Gen 2 rear disc brake conversion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toms2014, Aug 17, 2019.
  1. Aug 17, 2019 at 9:49 AM
    toms2014
    toms2014 [OP] New Member
    Tommy
    4-dr Tacoma Prerunner
    LED lights
    Sorry, I haven't been on this site in a while. Does anyone know where to get parts to convert the rear axle brakes of a '14 Tacoma to discs?
    I've searched online but apparently there are no commercially made kits for this conversion.
  2. Aug 17, 2019 at 9:50 AM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Why would you? Is current braking inadequate?
    Edit: for the record I was asking a genuine question, not trying to be a jerk or anything.
    Thuguon2.7 and bigmw like this.
  3. Aug 17, 2019 at 9:54 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Look up sos rear tacoma disk brake kit.
    Thuguon2.7 likes this.
  4. Aug 17, 2019 at 11:29 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Imo that would be a waste of money, since the front brakes do probably 70 percent of your stopping. Why your rear shoes last forever. You’d be spending money and not really getting a major benefit. Maybe do a good front break upgrade, slotted rotors , ceramic pads maybe. Just food for thought
    Athlaos, TegoTaco and tacom08 like this.
  5. Aug 17, 2019 at 2:02 PM
    toms2014
    Tommy
    LED lights
    I was wanting to check it out since we're looking at pulling a travel trailer that is going to be near the max towing capacity. Discs would help eliminate the drum brake fade in a situation where one would be braking while going down a grade.
    Athlaos likes this.
  6. Aug 17, 2019 at 2:09 PM
    EndlessOverland
    EndlessOverland Well-Known Member
    Will
    Denver
    2010 Tacoma TRD Sport DCSB
    King 2.5 Remotes OME HD Leafs LR UCA's, Dirt King LCA SCS F5 Wheels, STMaxx 34"s 4.56 gears Custom Sliders Avid Offroad Bumper Custom Solar Setup Warfab Bedrack RCI Full Skids Prinsu Toprack Wheeler Superbumps and Ubolt Flip
    I think most of us here would highly recommend against pulling a trailer that weighs in at your max capacity. You would have trailer brakes I'm sure but braking is a small part of that entire equation. How long of a trailer are you looking at? What is the tongue weight?
    I look extensively at towing information with the tacoma all over, considering living full time in a TT. Moving it only on rare occasions and I still wouldn't want to load to the 6500 lbs
  7. Aug 17, 2019 at 2:09 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Its a worthy investment over stock drums. @Torspd upgraded and the benefits were realized. I also have a rear disk brake kit waiting to be installed as well.
    Athlaos and Torspd like this.
  8. Aug 17, 2019 at 4:56 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    www.sosperformance.com
    I'd do the rear swap on any Tacoma that I purchased. Plan to upgrade my rears to twin piston even. Worth every cent and more.
    There is also a master cylinder upgrade. Make sure to get that as well.
    Those that have the best opinions on the subject, are those that have actually installed a set and have the experience of both style of brakes.
  9. Aug 17, 2019 at 5:33 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Does it use IS350 Rotors and Pads?
    Or is it X-Runner Rotors and Pad?
    Just asking for later, if one needs to replace parts.
    ptc075 likes this.
  10. Aug 17, 2019 at 6:01 PM
    CountryDan
    CountryDan Well-Known Member
    Daniel
    Calhoun GA
    15 TRD PRO DCSB 6 spd
    a lot of bad ass stuff
    Research research research first
    I went this route after having my passenger rear drum fail in a very epic way that cost me a lot of money. At the time of repair it was a reasonable amount more to go with the conversion kit from sos. So I did. The guys at sos were very quick and customer service was great especially since a hurricane just hit their area. I paid extra to have the kit with the emergency break. Just know if you go this route your ebreak will be significantly weaker. It’s stated on the website but I guess I missed that message during my research.
    Good luck with your research and the choice you make OP.
    TnShooter likes this.
  11. Aug 17, 2019 at 6:14 PM
    TnShooter
    Deogee
    STOCK
    Other than the E-Brake. How do you like the setup?
    How is pad life and what replacement pads and rotors are you using?
  12. Aug 17, 2019 at 6:36 PM
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    For the people who have done the upgrade, is there any actual advantage to rear discs other than for towing? My truck has 110k miles on the original drums and rather than mess with replacing them, I’m tempted to do rear wheel bearings, axle seals and the rear disc conversion (with master cylinder upgrade) all at once. I’ve already done the 5th gen T4R front brake upgrade and would love to upgrade the rear. But I could just as easily stick with drums, I’m just curious about the overall benefit, outside of never having to look at ugly rusted drums behind the wheels again.
    nudavinci64 likes this.
  13. Aug 17, 2019 at 7:44 PM
    CountryDan
    Daniel
    Calhoun GA
    I’ve had the set up for less than a year. So far so good
    Athlaos and TnShooter[QUOTED] like this.
  14. Aug 22, 2019 at 7:12 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    How do you like it with the Electronic booster in the Pro/OffRoad? I have a rear setup sitting in my garage but since I can not upgrade the booster I have been hesitant to swap it out.
  15. Aug 22, 2019 at 7:13 PM
    nudavinci64
    Robert
    most people say there is not that big of a benefit. next step is a BBK if you want more stopping power. I am still debating the rear setup. At least with the sport you can upgrade the master.
  16. Aug 22, 2019 at 9:01 PM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    What is the cost of this upgrade?
  17. Aug 22, 2019 at 9:30 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    $1,200 for the parts plus an estimated 8 hours labor if you don't DIY
  18. Aug 22, 2019 at 9:42 PM
    nudavinci64
    Robert
    My only hesitation is I cant upgrade my master.
  19. Aug 23, 2019 at 3:38 AM
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    I did the rear conversation and the sequoia master cylinder later. Both stages made noticeable differences. Stopping power became an issue after going to 35s.
    Additionally, Tom is a really great guy to deal with. Customer service beyond what I’m used to.
    Flushed my system both times with a pneumatic bleeder.
    https://sosperformance.com/products...-with-parking-brake-slash-tr-dot-ps2-dot-ta16
    Torspd likes this.
  20. Aug 23, 2019 at 4:35 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Why not peruse through the link?
    Hawk373 likes this.
