Gen 2 reliability
Discussion in '2nd Gen. Tacomas (2005-2015)' started by domanfp, Nov 10, 2016.
  1. Nov 10, 2016 at 8:50 PM
    domanfp
    domanfp [OP] New Member
    Frank
    looking to get a used gen 2 double cab in the next couple months, budget is $16k or under so likely between 110 and 150k miles. I have never purchased a used vehicle with this many miles, but there seems to be a ton out there. How many miles can I expect out of a gen 2 before needing something big? What are the things I should look for?
    Thanks for all the help, looking forward to making my build thread!
  2. Nov 10, 2016 at 8:57 PM
    njcoma
    njcoma Well-Known Member
    California
    2017 Accord Sport Special Edition
    Previous: 2006 Tacoma SR5 Prerunner: 2010 4Runner sr5 Rims, TSB rear leafs, Wetokole neoprene seat covers, JVC LED color matched head unit, scanguage II, Flowmaster 40 cat back exhaust, hankook dynapro atm tires, Class 4 Uhaul Hitch. Kicker 12 inch sub and amp. Focal speakers. jba offroad UCAs.. Detroit truetrac rear end... bilstein 5100 rear and 6125 front coilovers. Nfab front bumper with KC apollo lights, bed lights, bluesea systems fuse box....lots of painted stuff.
    Leaf spring recall... if it's 4wd then front diff bearing whine (but it should have had that done lonnnngggggg ago)..
    Annoyances:
    1. steering shimmy...good luck.. comes and goes.. they all do it..
    2. driveline vibe on takeoff.. no real solution here.. doesn't hurt anything.they all do it.
    3.not a whole lot else... little things.. too trivial to matter...
    Someone else will chime in I'm sure... I have an 06.. lots of squeaks now due to age... steering shimmy.. comes and goes...
    No real mechanic issues.. knock on wood.. I replaced the valve cover gasket (easy..takes an hour TOPS) at 85k. had a slow ooze.
    Everything else was upgrade based.
  3. Nov 10, 2016 at 8:57 PM
    Oscar Schmidt
    Oscar Schmidt Member
    I own an 05 double cab TRD OFF-ROAD with 133xxx miles. I got it 3 or 4yrs ago with 87xxx on it. My motor is sound, still has lots of power for a v6. Sometimes I'll get a bump in shifting though (automatic ). Hope this helps, I'm not a mechanic.
    *edit...
    Also got a new frame courtesy of a recall on these year models that were sold in cold climate areas where roads were salted (Maryland)
  4. Nov 10, 2016 at 8:57 PM
    stlfun88
    stlfun88 Well-Known Member
    St Louis
    10 TRD
    Check the frame. These engines will go 200k miles easy. Dont worry about cabin fan ticking it is a small annoyance issue. Look throuh forums tons of good info.
    Good luck
  5. Nov 10, 2016 at 8:58 PM
    njcoma
    California
    I forgot the cabin fan. replaced mine once.. took 15 minutes and that's cause I couldn't find my sockets.
  6. Nov 10, 2016 at 8:59 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    It depends on how it's driven, maintained, and the environment in which it is used. Here's an example of what it possible:
    https://www.tacomaworld.com/threads/400-000-miles.404359/
    Depending on your location, frame rust may be a big concern, otherwise, there is a reason Tacoma's are #1 in resale value, they are a darn good, reliable truck overall.
    Clearwater Bill likes this.
  7. Nov 10, 2016 at 11:18 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Annoyances:
    Mine doesnt
    Again, mine doesnt
  8. Nov 10, 2016 at 11:57 PM
    azgunrunner
    azgunrunner A guy that knows a guy, that knows a guy...
    George
    Arizona
    06 DCLB Sport
    ADS 2.5, Dakar leaf springs KMF sliders CBI Ditch light mounts, DD SS3 pods Bumpers pending OBA pending
    I've got a 2006 DCLB. It's got 225k on it, I'm the 3rd owner. Bought it with 105k on it 5 years ago. No major mechanical issues. I've replaced the u-joints, belts, pulleys, half shafts due to my off-roading, wheel bearings and of course normal maintenance items.
    truck is still going strong! Biggest complaint is the driveline "bump" when I come to a stop and when I go from a stop.
    Hoping it lasts me another 100k! I've been super happy with the truck, hasn't left me stranded yet.
    Second biggest complaint is I have a garage full of upgrades and not enough time to install them all!
    TRDSport10, R0dzilla75 and Markcal like this.
  9. Nov 13, 2016 at 9:02 AM
    njcoma
    California
    Then you have a gem..... not saying every single tacoma does it... but the odds are stacked against you
  10. Nov 13, 2016 at 9:32 AM
    Mickeydog
    Mickeydog Well-Known Member
    Dave
    West Michigan
    2020 TRD Sport, Cement DCSB
    Pro wheels with 265-70-17 Goodyear UT. Pro skid. Pro tail lights. OEM tailgate power lock.
    I'd have to agree, mine has none of these issues.
    TRDSport10 and shakerhood like this.
  11. Nov 13, 2016 at 10:01 AM
    bgsmith
    bgsmith Well-Known Member
    Brian
    Hingham, MA
    06 Speedway Blue TRD Sport 4x4 DCSB
    ATX Mojaves with 265/75 16 Hankook Dynapro ATMs, Spidertrax 1.25" spacers (front and rear), Bilstein 5100 all around up front set at 1.75", Blacked out badges, Pioneer AVIC D3 DVD/NAV Head Unit, K&N Air Filter, Tyger Tri Fold Tonneau Cover, Rockford Fosgate Punch Speakers.
    I have a 2006 with 124k on it, no issues other than some creaks here and there (had the frame a leaf springs replaced over the summer) and I need to replace my antenna (corrosion) and the cabin fan as it is ticking and driving me nuts if the radio isn't on.
  12. Nov 13, 2016 at 10:08 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Neither of mine did either.
  13. Nov 13, 2016 at 10:12 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
  14. Nov 13, 2016 at 1:08 PM
    Razgriz1
    Razgriz1 Well-Known Member
    Southern California
    2017 Toyota Tacoma TRD Pro Cement 6MT
    Literally the only issue I've had with my truck is that stupid A/C ticking noise, but it goes away at higher fan speeds.
    I also drained the battery accidentally, but that was my dumb ass fault.
    Otherwise, it's a rock solid truck.
  15. Nov 13, 2016 at 2:19 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    127k on mine and I literally can't think of one issue or complaint. The center console latch is a little sticky, but it hasn't bothered me enough to look into why. I wish I had a front differential, but I can't blame the truck for that. :anonymous:
