General Questions on Installation of Amp with Aftermarket Head Unit
Discussion in 'Audio & Video' started by Tarvis, Dec 27, 2019.
  1. Dec 27, 2019 at 8:02 AM
    Tarvis
    Tarvis [OP] Well-Known Member
    Travis
    Bel Air, Maryland
    2018 Metallic Gray SR5 Double Cab
    Just called Crutchfield again. The guy I got today seemed much more knowledgeable than yesterday. He had my call log from the last call and basically told me that the last guy was an idiot.
    New guy told me exactly what you said. Cut the speaker wires out from the head unit, cap them. Splice the amp speaker wires into the existing door speaker wires. Power to power, ground to ground.
    Should have it all figured out now. Will probably get to re-wiring on Saturday.
  2. Dec 27, 2019 at 8:09 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    glad they got you back on track lol
  3. Jan 20, 2021 at 7:48 PM
    Raiderromo37
    Raiderromo37 New Member
    Raul
    Ford Ranger
    None
    So i do installations for a living and have recently done 3 of these systems
    First hook up the RCAS from the amp i to the radios front and rear inputs
    Second connect the remote wire from the stereo (i think it has like a double connector) so you can add a second amp.
    third run the ground cable to a piece of metal and not the stereo ground.
    Forth is run the yellow wire to the battery ( not the stereo power). This is an amp and requires 15 amps by itself. The stereo uses 10amps alone. Make sure to fuse this yellow wire at the battery. This wire is 12gauge ( crutchfield usually will give you some sort of amp kit with the purchase. My customers have all gotten one with there purchase.
    If you have the radio currently wired to the speakers in the car, you will need to disconnect it from there. you will cap the leads from the stereo( since you will be using the amps power now).
    next connect the outputs ( speaker wires coming out of the amp and wire those to the cars speakers. Make sure to read the crossover adjustments. They can be alittle confusing, because some are upside down. alpine could have just made it an on and off to make it easy, but since this amp can be used in many ways, they complicated it. Of you are not going to run a subwoofer, then you need to figure out the switches that will make it be in full range only. Also it might have dual inputs ( I can’t remember). But you want front and rear input to the amp. Has something to do with switch 5 & 6
    If you have any questions take a pic of the switches on the side of the amp and also the instructions and i can walk you through the rest. Good luck
  4. Jan 21, 2021 at 9:59 AM
    GRNT4R
    GRNT4R Well-Known Member
    NC - Triad
    2010 TRD Sport DCLB 4WD Silver
    TBD
    My bad, seen this is an old post
    Let us know how this sounds when you are done. Are you using factory speakers?
  5. Mar 26, 2023 at 12:30 PM
    Iceman77
    Iceman77 New Member
    Has anyone have a diagram for the kta 450 to be wired up to the ilx w650? I have a harness kit from crutchfield. I just need to add the amp since everything has been installed already.
