General Discussion and BS thread -Safe Haven
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lord Helmet, Jan 16, 2015.
  1. Oct 27, 2015 at 5:40 AM
    #4161
    BAMA-256
    BAMA-256 Well-Known Member
    Rex
    Huntsville Alabama
    2017 SR 4x4 5 speed manual Past-2016 TRD Offroad 4x4
    "Although a less sophisticated four-wheel-drive system is offered for the other trim packages (all models use the same transfer case with the 2.57:1 low range), the TRD Off Road uses a Multi-Terrain Select system that allows the driver to select rocks, mud, snow or sand to allow the 4x4 computer to change gears, transmission shift points, traction control parameters, and even throttle and brake inputs. The Off Road trim also includes a bigger, heavier-duty rear axle — an 8.75-inch ring gear instead of the normal 8-inch axle."
    This is from one of the reviews of the truck
  2. Oct 27, 2015 at 7:43 AM
    #4162
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    Well, it is pretty darn tacky...what ever it is. No wonder every reincarnation of the Toyota pickup gets worse and worse...
  3. Oct 27, 2015 at 8:06 AM
    #4163
    ROAD DAWG
    ROAD DAWG Well-Known Member
    birmingham,al
    10 trd prerunner
    debadged,procomp 7105 wheels,,kc slimlites,n-fab light bar,predator step bars,baja roof rack and light cage,hella 500 black magic,5100's(f/r) @.85,tsb rear,nitto terra grapplers(265-65-17)
    now that's some badassery right there.
  4. Oct 27, 2015 at 2:27 PM
    #4164
    WaldoJPL
    WaldoJPL Well-Known Member
    Bill
    ...looking to buy....
    ...OK...not too sure just where to post this....so apologies if I hit it wrong....but:
    ...My question has to do with the SS exhaust tip...is this mainly just for looks?...:confused:
    ....reason I ask is it slips over the original tip...which is just steel....so wont moisture get trapped between the two and rust out the original tip faster than without it?....o_O...
  5. Oct 27, 2015 at 2:35 PM
    #4165
    WaldoJPL
    Bill
    ...Thanks, OuTkAsT!.....I live in SoCal presently.....so rain and moisture are rare around here....but we can only hope El-Nino brings us some desperately needed rain this winter to help end the really bad drought....
    ..and, of course...once that happens....it could rust?...o_O............Cheers!......
    0uTkAsT likes this.
  6. Oct 27, 2015 at 2:41 PM
    #4166
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    i wonder if he gets better mileage with that upgraded intake...would this be a deck plate mod?
    devinzz1 likes this.
  7. Oct 27, 2015 at 2:46 PM
    #4167
    WaldoJPL
    Bill
    ...Nah...I am inland...almost to the edge of the Mojave.....But don't get too complacent out there in AZ.....o_O
    ...Once the BIG-One hits CA, and it breaks off...Phoenix will become ocean-front property...and you will have to worry about rust!...:eek:.....LOL!.....Cheers!.........
    ...( so...buy up cheap desert land NOW! ).....:thumbsup:...
  8. Oct 28, 2015 at 6:07 AM
    #4168
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    Its going to rust anyway. Whether that SS tip is on there or not. UNLESS of course, the whole tube is made out of SS.
  9. Oct 28, 2015 at 6:25 AM
    #4169
    radchris88
    radchris88 Well-Known Member
    Christian
    NY
    2016 Tacoma TRD Off-Road MGM DCLB
    Here in upstate NY, it doesn't even matter if it's stainless steel. All rust warranties are voided up here because of the weather and the crap they put down on the roads. If it isn't the tube rusting out, it's the welds.
    ZachMX likes this.
  10. Oct 28, 2015 at 6:43 AM
    #4170
    Roll Tide
    Q
    01 T4R
    They put that shit in meat too. Causes cancer.
  11. Oct 28, 2015 at 6:43 AM
    #4171
    Roll Tide
    Q
    01 T4R
    Aww...dammit, my tin foil is alllllll the way at home....probably rusting...
  12. Oct 28, 2015 at 11:58 AM
    #4172
    Kingair84
    Kingair84 Well-Known Member
    Wisconsin
    2016 Double Cab TRD Off Road 6 speed MT
    Rad Industries skid plate, trd pro grill, rigid DOT Fogs
    I love it!!! When my truck comes I'll be buying one. I have 2 questions. How are the lights attached behind the grill and could you do a light bar and the words Toyota. Depending on if it looks ok or not. Thanks!
  13. Oct 28, 2015 at 12:09 PM
    #4173
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Looks like DB found another taco to mess with. What do you think?
  14. Oct 28, 2015 at 12:11 PM
    #4174
    SMKYTXN
    Nathan
    Houston
    DCFB
    There are tabs behind the cutouts that accept the bolts on the cubes. The same goes for the lightbar version.
    Speaking of the lightbar version, here it is in the flesh before powder coat. As far as letters above the bar? That's certainly possible.
  15. Oct 28, 2015 at 12:12 PM
    #4175
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    SMKYTXN[QUOTED] likes this.
  16. Oct 28, 2015 at 1:58 PM
    #4176
    Kingair84
    Wisconsin
    Sweet! I like it! Could you lay some letters over it when you are done painting I'd like to get a feel of what it would look like. I really like the look so far thanks for building something to replace that ugly stock grill. I like the mesh pattern as is but do you also do others? Just out of curiosity.
  17. Oct 28, 2015 at 2:30 PM
    #4177
    SMKYTXN
    Nathan
    Houston
    DCFB
    I'll ask DB to lay the letters over the top for reference when this one comes out of the oven.
    Yes, this is the only pattern available. If you didn't know already; the pattern is cut out of a single piece of plate on a waterjet.
    -Nathan
  18. Oct 28, 2015 at 2:33 PM
    #4178
    Kingair84
    Wisconsin
    Ah gotcha. Even stronger then a mesh. Great idea.
  19. Oct 29, 2015 at 8:46 AM
    #4179
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    2 days old. Taken from Luis Segundo Romo's FB post on the TW Facebook page.
  20. Oct 29, 2015 at 8:46 AM
    #4180
    99TacoDriver
    South Louisiana
