Gen 3 Towing Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoJonn, Jan 28, 2016.
  1. Jan 16, 2018 at 11:36 AM
    #1221
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    That is for combined weight. Regardless if it’s personal or commercial. Only time it isn’t considered is if you’re towing an RV. Because the mto website is very vague, I went to the weigh scales and spoke to an mto officer. You can get big fines if towing improperly or overweight.
  2. Jan 16, 2018 at 4:27 PM
    #1222
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    Your GVWR is the weight of everything resting on your truck's 4 tires. This includes the truck, you, family, friends, all fluids, your lift kit, your weight distributing hitch, tongue weight...
    Often times published curb weight + payload won't add up to GVWR. If you take your truck to the scales it'll weigh a couple hundred pounds more than the published curb weight + your weight.
  3. Jan 16, 2018 at 5:41 PM
    #1223
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    Ya I know I asked that earlier then figured it all out. I posted it a page back
  4. Jan 17, 2018 at 7:46 AM
    #1224
    OkieCowboy
    OkieCowboy Well-Known Member
    Lloyd
    Choctaw, Oklahoma
    2012 TRD 4X4 Access Cab
    Are there videos that show how to install a trailer brake control? I have a 2017 DCSB TRD with AT. We are towing a 3100 lb. 19 ft. TT 1,500 miles round trip in a month. Oklahoma to south Texas. I have a WDH. I towed the trailer from eastern Oklahoma to Oklahoma City without the brake controller and it did just fine. Going to sell the TT after the trip.
  5. Jan 17, 2018 at 7:49 AM
    #1225
    fdb03taco
    fdb03taco Well-Known Member
    Danny
    SOMD!
    2014 Tundra SR5 CrewMax 5.7 4x4
    All you need is the brake controller and an inexpensive harness. The truck is pre wired if it has the towing package. You'll have to remove the driver side kick panel to find where to plug the harness. I don't want to sound like that guy, but I searched to find the information and pictures.
  6. Jan 17, 2018 at 8:38 AM
    #1226
    OkieCowboy
    Lloyd
    Choctaw, Oklahoma
    Thanks fbd03taco. I have a brake control attached to a GM connector. Hope I can remember how I wired that.
    fdb03taco likes this.
  7. Jan 17, 2018 at 8:52 AM
    #1227
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    If you go to a trailer place where they sell brake controllers, they may also sell the wire leads that are specific to your truck so everything will just plug in. When digging into the wires under the panel in your truck, make sure it’s the right one as there are a couple of plugs in there. Find the one that matches your truck specific lead. Good luck!
  8. Jan 17, 2018 at 9:16 AM
    #1228
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
  9. Jan 17, 2018 at 9:47 AM
    #1229
    Cnd-GB
    Cnd-GB Well-Known Member
    2016 Nissan Frontier King Cab Pro-4X 6sp
    Not to take away from the thread but it is only for commercial vehicles and it is the truck GVW rating and not combined. Here is the link to the MTO site where it gives you the exemptions for a CVOR.
    www.mto.gov.on.ca/english/trucks/commercial-vehicle-operators-registration.shtml
    Here is the blurb specific to what I was talking about. Until recently I was one of those enforcement officers you are talking about.
    "Operators that don't need a CVOR certificate
    Carriers that operate certain types of vehicles do not need a CVOR certificate. These vehicles include:
    pickup trucks that:
    • have a manufacturer's gross vehicle weight rating of 6,000 kg (13,227 lb)
    • are being used for personal purposes without compensation
    • are fitted with either the original, unmodified box installed by the manufacturer, or an unmodified replacement box that duplicates the one installed by the manufacturer
    • are not carrying or towing a trailer carrying commercial cargo or tools, or equipment of any type normally used for commercial purposes"
  10. Jan 17, 2018 at 10:12 AM
    #1230
    fdb03taco
    Danny
    SOMD!
    Shouldn't be any actual wiring required on the Tacoma. Just plug and play once you find the connector behind the kick panel.
  11. Jan 17, 2018 at 10:22 AM
    #1231
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    Thanks! So am I still Limited the wt on my ownership? The max weight that I could get without a CVOR was 4500kg
  12. Jan 17, 2018 at 12:17 PM
    #1232
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    So I’m towing a Jeep on a dolly from NY to TN in March and had a few questions. It’s an 18 trd off road dbl cab long bed says it’s rated for 6,400 lbs. Jeep says it’s 3,100 plus it’s got some heavy duty axles and armor so my friend and I estimate about 3,800. He will be putting stock size wheels and tires and putting his 33” MTR mud terrains in my bed. I will also be putting my dirt bike in the back for the trip to Tennessee. U-Haul says the dolly weighs 750lbs so by my calculations I’m under the weight on a bone stock truck (for now). Will I be riding on the bump stops with the tongue weight from trailer and tires/bike in the bed? Also, the dolly doesn’t have brakes in fact most don’t. Should I be concerned?
  13. Jan 17, 2018 at 1:58 PM
    #1233
    fdb03taco
    Danny
    SOMD!
    It's not going to be fun but it sounds like you should be okay based on your calculations
  14. Jan 17, 2018 at 3:00 PM
    #1234
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    Anything over 3000 lbs towing without some kind of brakes is going to be... normally we give ourselves enough time to stop and we’re aware of our load. It’s the unexpected jackass who stops or pulls in front of you. You could be liable if something like that happens. It’s a really long trip through big hills too!
  15. Jan 17, 2018 at 4:42 PM
    #1235
    Shellshock
    Iowa
    I dolly towed a 2006 corolla (2500-2700bs plus dolly) 800 ish miles with no issue. The car was packed full of stuff in addition to 2 passengers and a truck bed full of stuff. No issues here. Take your time and anticipate stupidity ahead of you and you’ll be fine.
    If you are using a dolly, tongue weight won’t really be a concern. If you were using a car trailer you’d get some squat but the dolly the weight sits right on the axel, not the receiver.
  16. Jan 17, 2018 at 5:30 PM
    #1236
    Cnd-GB
    No worries. Correct, what ever the GVWR is for your truck on the ownership. 4500 kg or less no CVOR required. My brother has a construction company with 25 trucks in the fleet and only 4 of them require a CVOR as they are over 4500kg.
  17. Jan 17, 2018 at 5:34 PM
    #1237
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    Doesn’t that 4500 kg include trailer w/load?
  18. Jan 17, 2018 at 5:51 PM
    #1238
    Cnd-GB
    Sorry, yes it does. Trying to do something else while posting not a good thing. I should have stated RGW (Registered Gross Weight) which can include the trailer. Going from memory here but generally the weight of a towed trailer and its load are added to the RGW of the truck. The load would include driver, passengers, fuel, equipment, tools, cargo, equipment, etc. carried in the truck and trailer. However light trailers that transmit to the highway a total weight of 2,800 kilograms (6,173 lb.) or less are not included in determining registered gross weight but the tongue weight of the trailer would need to be included in the truck weight. If you weigh all of this and it still works out to 4500 kg or less no CVOR. Hope this helps and makes sense gov't speak can definitely get confusing.
    If you search the MTO site they tell you how to determine how much a truck should be registered for and have diagrams. At least they did when I was there, I have been gone for just over a year now. You can search at that link that I included.
    Steadfast[QUOTED] likes this.
  19. Jan 17, 2018 at 5:55 PM
    #1239
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Happened to me with the '12 OR. But the crazy rock came from the opposite lane of the freeway. I had safelight come and repair the windshield. Asked Farmers Ins. if the cost could be covered. They said yes. They paid for the job plus the house call. Nice to get a little back. I'd go that route.
  20. Jan 17, 2018 at 5:56 PM
    #1240
    Topanga Taco
    Rick
    Oooops. My bad. Wasn't thinking. Feb. 2016. Next time keep that in mind, or anyone for that matter.
