General Grabbers
Discussion in 'Wheels & Tires' started by pLon, Dec 14, 2011.
  1. Dec 16, 2011 at 2:55 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Yeah I really don't know if the new fenders will give you enough clearance without a lift. Maybe someone else can chime in.
  2. Dec 16, 2011 at 2:58 PM
    pLon
    pLon [OP] Well-Known Member
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    Let's see if someone else can answer, anyway thanks a lot man, I had another idea on how tires where measured before :)
  3. Dec 17, 2011 at 1:15 AM
    Tacovette
    Tacovette NUB
    Eddie
    San Diego, CA
    06 4x4 DBL CAB V6
    3" lift Volant intake w/ram air scoop DC1 Wheels BF AT 33's Grillcraft Grille Satoshi Grille (I get bored) Xeon Headlights LED Tail lights Custom rock guard/step De-badged ARB bumper w/fogs Rotors cross drilled Braided brake lines Wet Okole covers Stereo stuff
    They will be on back order for a while. I just got my refund from 4WP.
    Response Via Email (Renae)12/16/2011 09:44 AM Dear Edward,
    [Web Inquiry: 111215-000012]
    Thank you for your interest in the General Grabber AT2. Unfortunately, demand has exceeded our expectation, and it will take several months for production to reach your local General Tire dealer.
    Sincerely,
    Continental Tire the Americas, LLC
    Customer Relations
  4. Dec 17, 2011 at 1:24 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
  5. Dec 17, 2011 at 1:27 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    the wheel spacers will only make you rib more, because it puts your tire out father from where you turn at, so when youbturn your tire travles more distance to turn aka will rib more.
    if you want ill take pics of a 3 inch life with my 33s to show what i did and how bad it still rubs with no spacers, 3x12.5x15s
  6. Dec 17, 2011 at 7:55 AM
    TexasTacoma37
    He wants the grabber red letters, not the at2
    That's true if you push them out too far, like some folks do by running wheel spacers on aftermarket rims. A lot of the time though running wheel spacers on stock rims decreases rub by moving the tire further from the uca and cab mounts, but not so far out that it hits the fender on the outside. There's a sweet spot in there with minimal rubbing (at least with 285s, 12.5's maybe be a different story)
  7. Dec 17, 2011 at 4:04 PM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    I would really appreciate if you could take some pictures of your tires, and yes what you are saying makes sense, by extending the wheel to the outside the turning radius will become bigger so the travel will be longer, I don't mind to trim a little bit but I don't know how much is needed and where, please post your pics :)
  8. Dec 19, 2011 at 10:26 PM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    So the red letters aren't in backorder? :)
