General Car Audio FAQs
Discussion in 'Audio & Video' started by Mr Marv, Mar 16, 2008.
  1. Apr 4, 2014 at 6:45 PM
    #81
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    Plug the RCA's into the middle set of connectors. Then set the output on the deck to make sure it knows it's a sub out, instead of rear speakers. That way it won't fade when you adjust the fader.
  2. Apr 4, 2014 at 8:29 PM
    #82
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Thanks, I'll try to figure out how to do that.
  3. Aug 11, 2014 at 3:50 AM
    #83
    Harkonnendog
    Harkonnendog Active Member
    Kauai
    11 DC TRDS
    I have the Sound Ordinance mentioned above paired with stock speakers and an Alpine cde--154BT. The alpine allows you to set the equalizer and crossovers with your an iphone app. Awesome right? Well, if you know what you're doing, sure!
    This is my latest setup... Any tips or anything? Am I way off?8emu2e4a_21b3cb68da6c88ab470e607732093cd8230e6f15.jpg
    Equalizery6ebeme8_dfeed8304040e0b87838ac2fa9fbeafc96bf25c7.jpgju8u7ane_3d2ec7df4a82e55e551d758a2d89f9bf7393ac50.jpgaqa9yjuj_2702d64f52aa714f06fcad81168ef3ee7ed6f5fb.jpg
    And crossovers. Any advice would be greatly appreciated!
    I
  4. Aug 11, 2014 at 3:53 AM
    #84
    Harkonnendog
    Kauai
    11 DC TRDS
    Oh and I just want to thank you, generally, Mr Marv, for the time and advice you have given us all. You are very generous.
  5. Aug 28, 2014 at 3:02 AM
    #85
    g35man
    g35man Discount Double Check
    League City, TX
    2012 MGM DC 4x4 OR
    Icon Stage II lift kit, LR uca's, Weather Tech floor mats, FX-R retrofit, Morimoto factory fit LED fogs, flyzeye designs cup holder lights, wet okole seat covers, upgraded Entune system
    Amen!
  6. Aug 28, 2014 at 8:53 AM
    #86
    ZMan2k2
    Richard
    Under a tinfoil hat
    :wave::cheers::yay::thumbsup:
  7. Sep 16, 2014 at 11:49 AM
    #87
    95 taco
    95 taco Battle Born
    Looking at new door speakers for my truck (I wouldn't mind tweeters either as they are built in the upper part of the door) as the stock speakers start to distort at the volume I like for cruising 55 with 2 windows down.
    I have a Sony HU and sound ordnance sub, any speaker and amp suggestions?
  8. Nov 3, 2014 at 7:38 PM
    #88
    808wildboi
    808wildboi Haaaawaiian!!!
    chase
    kailua kona
    2003 Toyota Tacoma DC 4x4
    Hey Marv, how can i get ahold of you? im looking to buy sounds but im not sure what to order.
  9. Nov 8, 2014 at 1:04 PM
    #89
    HighTechRedneck
    HighTechRedneck Member
    Brandon
    VA
    08 PreRunner
    Large GY SilentArmors, Kenwood HU & speakers, Powered Sub, removed mud flaps, still planning.... LED's next
    I just replaced my factory speakers with Kenwood 3-way6x9's in the front and 6.5's in the rear. I've had a Kenwood HU and SO powered sub for a while and finally upgraded the factory speakers. Wish i would have done it a long time ago. I left the factory tweeters installed.
    I would suggest using Crutchfield since they will tell you what fits and they also provide the wiring harness and speaker brackets for free.
    Hamer95USA likes this.
  10. Nov 9, 2014 at 12:54 PM
    #90
    Large
    Large Red
    Anyone know the speaker wire colors for the front doors of a DCSB? Trying to wire wakeboard speakers to my tube doors.
  11. Nov 10, 2014 at 4:49 AM
    #91
    Large
    Large Red
    :tumbleweed:
  12. Nov 10, 2014 at 4:27 PM
    #92
    HighTechRedneck
    Brandon
    VA
    08 PreRunner
    Sorry, I didn't take note of the wire color when I changed out speakers. You should be able to find it on the tweeter when you pull the panel off.
  13. Nov 12, 2014 at 7:45 AM
    #93
    Large
    Large Red
    Driver's side is pink and purple and twisted together, the rest just run side by side. Will update on passenger side when I get the door off.
  14. Nov 12, 2014 at 7:48 AM
    #94
    jflames05
    jflames05 Active Member
    James
    Greenville
    Silver 05 SR5 4x4 Lifted
    3" Toyo Tech Lift, 33x12.50 Toyo Open Country Mud Terrains on 18x9 Gear Double Pump, AFE Cold Air Intake System, Flow Master 40 Series Dual Exhast, Knaack Toolbox, Custom Tint/Graphics, Custom 5th Wheel Rails/Gooseneck Hitch, Rear View Camera, JBL Speaker System
    2012 Toyota Tacoma Stereo Wiring Information
    Radio Battery Constant 12V+ Wire: Light Blue
    Radio Accessory Switched 12V+ Wire: Gray
    Radio Ground Wire: Brown
    Radio Illumination Wire: Green
    Left Front Speaker Positive Wire (+): Pink
    Left Front Speaker Negative Wire (-): Violet
    Right Front Speaker Positive Wire (+): Light Green
    Right Front Speaker Negative Wire (-): Blue
  15. Jan 5, 2015 at 10:09 AM
    #95
    Jayne
    Jayne Well-Known Member
    Dave
    Utah
    Silver 4x4
    Quick question, my 2011 4x4 double cab has the factory head unit. It paired with my phone for making calls, but will not play audio (Pandora, etc). When I press the aux/CD button, it only goes to the CD's. Does the bluetooth support audio? My phone says it's paired.
    thanks!
  16. Jan 5, 2015 at 10:37 AM
    #96
    ike3000
    ike3000 Well-Known Member
    does your radio have a separate source input for bluetooth? i know my 2013 factory radio treated bluetooth as an input separate from CDs.
  17. Jan 5, 2015 at 11:21 AM
    #97
    Jayne
    Dave
    Utah
    Silver 4x4
    There's not a button for Bluetooth, no. There is an aux jack below, by the 12V.. But I was hoping that pairing meant for phone and music.
  18. Feb 26, 2015 at 9:44 PM
    #98
    Beatlejuice
    Beatlejuice Used To Have A Dakota, Now I got A Tacoma
    Andy
    SoCal
    14 PreRunner Longbed
    Should my Marv sub cabinet be bolted to the back wall, or just left "floating behind the seat?
  19. Feb 28, 2015 at 10:37 AM
    #99
    JPC
    JPC Well-Known Member
    JPC
    Highlands Ranch, CO.
    2011 DC SB TRD 4X4
    5100s front & rear, 2"AAL, KMC XD wheels, Hecuules Tera Trac AT II 265/65/17 tires, ARE Color Matched Topper, Thule Roof Rack, Alpine INE-W940
    Is anyone else running the Alpine INE-W940 indash GPS & Bluetooth and if so do you know how hard is it to switch the rear camera output from the rearview mirror to the deck?
  20. Feb 28, 2015 at 4:41 PM
    #100
    mikerm
    mikerm Well-Known Member
    Grand Rapids, MI
    2011 4x4 DCSB TRD
    Nope.
    Which is one of the MANY reasons I am (hopefully) replacing my HU tomorrow. This radio is hugely disappointing. It can't even download my address book from my phone. I've seen HU's from 2011 and earlier that could. I've also seen them able to play music through BT. This HU is about as basic as you can get.
    Although the phone ringing at ear bleeding full volume is a real treat. People have complained about the sound quality from the mic too.
    Sure, it sounds good (I have the JBL system), but man, no thanks. It's also been acting up lately, so it's time.
