Gen 2 Trailer Battery Charge
Discussion in 'New Members' started by riverrat14, Nov 22, 2023.
  1. Nov 22, 2023 at 8:14 AM
    riverrat14
    riverrat14 [OP] Member
    buckwheat
    NoCal
    2015 PreRunner TRD
    Shell
    Needc help with turning off Trailer Battery Charge wire from Main Panel to 7Pin connector
  2. Nov 22, 2023 at 8:21 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    When do you want it off?
    I goes off when you turn the ignition off.
    If you want it off with the ignition on, you'll either have to pull the fuse or relay.
    Or, you could put a switch in on the relay and turn it off and on as you please.
  3. Nov 22, 2023 at 8:22 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Is it safe to assume the 7pin was aftermarket? I didn't think the 1st generation tacoma came with a 7pin.
    Is your goal simply to turn off power to the 7pin? what is the problem you are trying to solve.
    SR-71A and TnShooter like this.
  4. Nov 22, 2023 at 8:23 AM
    YF_Ryan
    Kent, WA
    I looked at the fuse panel/relay box diagrams for a '99, I didn't see any trailer fuses.
    TnShooter[QUOTED] likes this.
  5. Nov 22, 2023 at 8:24 AM
    TnShooter
    Deogee
    STOCK
    Oh, I missed that.
    I thought he had a 2md Gen truck
    YF_Ryan[QUOTED] likes this.
  6. Nov 22, 2023 at 8:25 AM
    TnShooter
    Deogee
    STOCK
    I though he had a 2nd Gen.
    We'd need to see how the truck is wired before we can help.
    I'm going to say the wire harness is aftermarket.
    I never seen a factory 7-pin on a 1st gen.
    Mine had a 4-pin.
    SR-71A likes this.
  7. Nov 22, 2023 at 8:27 AM
    YF_Ryan
    Kent, WA
    Yeah, this was my thinking. Didn't think they had a 7pin, so if it's aftermarket we'd need more info. He probably just needs to start tracing wires.
