Gen 3 Towing Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoJonn, Jan 28, 2016.
  1. Jul 17, 2020 at 6:45 AM
    #1601
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    Yeah that seems high for a smaller single axle Airstream like that. I thought they were supposed to be very light due to the aluminum construction? I have a dual axle Apex Nano and it is ~4000 lb. dry and definitely looks bigger than your trailer there.
    I use an E2 WDH with anti-sway that seems to handle it fine and keeps the sway down to a minimum. It's takes a bit to get up to speed and I usually stick around 60mph or so, but I've never felt unsafe about it.
    But you should definitely stick to your comfort zone, so if you don't like it, then don't do it!
    RushT[QUOTED] likes this.
  2. Jul 17, 2020 at 11:39 AM
    #1602
    supremepizza
    supremepizza Member
    Los Angeles, CA
    '17 TRD OR 4x4 AT
    I'm just estimating from mfg spec, it definitely could be lighter.
    I was using one of these, but not entirely sure the person who rented me the trailer had me set it up properly:
    https://andersenhitches.com/Catalog/andersen-nosway-weight-distribution-hitch.aspx
    I definitely felt the weight of that thing pulling me around the road.
    AT Habitat, here I come.
  3. Jul 17, 2020 at 11:47 AM
    #1603
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Interesting. Those have a decent reputation in general, but are also known to not handle heavy weights as well as the tension bar setups.
    I’m pretty sure they have a friction collar in the hitch setup that requires tongue weight to activate. It’s possible the trailer was tail heavy so a light tongue and not much tension in the chains. Who knows. :)
    But you’re smart to be concerned about a setup that makes you uncomfortable, for whatever the reason.
  4. Aug 18, 2020 at 9:58 AM
    #1604
    ChrisSandstorm
    ChrisSandstorm Well-Known Member
    '01 Land Cruiser, '16 TRD OR DCSB
    I posted up on another thread but here is what I just towed from Salt Lake, to Livingston MT and back to Denver. It was a bit if a grind. I will do it again I am sure but next trip will use the 2001 Land Cruiser and see how she pulls it. Dry weight is 3500 lbs. I am sure it was closer to 4200 lbs when pulling.
    7MPG thru Wyoming, 8.5 thru Colorado's flats..
  5. Aug 18, 2020 at 10:08 AM
    #1605
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    2015 Rpod 182g 3k dry, est 3800lb on this load. Plus DR 125 & 350 and generator and gear in bed. EST 900lbs. Pulled up Highway 49 in CA near Downieville to Camp just fine. EST 10 mpg. I’m on 33’s with 5.29’s and OVtune 2.0 91 octane tune. Also firestone bags were around 45psi and use an extended WDH to tow with the tailgate down.
    this was the most loaded down I’ve been and it seemed to haul the load very well. Could even hold 5th gear at 55mph on the flat parts of interstate 80.
    geoyota760 and ChrisSandstorm like this.
  6. Aug 18, 2020 at 10:19 AM
    #1606
    KingJeff813
    KingJeff813 Well-Known Member
    Wisconsin
    2020 Alfa Romeo Giulia Ti Sport Q4
    Traded it in.
    Gulf Stream Vintage Cruiser with WDH, about 3200 dry, guessing around 4K loaded. I've taken it from southern WI to Northern WI (about 3.5-4 hours) a few times with no issues. Truck says I get 9-10mpg.
    Jay1313g, marc1 and ChrisSandstorm like this.
  7. Sep 13, 2020 at 6:44 AM
    #1607
    Fishingeek603
    Fishingeek603 Well-Known Member
    New Hamphire
    2023 TRD Sport, Super White Access Cab 4x4
    Fox 2.0 front with res adjustable rears jba ucas icon rxt leaf pack.
    Hello all, Im currently in the process of purchasing a new to me bass boat. I have the 2.7L engine in my tacoma, the boat and trailer will weigh in at around 2,400 lbs. I will be mainly towing an hour and a half (one way) with various terrain i.e medium mountains and hills with some high way mixed in. My question to you guys is should I install a trans cooler? If so what would you recommend? Also is there any additional sway bar support I can add? I'm new to the towing world. So forgive me if this is common sense for most. Thank you!
  8. Sep 13, 2020 at 8:12 AM
    #1608
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Maybe there was an issue with your setup? Tongue weight not correct?
  9. Oct 27, 2020 at 3:32 PM
    #1609
    tow-coma
    tow-coma Well-Known Member
    I tow a toy hauler with larger sides than that and I only get a single side to side movement when a large truck passes. Were you running a friction sway stabilizer or any kind of sway stabilizer? I am also on two axles
  10. Oct 27, 2020 at 4:44 PM
    #1610
    Sheepnick1
    Sheepnick1 TacoJerry.com
    Nick
    Lynchburg Virginia
    2019 Tacoma trd off road
    Does anyone know a good ball and hitch kit that has all 3 different sizes on the hitch? I'm tired of always having the wrong ball size when I go to tow something!
  11. Oct 27, 2020 at 5:08 PM
    #1611
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Thank you for that. I appreciate your honestly.
    Zim
  12. Oct 27, 2020 at 5:17 PM
    #1612
    FirsandFire
    FirsandFire Well-Known Member
    New York
    No more Taco. A 2500HD and a Bronco sport
    Just pulled this home today. Towed way better than I expected. I believe it’s a 7x14.
  13. Oct 27, 2020 at 5:23 PM
    #1613
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    Great combo.
    Zim
  14. Oct 27, 2020 at 5:31 PM
    #1614
    FirsandFire
    New York
    Thanks! I’m pretty happy with it. I had a color matched silver 7x12 on order but every manufacturer seems to be backed up. I found this an hour away and the price was almost too good to be true. I'll deal with a darker silver for the $avings I got.
    Tacman19[QUOTED] likes this.
  15. Oct 27, 2020 at 6:43 PM
    #1615
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    sierra.grit likes this.
  16. Oct 27, 2020 at 7:22 PM
    #1616
    deusxanime
    MN
    Yep exactly what I was going to post. Get the stainless steel set if you want it to not rust or corrode. But for some reason they still give you a non-stainless nut and washer so you have to contact their support to get those sent to you in stainless steel if you want it.
    Here it is on Amazon: https://www.amazon.com/dp/B0000AY9HO/
  17. Oct 27, 2020 at 8:20 PM
    #1617
    RushT
    North Texas
    I had one of these too, worked pretty well for me too.
  18. Nov 1, 2020 at 6:16 AM
    #1618
    sebooher95
    sebooher95 Well-Known Member
    Mississippi
    ‘18 MGM Sport 6MT 4x4 KDMax6.0 XT
    KDMax6.0 XT Tuned
    hasn’t let me down yet
  19. Nov 1, 2020 at 8:58 AM
    #1619
    KentuckyDoug
    KentuckyDoug Well-Known Member
    NC
    2020 TRD Sport 4x4
    None
  20. Dec 30, 2020 at 9:23 AM
    #1620
    barnes828
    barnes828 Well-Known Member
    Nathan
    Vancouver, Wa
    21’ DCLB OR WHITE
    Here’s my submission. My dad built this trailer about 15 years ago and I believe it’s a 10x12. Hauled a load of cedar triangles I got for free through a buddies work
    Gen3TacomaOBX likes this.
