Gen 3 Towing Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoJonn, Jan 28, 2016.
  1. Jul 26, 2016 at 4:30 PM
    #521
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
    I'd normally get 21 on that same drive.
  2. Jul 26, 2016 at 4:35 PM
    #522
    Gander
    Gander Well-Known Member
    Ellis County Texas
    2012 TRD 4x4 Tacoma
    Nice rig ....great color on that truck too..
  3. Jul 26, 2016 at 6:20 PM
    #523
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    The Taco did great pulling the Jayco 195RB from Phoenix 1100' to Hawley lake 8300'. I took it easy keeping it 55 and under and managed about 10 mpg on the way up. The steepest grades were about 7 percent for 4-5 mile stretches. The taco would would maintain the 60 MPH speed limit up but was running in the 4500 -5000 RPM range to do so. I eventually just setted in behind the SEMI trucks and other travel trailers and crept up the hills at around 3k to conserve fuel. I used ect to keep it out of overdrive and it would pull 55-60 on the flats all day long at about 2500 RPM.
    We had allot on monsoon weather including rain, hail and powerfull winds on the road and I hardly knew we were pulling a trailor. All in all very impressed with this truck.
    I couldn't get the torque app to read tranny temps just yet but I can say that the coolant temp hardly moved lol.
    This truck doesn't pull like my uncles Ram 6.7 Cummins but considering it will hang offroad with a Jeep rubicon, its easy day to day drivability and overall price I'd still have to say its the best all around vehicle I've ever owned and would have no issues pulling our trailor anywhere in the nation any time of the year.
  4. Jul 27, 2016 at 3:55 PM
    #524
    Schriner13
    Schriner13 Well-Known Member
    Austin
    Perry county, OH
    2016 Quicksand Tacoma TRD 6-Speed Manual
    Hey guys anyone know why my 6 speed manual would be shaking while I tow. Like a steady shake. Stops when I let off the gass
  5. Jul 27, 2016 at 4:02 PM
    #525
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    From your aviator pic looks like you have significant sag in the rear on your truck. My guess is drive line angle from having to much weight on the tongue. Try backing the sxs back over the trailer axle till the truck and trailer set a little more level and see if that helps.
  6. Jul 27, 2016 at 4:46 PM
    #526
    Schriner13
    Austin
    Perry county, OH
    I thought many that too but I had it hooked up today moving a swing set and its doing the same thing
  7. Jul 27, 2016 at 6:36 PM
    #527
    RedBeard1
    Red
    Greased your ujoints? All gears? Rpm range?
  8. Jul 28, 2016 at 3:33 AM
    #528
    Schriner13
    Austin
    Perry county, OH
    Everything greased. Depending on load 2500 -4000 rpm. Shakes all gears. Without a trailer is has a slight jerking almost like torque converter shudder on a auto trans with moderat to heavy acceleration
  9. Jul 28, 2016 at 5:27 AM
    #529
    tyme2par4
    tyme2par4 Well-Known Member
    NH
    N/A
    There is no way that much sag should cause a problem with the driveline. If it does, there is a SERIOUS design flaw.
    You can get a lot more sag than that with a bed loaded to capacity...
    Schriner13 likes this.
  10. Jul 28, 2016 at 7:26 AM
    #530
    Schriner13
    Austin
    Perry county, OH
    There's really not that much sag
    SilverII and IphonePirate16 like this.
  11. Jul 28, 2016 at 7:27 AM
    #531
    TejasTaco
    TejasTaco Grab a taco
    What does the trailer and ATV weigh in that pic?
  12. Jul 28, 2016 at 8:43 AM
    #532
    Schriner13
    Austin
    Perry county, OH
    The Polaris general is probably 11-1200 and that's a trailer I made it probably weighs a little over 2000. Had it weighed when I titled it but I don't have the registrayltion on me
  13. Jul 29, 2016 at 7:35 PM
    #533
    Lord Humongous
    AZ
    So I might be trying to fix something that isn't broke here but wondering what the experts think about running an auxillary electric fan on a toggle on the tranny cooler. I haven't had any issues pulling our trailer but everytime we leave the Phoenix area we're immediately hit with 7-8 percent inclines at 115F degree temps outside and thought a little extra protection in the hills wouldn't be bad. I do know that too cool ATF can be bad too so thinking I could just toggle on and off while I'm pushing higher revs while climbing. It'd be just a matter of running a wire to the switch-pro so easy install but wondering what some negatives might be? Thanks:cheers:
  14. Jul 29, 2016 at 9:53 PM
    #534
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    i would install a gauge first, see what its running at then go for it
  15. Jul 30, 2016 at 12:10 AM
    #535
    Lugnut22
    Lugnut22 The custom console guy
    Kylin
    South-East Idaho
    2016 Inferno Off-Road DCLB
    Had to rescue my sister in her subaru that went into limp mode. Taco did awesome! Even got 15 mpgs on the 25ish mile trip.20160729_113615.jpg
  16. Jul 30, 2016 at 4:53 AM
    #536
    damnfingers
    damnfingers Well-Known Member
    Gene
    Mississippi
    2016 Limited 2x4 DCSB
    My ScanGauge shows my ATF temp is normally in the 195+ dF area when not towing in 90 degree temps here in south Mississippi. I doubt your aux fan would cool it too much when towing in AZ.
  17. Jul 30, 2016 at 6:34 AM
    #537
    whitecord
    whitecord Well-Known Member
    dcsb trd off-road mt
    So i towed my boat 200 miles down to the keys to catch some lobster. I took the high way there and got around 7.5 mpg going around 70mph. On the way back i took us41 and got 10mpg averaging around 55-60mph. the boat and trailer weighs around 4300lbs loaded. plus the 4 200 lb guys in the truck. If the truck had more power it would of been a effort less tow. The lack of tq really shows even on flat florida roads at highway speeds.
    In comparison our x5 diesel did this same trip last year and got 18mpg. I could easily over take people and braking was almost unaffected(sport package with 275 front and 315 rear sport tires). But the unibody of the x5 didn't take the movement of the trailer as well and would jostle the truck around. Also the noise from the trailer would resonate threw the entire vehicle.
    over all the tacoma did great. But i will be avoiding the highway if i can.
    479C30B6-C54B-4D1C-B421-FA7827A2FF17_zps_0898e36bc5f310b3e299a159e747f2e1448888c9.jpg
    SilverII likes this.
  18. Jul 31, 2016 at 6:41 AM
    #538
    aggie77
    aggie77 Well-Known Member
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Lund Nerf Bars Auto tailgate unlock
    Well, the stay at Goose Island was great and the fishing was so-so. After towing around 5,500 pounds for 200+ miles back and forth I've decided to trade-in the Tacoma for a larger truck. It simply doesn't have enough low-end torque for the trips we will be making in the future in the Rockies and other similar terrain. The last 20 miles heading down to Rockport is due south and we had about a 15 MPH headwind. On a perfectly flat road it would not hold 60 MPH without downshifting to 3rd every 1/4 mile or so. We didn't have RVing plans in mind when I bought the truck last year. Oh well, as they say in Louisiana, C'est la vie.
    SilverII and arnette64 like this.
  19. Jul 31, 2016 at 7:11 AM
    #539
    melikeymy beer
    melikeymy beer Hold my beer and watch this
    2019 Tundra
    Good call.
  20. Aug 1, 2016 at 9:50 PM
    #540
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    I would look into a larger atf cooler. The longer it's in the cooler, the lower it's output temperature.
    The lack of torque means nothing when you are trying to hold a constant speed on a flat road. That is all horsepower.
    Torque accelerates and horsepower holds you at a constant speed
    damnfingers likes this.
