General Questions on Installation of Amp with Aftermarket Head Unit
Discussion in 'Audio & Video' started by Tarvis, Dec 27, 2019.
  1. Dec 27, 2019 at 6:29 AM
    Tarvis
    Tarvis [OP] Well-Known Member
    Travis
    Bel Air, Maryland
    2018 Metallic Gray SR5 Double Cab
    Hello TW. Just got a Alpine KTA 450 Power Pack Amp as a Christmas gift, and looking to install it with my existing Alpine ILX W650 head unit. I have it all plugged up (I thought) but I don't think it is even turned on or powered...And I think I am missing something. Here is what I have.
    • Amp RCA Cables plugged up to the corresponding RCA cables on the head unit.
    • Ground => Truck Ground (Shared with Head unit)
    • Remote Trigger => Remote Trigger. After reading, I think I have this wired backwards. I think I need to wire it attaching the remote trigger of the HU to the Amp instead of the remote trigger from the truck.
    That seems like it should be everything I need... I was told I wouldn't need to run a dedicated power wire since the truck has a 20A fuse for the audio, which exceeds the 15A recommended for the Amp / HU combo. I'm just not understanding where the amp gets power from then. Do I need to use the power wire on the amp?
  2. Dec 27, 2019 at 6:55 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    The yellow power from the amp needs to tie in with the yellow from the alpine radio.
    The blue/white remote turn on (on the side with the RCA connectors) needs to go to the blue/white in the alpine radio harness.
  3. Dec 27, 2019 at 7:01 AM
    Tarvis
    Travis
    Bel Air, Maryland
    Okay so there is going to be one power line coming into the area behind the HU that splits into two? One power line going into amp and one to the head unit? There is no issue with splitting one power line off to two separate components? Sorry total wiring noob.
    I think you just confirmed what I was thinking. The remote turn on runs between the amp and HU. So I have that wired wrong and need to correct it.
    Thank you so much for the help.
  4. Dec 27, 2019 at 7:05 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    yes, the wire your radio yellow is connected to is where the amp yellow needs to go.
    and like i said, make sure to use the blue/white on the amp coming from the small connector with the RCA cables, NOT the one on the other side with the speaker output wires
  5. Dec 27, 2019 at 7:12 AM
    Tarvis
    Travis
    Bel Air, Maryland
    All clear on the power wire. Still a little unsure on what you mean with the blue w/ white stripe. There is only 1 blue w/ white stripe on the amp, and it looks to match colors with the blue w/ white stripe on the HU which says "Remote wire"
  6. Dec 27, 2019 at 7:16 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    OH my bad! I was picturing the standard alpine power pack and not the new one that mounts on the w650. So yeah, only 1 blue/white and it will go with the radio's blue/white
  7. Dec 27, 2019 at 7:17 AM
    Tarvis
    Travis
    Bel Air, Maryland
    Hahah okay great. Everything else you told me is still correct though, right?
  8. Dec 27, 2019 at 7:18 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Yep. Yellow's still go together
    And just cap off the radio's speaker wires. They will still be outputting power even though we aren't using them so you don't want any shorts to happen.
  9. Dec 27, 2019 at 7:21 AM
    Tarvis
    Travis
    Bel Air, Maryland
    The head unit's speaker wires are already hooked up since I haven't had an amp wired up yet. Did you mean cap off the amp's speaker wires since I'm not hooking them up? I was under the impression that if I went the AMP RCA to HU RCA that I could keep the head unit speaker wires connected.
  10. Dec 27, 2019 at 7:25 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Nope. The RCA cables carry the audio signal from the radio to the amp. Then the new powerful audio signal is sent out through the amp's speaker wires. So the radio's speaker wires need to be disconnected from the existing wiring, and be replaced by the amp's speaker wires.
  11. Dec 27, 2019 at 7:26 AM
    Tarvis
    Travis
    Bel Air, Maryland
    This is completely the opposite of what Crutchfield told me... I am officially confused.
  12. Dec 27, 2019 at 7:27 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I was looking at that same combo, isn't it just plug and play? I thought is was designed to connect easy.
  13. Dec 27, 2019 at 7:27 AM
    Tarvis
    Travis
    Bel Air, Maryland
    I thought so too... but its getting more and more complicated lol.
  14. Dec 27, 2019 at 7:28 AM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    Did crutchfield send you pre made harnesses?
  15. Dec 27, 2019 at 7:29 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    post up a pic of everything you have if you can.
    alpine makes a plug-and-play harness for this amp/radio combo, but it doesnt sound like you have it
  16. Dec 27, 2019 at 7:29 AM
    Tarvis
    Travis
    Bel Air, Maryland
    With the head unit, not the amp. I am adding the amp after already having the head unit.
  17. Dec 27, 2019 at 7:30 AM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    Good luck! Hope you get it figured out. Can always call crutchfield tech help
  18. Dec 27, 2019 at 7:31 AM
    Tarvis
    Travis
    Bel Air, Maryland
    I tried. They told me I only needed to hook up the RCA cables, ground, and remote wire. Apparently that was very wrong.
  19. Dec 27, 2019 at 7:32 AM
    Tarvis
    Travis
    Bel Air, Maryland
    I am at work right now so I can't take pics. Not sure that would be helpful though, its starting to look like a rat's nest of cables from trying to figure this out lol.
  20. Dec 27, 2019 at 7:34 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    I would pull everything out and lay it out on the table. This is not going to be something you can easily do while its all still connected in the truck. Unless you have some additional wiring I'm not aware of, there is going to be cutting and crimping/splicing involved.
