General Question
Discussion in 'General Tacoma Talk' started by Skubbasteve, Sep 19, 2023.
  1. Sep 19, 2023 at 2:40 AM
    Skubbasteve
    Skubbasteve [OP] Member
    2012 Super White Tacoma 2WD
    Hello I have a question for anyone. As I press the break down to stop my Tacoma I’ve noticed that I hear a “ Click “ sound. But once I get moving it’s smooth sailing.
  2. Sep 19, 2023 at 3:49 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Someone might have a clearer answer but it sounds like abs or traction control. That's normal.
    Sometimes the lower shock bolt or swaybar links can cause a click if loose or worn but that's typically going over bumps.
  3. Sep 19, 2023 at 9:40 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Welcome to the Forum!!
    Noises can be so tricky !
    It could be as simple as a loud brake light switch. Something loose in the brake pedal linkage.
    Some many things it might be.
  4. Sep 19, 2023 at 10:18 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    So many things indeed but isn't it fun trying to help figure out clinks, clanks, bumps, thuds and vibes? heh
  5. Sep 19, 2023 at 10:34 AM
    Bivouac
    only in person for me.
    One persons loud noise I never even notice.
    bkhlrTaco's[QUOTED] likes this.
  6. Sep 19, 2023 at 10:52 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you just hear one click/tink when you stop after changing directions or stop after driving awhile your likely hearing the front brake pads shifting on the pins, it's pretty common with the front caliper design as the pads have a slight bit of movement on the pins that hold them in place.
    Mine has done it since it had about 15 k on it, I don't worry about it although some people have tried various ways of keeping them quiet.
    The most common one seems to be adding a second spring clip to them.
  7. Sep 21, 2023 at 12:15 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Brake pad slap sir.
  8. Sep 21, 2023 at 2:21 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    First remove all loose objects from your truck after taking pictures to document exactly how they are filled ... glove box, seat bins, armrest console, pockets in the bed.
    If the noise is gone after, start adding back one storage-site at a time.
    I have stored ... oh ... one or two things and can hear a noise on braking or on acceleration.
  9. Oct 1, 2023 at 5:28 AM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    It’s called brake pad slap and happens because of the design of the brake calipers, almost every Tacoma gets it at some point. It is annoying but harmless :thumbsup:
