GEN 3 Tacoma Pro best tire specs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JosueRD1989, Mar 16, 2019.
  1. Mar 16, 2019 at 10:18 PM
    JosueRD1989
    JosueRD1989 [OP] Well-Known Member
    I just wanted to know what is the best fitting tires for both off roading and highways.
    I will do some off roading but nothing crazy and using it to commute.
    Would like suggestions on sizes and specific tires you guys are running with pictures.
    My pro is a super white so extra points if you add pictures of it.
  2. Mar 17, 2019 at 8:46 AM
    SkunkTaco
    SkunkTaco Well-Known Member
    Kahl
    2017 Cement TRD PRO
    Best tire for offroading AND highways:
    Goodyear Wrangler Kevlar (...the stock pro tires). I get 20 mpg average and it's fine offroading until you hit mud. I'd just stick with those, they look plenty aggressive for street tires.
  3. Mar 17, 2019 at 8:48 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    A nice upgrade over stock is Wildpeaks and they have really good prices too.
    GillyLink likes this.
  4. Mar 17, 2019 at 8:49 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Boggers
    Boghog1, JMY24 and JCOOR like this.
  5. Mar 17, 2019 at 9:01 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Yeah Wildpeaks in 265/75/16 look good and work well on 7 inch stock Pro wheels
    A93AE5F1-5E5C-410F-B3EC-38C51B25F43C.jpg C8762AD4-60AD-4AF1-9136-BEE4D11A787A.jpg 96944540-BAD8-4B54-9E11-836736E8BBEB.jpg
  6. Mar 17, 2019 at 11:03 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Toyo open country at2 SL or nittos.
  7. Mar 17, 2019 at 3:00 PM
    JosueRD1989
    For the Wildpeaks, ever consider going bigger?
  8. Mar 17, 2019 at 3:16 PM
    NMBruce
    NMBruce Well-Known Member
    SW Colorado
    2020 Quicksand TRD OR, sold = 2006 GX470 (past 85, 2-1987 pickups,90, 92, 96 pickup, 2000 xtracab, 2002 double cab)
    Ironman Foamcell 3" lift, ARB dual compressor, GoPro mount, BadElf mount, Drive grab handle, RCI skids, Victory sliders, half rack, TuffStuff Alpha ll RTT, Dometic 75 Fridge, extra USB & Outlets
    Cooper AT3 & I like the Toyo Open County too
  9. Mar 17, 2019 at 4:25 PM
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
    Sure I think 285’s would look even better fill the wheel wells more and add more height but the recommended minimum wheel width for that size tire is 7.5 inches...stock pro wheels are only 7 inch. They do make aftermarket pro wheels in 8 inch width but not sure of the quality I have zero issues with vibrations with my wheel, tires and lift setup and I want to keep it that way. Maybe someone can chime in if running 285’s on oem 7 inch pro wheels...any issues
  10. Mar 17, 2019 at 4:46 PM
    Mr fuzzy
    Mr fuzzy New Member
    Craig
    Ontario Canada
    Orange 17 taco dbl cab long box trd sport
    3" lift, rims and tires, cap
    I put on 275/75/17 BFG all terrains on my 17 and when i had them on stock rims they rubbed against my upper control arm at full turn. Thats with a 3 inch lift so i had to get a slightly offset rim to clear it
  11. Mar 17, 2019 at 4:49 PM
    valeyellow46
    valeyellow46 Well-Known Member
    Christopher
    Tacoma SR5 Cavalry Blue
    I'm def gonna be in the market for a good hybrid tire - planning on throwing on the 1552 HDs with some better rubber and Ebaying these Hankooks.
  12. Mar 17, 2019 at 4:55 PM
    JosueRD1989
    Is this all on 16" tdr pro rims?
    My current truck has 265/70/r16
  13. Mar 17, 2019 at 5:10 PM
    JosueRD1989
  14. Mar 17, 2019 at 5:13 PM
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
    Correct...all on 16 inch TRD Pro Tacoma wheels.
  15. Mar 17, 2019 at 5:18 PM
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
  16. Mar 17, 2019 at 8:17 PM
    JosueRD1989
    What would be the next step up that can fit without an issue
  17. Mar 24, 2019 at 3:58 PM
    JosueRD1989
    Anything bigger than 265/75/16s on stock 2017 Pro wheels ?
    I want to go as big as i can without having to modify much. Dont mind modifying a little.
