General Grabbers
Discussion in 'Wheels & Tires' started by pLon, Dec 14, 2011.
  1. Dec 14, 2011 at 1:46 PM
    pLon
    pLon [OP] Well-Known Member
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    Hi you all, my pickup will need tires soon, and I was thinking about the General Grabbers (red letters), I wanted to run 285/75/16 (I've read those are backordered everywhere) or 310/75/16 on stock TRD off-road rims, also I will have this weekend installed the glassworks fenders/bedsides I believe those are 4" or 4.5" flare, and also I've ordered 4 spidertrax hub-centric spacers 1.25" I think, would I be able to fit those tires with the stock height of my truck?
    Thanks in advance :)
  2. Dec 16, 2011 at 10:32 AM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    Bump :/
  3. Dec 16, 2011 at 10:38 AM
    sprocketdog
    sprocketdog Well-Known Member
    Halifax Pa
    05 Taco 96 Taco 06 TSX 94 extra cab Hilux
    DR coilovers, Camburg UCAs, Dakar rear springs, Bilstien 5150s, Demello sliders, rear plate bumper w/ swing gate, and alot more mods. [IMG]http://i1216.photobucket.com/albums/dd368/sprocketdog1/059.jpg[/IMG]
    I dont know if that will be possible I am ruuning the same exact tires with 16" rims and with my 3" kit the wheel well is stuffed pretty good. You will run into many problems with the inner fender and the frame mount as well.
  4. Dec 16, 2011 at 11:30 AM
    sprocketdog
    Halifax Pa
    Here is a link tcBob has put up.
    http://www.tacomaworld.com/forum/wheels-tires/67550-largest-tire-sizes-stock-suspension.html
  5. Dec 16, 2011 at 11:33 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Even with the glass there's just no way you could fit the 315s on there. Those are 35's. People rub a little with those even on 6" lifts.
  6. Dec 16, 2011 at 11:35 AM
    sprocketdog
    Halifax Pa
    As well as the 285s
  7. Dec 16, 2011 at 1:27 PM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    So I should wait until I have my Tacoma lifted and go with a smaller tire for now?
    I'm going to have TC long travel in front and leaf-over-spring on the back (I don't know what brand yet), but this will be until mid 2012 I think, will this solve any issues with the 285's?
  8. Dec 16, 2011 at 1:29 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    do not go 35s on a 3 inch unless your very handy with a grinder, welder, and a plasma cutter.
  9. Dec 16, 2011 at 1:43 PM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    But 285's are like 33 right?
    Also remember I will have installed spidertrax spacers 1.25" and I thought the 265, 285, 310 was all about the tire width not the height, correct me if I'm wrong please :confused:
  10. Dec 16, 2011 at 1:45 PM
    TexasTacoma37
    the 265 vs 285 is the width, in MM. Most common 285's are also 33" in diamater, and most 265's are 32's or 31's, so the terms are often used interchangeably.
  11. Dec 16, 2011 at 2:08 PM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    so a tire 265/75/16 have the same height than a 285/75/16 and a 310/75/16 just a bit wider, my question is if a standard Tacoma can fit a 265/75/16 why can't I use a 285/75/16 if I have 1.25" spacers, what's the other restrictions?
    20mm extra wider would be just 0.7874015748031497 inches, per calculations those 285 should fit perfectly, the 310 is a different story that would be 1.7716535433070868 inches extras in width than the 265's
  12. Dec 16, 2011 at 2:13 PM
    sprocketdog
    Halifax Pa
    http://www.tacomaworld.com/forum/tirecalc.php
    This link will help out with the metric tire sizes.
  13. Dec 16, 2011 at 2:23 PM
    TexasTacoma37
    The second number is the sidewall height expressed as percentage of the the width. So a 315/75 (no such thing as a 310) is way taller than a 265/75, in addition to being much wider.
  14. Dec 16, 2011 at 2:31 PM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    Ohhh got it now, I though it was width (265,285,315,etc) height (65,70,75,etc) and rim size, my bad, thank you for the clarification :D
  15. Dec 16, 2011 at 2:38 PM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    so I have this
    tire height
    265/75/16 198.75
    285/75/16 213.75
    315/75/16 236.25
    are those heights in millimeters also?
    doesn't seems as much difference
  16. Dec 16, 2011 at 2:40 PM
    TexasTacoma37
    They are the height of the sidewall. So that number, times 2, plus the diameter of the wheel, will be the tire diameter.
    The tires you have listed have diameters just under 32", 33", and 35", respectively.
  17. Dec 16, 2011 at 2:41 PM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    Those numbers you have are the sidewall height in mm. You need to multiply this by two and add the wheel diameter to get the overall tire diameter. Or just use the calculator which does it all for you.
    Edit: KPT beat me to it :)
  18. Dec 16, 2011 at 2:45 PM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    right... once again :eek: thanks for that
    so that would be
    265/75/16 ---> 803.9mm
    285/75/16 ---> 833.9mm
    315/75/16 ---> 878.9mm
    thnx to you too Dustyroades :)
  19. Dec 16, 2011 at 2:46 PM
    TexasTacoma37
    Yes, but sizes can vary by a few mm depending on the manufacturer. You can check their websites for the actual measurements of any of their tires.
  20. Dec 16, 2011 at 2:52 PM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    so width issue is covered by the spacers easily (0.787" vs 1.25"), the difference between the 265 and 285 in height is 30mm or 1.18" plus or minus, that wouldn't be cleared with the fiberglass fenders? also I'll have to remove the inner fender right? so that's another problem I won't have anymore, sorry if I ask too much :p
