Gen 3 Towing Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoJonn, Jan 28, 2016.
  1. Nov 10, 2017 at 7:56 PM
    #1141
    BillyToy
    BillyToy Well-Known Member
    PNW
    2017 Tacoma TRD Pro 6MT
    I've posted this elsewhere, but it should be here.
    2017 Toyota Tacoma TRD Pro 6spd MT pulling a ToyotaMR2 3.5"Turbo/Intercooled 5spd MT Sandrail. Both have sweet leather TRD shift knobs.
    That is all.
    a2lowvw, arnette64, SilverII and 4 others like this.
  2. Nov 11, 2017 at 8:19 AM
    #1142
    Parkrat
    Parkrat Active Member
    McKinney, TX
    2017 TRD 4x4
    2017 Tacoma TRD Sport 4x4 6spd MT Access Cab
    Just got back yesterday 1300 miles towing my 2014 Forest River 22bp travel trailer. Dry weight 3500lbs and tongue weight 438lbs.
    Had a lot of 22mph head and cross winds. Drove from Dallas to Santa Fe NM so lots of open plains.. Usually only tow it 6 hours.
    I decided to install a Curt Sway Bar before I went and I'm glad I did. I couldn't believe the difference it made! It was amazing. I don't have a WDH.
    The worst gas mileage I got was 7.5. Best was 11.9. I probably averaged 9 the whole trip. Did okay. Most of the trip was in 20mph winds. It did best when I kept it around 3K RPM. When the winds died I could keep it in 6th gear at around 65mph.
    There were a few other people at the RV park that had Tundras and were pulling about 5K trailers. They said they averaged around 9-10mpg. Thought about moving up to a Tundra, but really don't think it's necessary.
    Ruggybuggy and SilverII like this.
  3. Nov 11, 2017 at 3:14 PM
    #1143
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    How did you get uhaul to rent you that trailer? I thought they don't rent unless towing vehicle is x3 the weight of the towed cargo.
  4. Nov 11, 2017 at 3:21 PM
    #1144
    Shellshock
    Iowa
    It’s not 3x
    From the U-Haul site
    • Must weigh at least 3,500 lbs. (curb weight), and must equal or exceed 80% of the combined weight of the trailer (2,210 lbs.) and the vehicle being towed (up to 5,290 lbs.).
    https://www.uhaul.com/Trailers/Auto-Transport-Rental/AT/
    specter208[QUOTED] likes this.
  5. Nov 11, 2017 at 3:25 PM
    #1145
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    I don't remember what the limitation was when I rented a dolly from them once but I knew it wouldn't fly if I told them what I was actually doing (going 600 miles in my 22RE powered '93 pickup pulling a '75 Electra 225) so I said I'd be dragging a hollowed out CRX shell. Done and done. Dumbest tow situation I've ever undertaken, but I kept to county roads across the square states and probably didn't get over 45 mph the whole time.
  6. Nov 12, 2017 at 3:13 PM
    #1146
    moser633
    moser633 2016 TRD OR AC
    2016 magnetic grey Tacoma TRD Offroad
    Aux Reverse Lights, tailgate inserts , TRD PRo Grill, Truxedo lo pro gt tonnaeu cover, Cali Raised led Apex stealth light bar Cali raised led Ditch Lights ARB on Board air Method NV Bronze 16 in with 265 75 16 Cooper STT Pro
    Walked in told them what I was towing asked if i wanted a dolly or trailer. I wanted trailer for the long haul plus the Rav is 4wd. I was under my weight limits. they allow to tacomas as long as your meet the weight requirements. No sag whats so ever to. and i was right about at 5800lbs IMG_0031.jpg
  7. Nov 12, 2017 at 7:32 PM
    #1147
    specter208
    California
    are there any weight distribution hitches that are easy to install and remove to U-Haul trailers?
  8. Nov 13, 2017 at 7:37 PM
    #1148
    moser633
    not that i know of Uhaul doesnt allow them on their trailers .
  9. Nov 13, 2017 at 9:31 PM
    #1149
    wafersmith
    wafersmith Well-Known Member
    Brian
    2017 TRD OFFROAD
    Many
    The shift sense pro does the shifting for me so that is the benefit;). I do like the automatic nature and the programmable shift settings. I use it when not towing as well. I really love the air bags, use then for towing and hauling, the ability to tune them for each load is awesome. I don’t have much bounce at all after the air bags. I do have to be mindful of the way I load the gear in the trailer and truck as it does, or can, make the trailer wag and I don’t have a equalizing hitch. I wouldn’t think shocks would make a huge difference. I would consider replacing the super spring with the air bags. Since those springs are progressive they will allow more bounce so as to retain the ride quality when unloaded as well.
  10. Nov 13, 2017 at 10:20 PM
    #1150
    Tyrant1919
    Tyrant1919 New Member
    Purchased truck in middle of Sep. Road trip time at the end of Sep. DC > GA > TX > AZ > CA > DC. Took i95 > i85 > i20 > i40 > i5 out to California. I80 all the way back to DC. Entire trip was around 7500 miles. Trailer probably weighed an even 2k lbs. No issues. Averaged 16mpg roughly, Going 65-70. Had 45 gal of gas in the nose of the trailer, a bit tongue heavy I'd say. I've done a few cross country trips. It was a pleasure to drive. Had my first 5k service before my first payment.
    melikeymy beer likes this.
  11. Nov 14, 2017 at 6:46 AM
    #1151
    Blktre
    Blktre Well-Known Member
    Land of Oz....
    16 Super White DCLB TRDOR: The White Goat
    After watching the famous video going around proving how a WDH is better for weight distribution/anti sway than bags for towing I chose a WDH. Bags are obviously great for payload but that pretty much where most the benefit stops. I can see using bags in conjunction with a WDH to gain some extra level with weaker stock springs. With that said, I pick up my Coachmen Freedom Express (4000# dry) in a few days. If I feel the WDH needs a little extra help with my stock springs I'm 95% certain I will go with Sumosprings over bags for a variety of reasons.
  12. Nov 14, 2017 at 10:33 AM
    #1152
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Which video? Got a link for the curious?
  13. Nov 14, 2017 at 10:49 AM
    #1153
    rockrosa1976
    rockrosa1976 First time Taco owner
    Cincinnati
    2017 SR5 V6 4X4 DCSB
    Window Tint - August 2017 Predator Steps - August 2017 All Weather Mats - August 2017 Chrome Exhaust Tip - August 2017 Hitch Cover - August 2017 Center Console Organizer - September 2017 Bed Mat - September 2017 Nox Lux Blackout Overlays - October 2017 Nox Lux Tacoma Tailgate Inserts - October 2017 Pro Grill - December 2017 Clazzio Leather Seat Covers - February 2018 Rear Seat Cover - February 2018 Bed Netting - February 2018 Plast-Dipped Wheels/bumper caps - April 2018 A/C Drain Mod - May 2018 OEM Tonneau Cover - July 2018 LED Headlights/Fogs - August 2018 Glovebox letters - October 2018 TRD Pro Shift Knob - April 2019 Rigid Fog lights - November 2019 Goodyear Wrangler AT 265/70/16 - March 2020 Grill Lettering - May 2020
    I have a WDH on my Summerland (about 3800-4000lbs loaded) with my stock springs and found that there were no issues. Should I be worried?
  14. Nov 14, 2017 at 11:01 AM
    #1154
    Opa5
    Opa5 Member
    Denis
    Mass
    2017 Tacoma 4x4 DC TRD OR
    Hondo garage radio knobs with ar15 bolt engraved. In channel vent shades.vinyl tg inset letters,glove box,engine cover & door sill protector vinyl insets also.Just getting started!!!
    I hope this is the right thread for my question if not I apologise.Here goes anyone know who makes a black locking hitch pin that fits the factory hitch on a 2017 Tacoma OR DCSB every one I have tried is not long enough to engage the lock.
    Cuffs likes this.
  15. Nov 14, 2017 at 11:10 AM
    #1155
    Blktre
    Land of Oz....
    Probably no need for worry but assuming your WDH is setup correctly, on a flat surface with the trailer unhooked measure from your wheel wells to the ground on the front and back. Hook your trailer up and the WDH then measure again. Your measurements should be no more than a 1/2" or less difference from the measurement without the trailer. If it is more than that then Id weigh the tongue on your wet and loaded trailer and see where you are for TW. You can also move gear around in the trailer and in the bed of your truck and see if that helps. If that doesnt help either to get within your fender measurements then Id consider bags or sumosprings in conjunction with your WDH to help take up the slack on your stock springs. Some will say to change out the rear suspension leaf pak which is also good advice but its spendier and might possibly change the ride without a load.
  16. Nov 14, 2017 at 11:14 AM
    #1156
    Blktre
    Land of Oz....
    Shulala likes this.
  17. Nov 14, 2017 at 11:19 AM
    #1157
    mbarbay
    mbarbay Well-Known Member
    Baton Rouge, LA
    2016 Tacoma BBP DCSB LTD 4X4
    while i haven't found a black one, i will say that i had to get the longer pin for mine. i can't remember the length but its for class v hitches i believe, instead of class IV
    Cuffs likes this.
  18. Nov 14, 2017 at 11:31 AM
    #1158
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    You too? I think I found one on etrailer.com. Have not ordered it yet. Their customer service is so good though, I’m going to call them and ask them to verify it before I buy.
    TacomaCZman likes this.
  19. Nov 14, 2017 at 11:44 AM
    #1159
    rhouse181
    rhouse181 Well-Known Member
    2017 TRDOR DCSB
    Latest towing adventures... 650 miles round trip through Texas hill country. Hauled up a pair of 4x4 blinds and returned with a mesquite tree, 800 lbs of pecans, and a full 120 qt cooler.
    Stock DCSB OR with sumo springs... S4 ECT averaging 11 mpg or so @ 70 mpg.
    REDNECKTEX and Garyji like this.
  20. Nov 14, 2017 at 12:35 PM
    #1160
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    OnHartung'sRoad likes this.
