Gen 2/ gen 2.5 2012 winch bumper compatibility
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pilotjoe123, Apr 29, 2021.
  1. Apr 29, 2021 at 12:25 PM
    Pilotjoe123
    Pilotjoe123 [OP] Well-Known Member
    Joe
    Eastern, NC
    2012 Pyrite Mica Tacoma Sport
    Trd Supercharger URD 2.8 pulley AFE momentum GT Cam gears DT shorties DT mid pipe Vibrant res Borla Pro XS HPtuners custom dyno Aem 340lph fuel pump agm x2 power 34 battery dynomat sso slimline Icon 2.5 coilovers Icon 2.0 rear RR All Pro 3” expedition leafs flip kit superbumps SPC ucas Whitelines 4.88 nitro gears Detroit Truetrac front/rear Mayhem Prodigy 35/12.50/17 Mickey Thompson Baja Boss M/T
    I’m looking at a used winch bumper for my 2012 Tacoma. It’s a rpmfab front for 2005-2011. Does anyone have this on a 2012? I’m curious what it would take to get this mounted.
  2. May 3, 2021 at 12:42 PM
    88seriesiii
    88seriesiii Well-Known Member
    2007 Access Cab 4x4 TRD Off Road 6cyl MT
    OEM with ARE CAP
    I have similar interest in the answer.. Topic bookmarked. I hope you get a reply.
  3. May 3, 2021 at 12:53 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    GHOST SHIP likes this.
  4. May 3, 2021 at 12:58 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    It should fit. Generally 2-2.5 bumpers are only different at the top edge to account for the difference in grill to headlight transition change with the 2.5s. Everything else remained the same between models from mounting bolts/position to fender clearance.
  5. May 3, 2021 at 12:59 PM
    GHOST SHIP
    GHOST
    Naveronski[QUOTED] likes this.
  6. May 3, 2021 at 1:01 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Mounting is the same, as we share the same frame. Only difference is the bumper lines. The grill and headlights are different on the 12-15 and fabricators often add additional plating/cosmetic pieces to fill in the gaps. Depending on fabricator, Some 12-15 won’t fit 05-11s but all 05-11s should fit 12-15s.
