Gen 2 Transfer Case Pump Broken?
Discussion in 'Technical Chat' started by wtp67, Jun 14, 2021.
  1. Jun 14, 2021 at 8:01 AM
    wtp67
    wtp67 [OP] Active Member
    Warren
    Arkansas
    2009 Access Cab 4x4
    I just discovered an issue with the 2009 ACLB 4WD truck I bought a month ago. It is a little embarrassing to me to see that I overlooked something this glaring but now I just need to understand the issue and fix it. So I am turning to the TW community for thoughts, guidance....
    The transfer case pump mounting tabs are broken and the case has a leak as you can hopefully see from the picture. I have just bought all the Redline gear oil to change out transmission, transfer case, and differentials but don't want to change the transfer case until I do some more research. It's not dripping oil to the point that I see it on the asphalt when I park it but it was not wet when I bought it several weeks ago. I have only used the 4H once for about 15 feet and when I tested both 4L & 4H during the test-drive (~1/4 mile in 4H).
    Questions: is this detrimental to the pump? I have found several new for ~$100 - can a mechanically inclined non-mechanic tackle this with too much worry? I need a service manual; is there any advantage to purchasing a Chilton or Haynes? No way can I afford the FSM.
  2. Jun 14, 2021 at 12:38 PM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    2019 TRD OR Cement
    Quikfix seat risers and lic plate mount, MESO interior and stage 1 tails, glove box and console dividers, shelf for center console, FACTOR 55 hitch link, TC bed stiffeners, OE bed mat,
    That's the T-Case Actuator Motor avail as a unit from Toyota for about $900. The Actuator shaft runs into the T-Case and appears to have snap-ring grooves in it. Possible T-Case disassembly req'd.
  3. Jun 14, 2021 at 12:44 PM
    wtp67
    Warren
    Arkansas
    2009 Access Cab 4x4
    Well, crap.... that takes out the possibility of me trying to tackle it. Many is the time that I have convinced myself that I can only to end up learning that I shouldn't have.
    Thanks for the info, time, and response, Ron.
  4. Jun 14, 2021 at 12:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  5. Jun 14, 2021 at 12:57 PM
    wtp67
    Warren
    Arkansas
    2009 Access Cab 4x4
    Actually, I've already found a couple of China-based, flea-bay dealers selling new ones (part no. 36410-34015 according to parts.toyota.com) with a lifetime warranty for $170. I'm thinking that I take a chance with one of those, put it on a shelf while I save pennies, and take it to a reputable mechanic. That is, unless it causes problems soon.
    TnShooter likes this.
  6. Jul 9, 2021 at 12:36 PM
    AustinM2015
    AustinM2015 Well-Known Member
    Austin
    New Braunfels Texas
    2007 V6 4x4 standard
    I'm having the same issue and saw the same actuators on Amazon for about 160. Did it work pretty well? I can replace it my self but dont want to spend the 1000 bucks on one from Toyota also if I was going to spend 1000 bucks I'd do an FJ swap .
  7. Jul 9, 2021 at 2:45 PM
    wtp67
    Warren
    Arkansas
    2009 Access Cab 4x4
    I haven't pulled the trigger yet. Quite frankly, I am not convinced that anything other than OEM is going to last because of the negative experiences I have read about here on TW.
    I changed engine oil and differential grease last weekend and then did transmission and transfer case this weekend all the while pondering if I could replace it. I have watched two related videos and have all the tools - now that I have gotten my head wrapped around the situation - but I am still not convinced that I could replace it myself without a lot of headache or creating more problems.
    The first thing I think I will try is cleaning the points/contacts like this post talks about:
  8. Jul 9, 2021 at 3:29 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    What are those radiator clamps for in the picture? If they were present when you bought the truck I think lots of alarms would have gone off in my brain.Are those clamps there doing the job of the broken tabs? If so that would definitely been a holy shit I’m outta here moment.
  9. Jul 21, 2021 at 12:30 PM
    wtp67
    Warren
    Arkansas
    2009 Access Cab 4x4
    I looked under it specifically on the ground, frame, motor, etc. for leaks, signs of intense cleaning and/or fresh paint (as if covering up for a leak or repair) and, no, didn't have a lie-down-on-the-ground-pull-out-my-creeper moment to do an inspection. It was overlooked just like the fact that the front brakes needed to be replaced. Was it something that could have been found had I taken it to a reputable mechanic? Yes but I didn't. It's one of the things that is possible when buying a used vehicle but I knew that buying a used Tacoma was a much better decision than buying a used any other brand...... been there, regretted that. The ~$6K cash I saved by not financing far outweighs anything I have seen that needs or needed to be done.
