General maintenance?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cgutierr, Nov 30, 2009.
  1. Nov 30, 2009 at 1:29 PM
    cgutierr
    cgutierr [OP] Active Member
    My truck has almost 100,000 miles. I change my oil and filter every 4000 miles and have changed the tranny fluid every 30,000. What other maintance should I do? Trying to stay proactive not reactive.
  2. Nov 30, 2009 at 1:35 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
  3. Nov 30, 2009 at 2:20 PM
    MMOCGuy
    MMOCGuy Active Member
    Norm
    N. California
    09 Tacoma 4wd
    If you have a 4wd, you should also change transfer case oil at the same interval as your transmission oil changes. You should also change the differential oil at the same interval if you have limited slip differential and/or 4wd.
    Hope this helps.
    Norm.
