Gen 2 TRD Pro Headlights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dakeek, Sep 13, 2021.
  1. Feb 14, 2022 at 6:53 PM
    #81
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    have a set on the way, what is the verdict on needing to adjust? Yay, Nay?
  2. Feb 14, 2022 at 7:07 PM
    #82
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Always count on it. Assuming that your current lights are properly aimed, tape a mark on the vertical cutoff line at 20ft and aim the new headlights to match.
  3. Feb 14, 2022 at 7:08 PM
    #83
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    how was getting to the vertical adjustment screw? it looks kind of far down there
  4. Feb 14, 2022 at 7:10 PM
    #84
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Haven't installed mine yet but I imagine a stubby screwdriver would do the trick.
    I believe it is discussed in the ultimate headlight sticky.
    AJKlug1[QUOTED] and Biscuits like this.
  5. Feb 15, 2022 at 6:07 AM
    #85
    Nubes
    Nubes Toyota Addict
    Texas
    2023 Red T4R ORP
    Double check they send you the updated TSB headlights. The new ones will not have a amber lense, it will be clear. I had to send mine back and it was an ordeal. Long story short according to the dealer I orderd from, Toyota is no longer making the 05-11 smoked TSB headlights. Edit: Also the boxes I received I could not find the part #'s and had to show them a side by side photo that they had sent me one of each. (One TSB and one non-TSB)
    AJKlug1[QUOTED] likes this.
  6. Feb 15, 2022 at 6:36 AM
    #86
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Would the DRL TSB be an issue if I have led DRL’s? They don’t make like any heat at all
  7. Feb 15, 2022 at 6:41 AM
    #87
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    I’ve seen the part numbers that are “post TSB” and click the link of those on TW and it takes me to a different part number which are the ones I ordered. They were 81150-04173 and 81130-04173 or something like that.
  8. Feb 15, 2022 at 8:19 AM
    #88
    Nubes
    Nubes Toyota Addict
    Texas
    2023 Red T4R ORP
    Not sure about LED's as I don't run them, but if the LED's don't get hot then you shouldn't have any issues. The part number you listed is the Pre-TSB part # that may have issues if you run normal bulbs (Granted it takes a few years).
  9. Feb 15, 2022 at 10:51 AM
    #89
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    See when I follow the link in @crashnburn80's ultimate headlight thread to the post tsb housings it takes me to a parts website and I get the pre tsb number. Im not too awful worried though.
    Nubes[QUOTED] likes this.
  10. Feb 15, 2022 at 5:10 PM
    #90
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    WTF.
    ^They updated the part listing to the preceding part, then listed this as the part the proceeds it?!
    Per the TSB:
  11. Feb 16, 2022 at 7:38 AM
    #91
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Yeah idk man something went funky I’m not too concerned because I have led DRL’s
  12. Jan 8, 2023 at 3:53 PM
    #92
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    These holding up for everyone? Any issues or buyers remorse?
  13. Jan 8, 2023 at 3:59 PM
    #93
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    I love mine, zero issues. I recommend putting some of this on to keep your investment looking good. Ceramic coating prevents hazing, yellowing…
    https://www.drbeasleys.com/headlight-coating-kit.html
  14. Jan 8, 2023 at 6:23 PM
    #94
    Rainier
    Rainier Well-Known Member
    OC, CA
    Black 15' Tacoma DCSB 6spd
    Worth the price tag on it? Been trying to find something to coat them, still haven’t installed been months!
  15. Jan 8, 2023 at 7:00 PM
    #95
    10thMTNgrunt
    2013 TRD Sport
    I think so, they advertise protection for five years with proper maintenance. I just put a fresh application on yearly though, just to be safe.
    One application kit should last you at 5 years, he’ll maybe 10, if you’re only reapplying every 2 to 5 years.
    Well worth it to keep your headlights looking pristine IMO.
  16. Jan 11, 2023 at 10:55 AM
    #96
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Just to confirm... For 2006 smoked I want
    these:
    https://parts.toyotaofdecatur.com/p/Toyota__/HEADLAMP-ASSEMBLY---RIGHT/69343306/8111004210.html
    https://parts.toyotaofdecatur.com/p/Toyota__/HEADLAMP-ASSEMBLY---LEFT/69343385/8115004210.html
  17. Jan 11, 2023 at 11:05 AM
    #97
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Considering the OE headlights lasted 10 years on my truck, I'm assuming the OEM TRD Pro lights should have a similar lifespan (unless I take better care of them).
  18. Jan 11, 2023 at 11:07 AM
    #98
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yes, sort of. But this gives me pause. The right assembly is the new fixed TSB assembly. The left has the new TSB part number, but the note that it is replaced by the old non-TSB assembly. Likely out of stock on the newer assemblies. So the headlights will have different DRLs and not match. I'd try to find a matching set.
    SR-71A likes this.
  19. Jan 19, 2023 at 1:54 PM
    #99
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    at this point I'm not finding the TSB version ANYWHERE!
  20. Jan 19, 2023 at 2:14 PM
    #100
    Nubes
    Nubes Toyota Addict
    Texas
    2023 Red T4R ORP
    For the 2nd gen (not 2.5) I was told by the dealer I ordered from that Toyota no longer makes them.
