Gen 2 Headlights
Discussion in 'Lighting' started by Tacomzz09, Feb 6, 2010.
  1. Feb 6, 2010 at 2:03 AM
    Tacomzz09
    Tacomzz09 [OP] Well-Known Member
    Calgary
    09 DBL CAB TRD Sport Towing
    I know this is kinda to much to ask for, but anyone who owns these headlights, can you show me the what it looks like? for example when you first start the truck and let off the handbrake, which part of the headlights will turn on for daytime running lights? then once you turn the headlamp knob once what does it look like? then once you turn the knob all the way, which will turn on the headlights, and also high beams?
    Thank you
  2. Feb 6, 2010 at 7:58 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    The top pic is with everything off. DTRLs will light up the blinker bulb, which is that black hole you see nearest to the grille on both headlights (just like the stock ones). the second pic shows the parking lights. and if you turn on your headlights, it looks like the 2nd pic with the projectors on (the hole nearest to your fender on both headlights).
  3. Feb 6, 2010 at 8:05 AM
    ballplayer002003
    ballplayer002003 Active Member
    delaware
    07 PreRunner long bed 4dr
    I like the look of those headlights, which ones are they and how is the light output?
  4. Feb 6, 2010 at 11:00 AM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    with those ligths, all the external lights have a lead going to them, so you can really make whatever you want to light up depending on how you wire it. i installed those exact lights for another member here...
