'm also planning to ask that the brake lines and a few other bits be left on the frame.
  7. Aug 8, 2024 at 11:06 PM
    ogmagic13
    ogmagic13 New Member
    2nd Gen SWB Tacoma
    3” leveling kit 285/70R17
    Did this work out after all?
  8. Aug 8, 2024 at 11:08 PM
    ogmagic13
    2nd Gen SWB Tacoma
    did this work after all?same situation I’m in
