Gen 3 Towing Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoJonn, Jan 28, 2016.
  1. Feb 28, 2016 at 7:08 PM
    #81
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Travel trailer dry weights are measured when they leave the factory. Then they go to the dealer who adds batteries, propane, some appliances, and whatever else. This is why dry weights rarely add up with what you drive away with.
  2. Feb 28, 2016 at 8:06 PM
    #82
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    These are some big trailers. What do you use for mirror extensions?
  3. Feb 29, 2016 at 6:56 AM
    #83
    RitchieE24
    RitchieE24 Well-Known Member
    Zack
    Ontario
    2016 Inferno Tacoma TRD Sport Upgrade 6MT
    Wish I took a photo, but I towed 5,100 lbs on the weekend. (a 2,000lb trailer with my Saab on it which weighs about 3,100lbs.) I wouldn't want to do it every day, but the truck did it no problem. Hill assist on the manual transmission holds a trailer too which was a pleasant surprise!
    Kevindust and TacoJonn[OP] like this.
  4. Feb 29, 2016 at 7:23 AM
    #84
    aggie77
    aggie77 Well-Known Member
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Lund Nerf Bars Auto tailgate unlock
  5. Feb 29, 2016 at 7:52 AM
    #85
    TacoJonn
    TacoJonn [OP] Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    Thanks for the updates, guys. Very informative. Lots of people pulling way bigger trailers than I would ever pull with a Tacoma but good to know you guys are enjoying towing with your new Tacomas.
    gsubioguy likes this.
  6. Feb 29, 2016 at 9:52 AM
    #86
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    How easy is "easy".... Did you try it on the highway?
    2nd gen here, and I can't pull 28' pontoon (probably 4,500-5,000 lbs) while maintaining 70. Have to stay at 55-60 otherwise it'll downshift to 3rd and run it up to 5,000 RPM
  7. Feb 29, 2016 at 2:37 PM
    #87
    jstudios
    jstudios Active Member
    2014 silver TRD sport, 2016 limited bbp
    Did you notice any problems with jerking or slipping around turns?
  8. Feb 29, 2016 at 2:47 PM
    #88
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Any one know if the ProEFX folding mirrors will fit the 3rd gen trucks?
  9. Feb 29, 2016 at 5:22 PM
    #89
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Nope. It did fine with turns, even fairly sharp ones to get to the dump station. No slipping while backing either. If your front tire are slipping/jerking during turns it's an indication that you are too light on the front end. If that's the case it's dangerous to drive as it will be too easy to lose control.
    jstudios[QUOTED] likes this.
  10. Feb 29, 2016 at 5:32 PM
    #90
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Dude, you have zero visibility with your mirrors.
  11. Feb 29, 2016 at 7:17 PM
    #91
    stdavis23
    stdavis23 Well-Known Member
    Middle TN
    2016 Silver OR
    TRD Pro Wheels, 3" Fat Bobs Predator Strike Force Lift, 285/70/17 KO2s, Painted front grill, blacked out badges, Leer 100 XR, roof rack.
    I could actually see ok on the interstate but turns not so much. I will be doing something about that before the next pull.
  12. Feb 29, 2016 at 10:03 PM
    #92
    thors.hammer
    thors.hammer Well-Known Member
    Quick question for those of you with far more experience that I have. At what point do you want brakes on the trailer and a brake controller on the Tacoma? Here's the trailer I bought for hauling our two Honda Ranchers (575 pounds each). Should I worry with that load?
    Here's a pic with them loaded.
  13. Feb 29, 2016 at 10:27 PM
    #93
    amazzajr
    amazzajr Well-Known Member
    Anthony
    Irvine, California
    2016 Tacoma, DCSB, TRD Sport, 4X4, Silver
    I've pulled that boat with a 2nd Gen AC, and a 2nd Gen DCSB. All 3 were fine - no issues around town, 60-65 on the highway. I don't go 70 when I'm pulling the boat.
  14. Mar 1, 2016 at 9:11 AM
    #94
    stdavis23
    Middle TN
    2016 Silver OR
  15. Mar 1, 2016 at 9:13 AM
    #95
    stdavis23
    Middle TN
    2016 Silver OR
    I wouldn't think you would need breaks or a controller, but then again when I pull something I tend to drive slow and easy. I wouldn't drive 80 mph because obviously it's not going stop as well. Keep it slow and steady you'll be fine.
  16. Mar 1, 2016 at 9:26 AM
    #96
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    Manual says 1k pounds I believe. Really up to you. I say at least go ahead and invest in the controller as they can be purchased faily cheap. If your current trailer doesn't have breaks no big deal at the moment for that load. I pull a hard sided pop up camper. Dry weight is around 2200lbs. I made sure it had breaks and they have come in handy for sure. Came up to a stopped car on a bridge one night.....happy I had breaks then.
  17. Mar 1, 2016 at 9:58 AM
    #97
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    As @OffsetPlayer2 said, your owners manual states this on page 171:
    and this on page 174:
    You can choose to follow Toyota's advice or not. If you are in a situation where an accident occurs and braking could have made a difference then you are likely on thin ice if you exceeded the limit. That's my 2 cents.
    OffsetPlayer2 likes this.
  18. Mar 1, 2016 at 10:49 AM
    #98
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    Lots of states require trailer brakes over a certain weight as well. Most common seems to be 2000lbs, but some set the limit lower.
    Edit: I looked again, and it seems like most states start requiring trailer brakes at 3,000 lbs.
  19. Mar 1, 2016 at 11:00 AM
    #99
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    You're fine without brakes. Just remember that you're being a rockstar with no trailer brakes and drive a little more cautiously.
  20. Mar 1, 2016 at 2:14 PM
    #100
    OffsetPlayer2
    Yep my state requires it at 2k I believe. Could be 3 but I think it's 2. Toyota says 1k which is a little on the light side. If you are questioning it, go ahead and get the controller installed and at the bare minimum, consider breaks on the next trailer you purchase. I made it a requirement. Not because of any laws or anything, but I know how other drivers love to cut people off then slam on breaks for no reason. Trailer breaks make a huge difference. Your trucks breaks will thank you later. I had upgraded breaks and drilled and slotted rotors on my last truck. I'll be sure to upgrade these as well once other options are available.
    EDIT: pretty sure I've been using the wrong brakes in my responses but whatever. You guys get what I'm taking about.
