General Added Fuse Panel Questions
Discussion in 'Lighting' started by Perfuseme, Dec 24, 2020.
  1. Dec 24, 2020 at 2:16 PM
    Perfuseme
    Perfuseme [OP] Well-Known Member
    Rick
    I’d like to add a blue sea 6 or 12 fuse block, 100 amp breaker, and probably establish some real-estate for a relay box for future projects like rear lighting. In the short term il be adding some interior ambient and reading light. I will likely use the Paranoid Fabrication or Power Trays, tray for a platform.
    Currently I have the Genesis Off Road dual battery kit with Odyssey 34’s and this all runs to a 3rd Optima Yellow top via 2 guage wire at the passenger firewall (see pics).
    My first question is should I run a set of 4 guage to the circuit breaker and new panel or just tap the 2 guage that’s running to the third battery? I really don’t care to run another heavy guage from the Odyssey battery and don’t really want to cut into the 2 guage either but I think that may be the best option. I was thinking maybe a large fuse that serves as a junction for the 3rd battery and the added breaker/fuse box assembly. If I go this route, what size fuse should I run here or is there another bridge I should be using? Maybe a large buss to continue to 3rd battery and tie new panel from?
  2. Dec 24, 2020 at 9:27 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    few questions,
    1. yea, for sure go with the paranoid bracket lol,
    2. what do you use the 3 batterys for?
    for me, i would wire up the panel to the house battery (depending on what you want to power) i would run new wire for that along with the CB for it.
  3. Dec 24, 2020 at 10:23 PM
    Perfuseme
    Rick
    I see! I expect you may like that bracket!
    long story short,,,,my car barley started at work back in sept-oct so I went straight to Autozone and put the yellow top in, in the parking lot. In the mean time I came across a fair deal on the genesis kit. Not wanting to wait 3-4 years to install I went ahead with the Odyssey 34’s but didn’t want to waste the yellow top.
    As you probably know...the factory fuse box is pushed back a few centimeters to accommodate the new tray....do you think your platform still fits?
  4. Dec 25, 2020 at 8:45 AM
    paranoid56
    San Diego
    14 double cab taco
    hmm, if the fuse box is moved my stock setup wont work, but give me some measurements and we can make you a custom one.
