Gen 3 Towing Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoJonn, Jan 28, 2016.
  1. Mar 6, 2016 at 7:54 PM
    #121
    Doug007
    Doug007 Well-Known Member
    Doug
    Houston, TX
    '16 TRD Off-Road M/T
    I towed my friends race car home today after he had an issue with his tow vehicle. Also had the race 911 engine in the bed. It was a rough weekend for him!
    The truck towed great with about a 3500 lb trailer (with wireless trailer brakes) and 300 lb motor in the bed. Got about 10 mpg on mostly flat terrain.
  2. Mar 6, 2016 at 10:25 PM
    #122
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    This is what you call a dumbass. That's a 7k tractor and 3k pound trailer easily.
    Moving it back would only make things worse because the load would whip the back end of the light Tacoma around.
  3. Mar 6, 2016 at 11:47 PM
    #123
    .劉煒
    .劉煒 Well-Known Member
    2016 Inferno DCSBTRDORMT
    14mpg @ 75mph.
    George1441, mistah and 2016TacomaTRD like this.
  4. Mar 7, 2016 at 7:34 AM
    #124
    Mike O
    Mike O Well-Known Member
    2016 TRD OR MGM Access Premium LB
    Mobtown Sliders, SSO Slimline bumper, Baja Amber lightbar & fogs, Sumo bump stops
    First trip with weight distribution hitch. Turns out I was wrong about the placement of the fresh water take. It is before the trailer axles and therefore when full, put more weight on the hitch. My wife's pictures below were taken with that tank full, but draining. With the weight distribution hitch and brakes on the trailer I felt just fine in the Ozarks. Wouldn't worry about a several hundred mile trip apart from fuel mileage.
    Ralph does not seem concerned.....
    cshrum, George1441 and Kevindust like this.
  5. Mar 7, 2016 at 8:28 AM
    #125
    joeshmo
    joeshmo Member
    Joe
    Are there any other mirror extensions you guys are using? Thank you!
  6. Mar 7, 2016 at 8:33 AM
    #126
    Mike O
    I'm using these. Can probably be had much cheaper elsewhere. If I were towing every week or even every other week all year I'd seek a more permanent solution, but I've been impressed with these so far.
  7. Mar 7, 2016 at 1:52 PM
    #127
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    Not sure what gen Taco you have, but this is what I have on my 13...They function great...these are complete bolt on, remove the existing factory and bolt these on, installation is about 30 minutes, 15 min each side....
    IMG_20160307_153119_525.jpg IMG_20160307_153127_052.jpg IMG_20160307_153137_477.jpg IMG_20160307_153153_120.jpg IMG_20160307_153216_875.jpg IMG_20160307_153224_134.jpg
    .28 and thors.hammer like this.
  8. Mar 7, 2016 at 2:00 PM
    #128
    Mike O
    Nice! I wonder if these work on a 2016? I suspect you loose blind spot monitor, heat, and remote control? Can you confirm? Still they look very useful (and stylish!).
  9. Mar 7, 2016 at 2:13 PM
    #129
    gmann1972
    Greg
    Rhode Island
    Well seeing my Taco is a 13 and it's a base SR5 I don't have all the fancy gadgets on my truck, like what you are describing. I do still maintain the remote control feature and if I remember there was an option for directional. But they sure do work great when i'm towing my 25' TT
  10. Mar 7, 2016 at 3:38 PM
    #130
    Vandy09
    Vandy09 Well-Known Member
    2016 Tacoma TRD offroad
    Lol they are like mini ram mirrors. Having that stlye of mirror, do you find yourself keeping them flipped up in non towing situations?
  11. Mar 7, 2016 at 3:40 PM
    #131
    gmann1972
    Greg
    Rhode Island
    no not at all...always down unless towing...But then again that's the only thing the truck is used for. I don't drive it during the week, only weekends during camping season...
    Oldkzrider likes this.
  12. Mar 7, 2016 at 4:47 PM
    #132
    Mavric31
    Mavric31 Well-Known Member
    2016 DCSB TRD Sport Super Awesome Edition
  13. Mar 8, 2016 at 4:32 AM
    #133
    aggie77
    aggie77 Well-Known Member
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Lund Nerf Bars Auto tailgate unlock
    Not a bit.
    Mr. Torgue and Mavric31[QUOTED] like this.
  14. Mar 8, 2016 at 9:30 AM
    #134
    TacoJonn
    TacoJonn [OP] Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    Seems like the gen 3's squat a lot when towing. Anyone using bags?
  15. Mar 8, 2016 at 9:51 AM
    #135
    Mike O
    In my case (post #129), the squat is caused by excessive weight on the hitch. Water tank at the front of the trailer full with a trailer that is relatively front heavy to start with. Still pulled/drove fine, but once the water was out was much more level. Unfortunately no pics.
    WD hitches also need to be properly adjusted. When mine was installed they first went too far w/regard to pulling weight off the truck making a connection difficult. They then went too far the other way. So I need to adjust the hitch 'one hole higher' to level it out even better than without water.
    Unless you are in excess of the prescribed tongue weight (and therefore in excess of other safety concerns) I don't think I would consider bags. You never know though, perhaps someone could convince me of the benefit (assuming everything else was in order).
  16. Mar 8, 2016 at 10:09 AM
    #136
    SSG665
    SSG665 Well-Known Member
    Georgia
    18 Tacoma
    Exactly..Hope he's not near my family on the road..
    RideFast likes this.
  17. Mar 8, 2016 at 8:17 PM
    #137
    justintackitt
    justintackitt Well-Known Member
    2016 Tacoma DCTRD4X4
    Just towed this 180 miles with a mix of level and 6% grade hills. Trailer weight 4619 pounds with about 500 on the tongue. I had a wd hitch all ready to go but the trailer builder built the a frame in such a way that I will need to weld the wd brackets instead of bolting them on. It towed flawless. No sway, nothing. Ect button on 4th gear running 2500 rpm in the flats and Max 3500 to 4000 rpm in the hills. Average 10 mpg. Going tomorrow to have wd brackets welded to the frame and then I will be good to go. I was impressed by the way it towed. Forgot to add...16 foot by 8 foot by 8 foot.
  18. Mar 8, 2016 at 10:16 PM
    #138
    mxwrench
    mxwrench Well-Known Member
    Brian
    Hi Desert, So Cal
    2016 DCSB TRDOR 4X4 JBL SW
  19. Mar 9, 2016 at 6:12 AM
    #139
    keithert
    keithert Well-Known Member
    Subscribed. I'm interested in towing a camper of around 4000 pounds.
  20. Mar 9, 2016 at 7:56 AM
    #140
    TacoJonn
    Jon
    Laramie, Wyoming
    Specs? Towing impressions?
    iyapysnf likes this.
