Gen1 headlight OEM Toyota headlamp assembly complete units ?
Discussion in 'Lighting' started by badaboom, Oct 23, 2017.
  1. Oct 23, 2017 at 1:39 PM
    badaboom
    badaboom [OP] Well-Known Member
    Rick
    GEN1 1998 Toyota Tacoma SR5 4cyl. 2.7
    Pretty much nothing yet rolls drives sucks fuel
    Working specifically with/on 1998 Toyota Tacoma SR5 TRD, ext cab, 4x4 , 5spd manual, 2.7.
    Are either the LH or RH side headlight assemblies different for specific models over
    the 1997-2000 vintage years? or GEN1 Tacomas in general ?
    example for 2wd or 4 wd for std cab or extended cab etc.
    Hope i didn't muddy up the waters to much with my explanation.
  2. Oct 23, 2017 at 6:38 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    95-97, 98-00, 01-04 headlights are all different.
    It shouldn't matter 5 lug, 2wd, 4wd, etc.
    The corner lights get a little more confusing.
    95-97 and 01-04 are similar since they will have either a chrome or painted edge
    98-00 go all the way out to the black trim
    5lug 2wd trucks also have different fenders and corner lights than prerunner and 4wd 6 lug trucks
  3. Oct 23, 2017 at 6:55 PM
    badaboom
    Rick
    If you happen to know part numbers for the headlamp assemblies for 98-2000 OEM Toyota let me know thanks.
  4. Oct 23, 2017 at 7:06 PM
    nzbrock
    Noah
    San Marcos, TX
    R 81110-04090
    L 81150-04090
  5. Oct 23, 2017 at 7:12 PM
    badaboom
    Rick
    Thanks
  6. Oct 24, 2017 at 6:12 PM
    badaboom
    Rick
    one more question...
    are will the following part numbers work for 1998 tacoma ext 4x4
    not compete headlamp assemblies
    Just lenses and housings
    LH lens and housing 81170-04090
    RH lens and housing 81130-04090
  7. Oct 24, 2017 at 6:17 PM
    nzbrock
    Noah
    San Marcos, TX
    What else do you need? Those part numbers are the headlamp housings. Your bulb inserts into it from the back. You can find a diagram on the parts list that I posted.
  8. Oct 24, 2017 at 6:22 PM
    badaboom
    Rick
    So they are the correct ones?
    I just thought I would verify my ignorance that they are correct
    Appreciate it
