General use recovery kit
Discussion in 'Recovery' started by Wand3r, Apr 15, 2019.
  1. Apr 15, 2019 at 9:07 AM
    Wand3r
    Wand3r [OP] Well-Known Member
    Sean
    2018 Tacoma TRD Sport
    Without climbing rocks or jumping into mud puddles, what's actually needed for a basic recovery setup?
    I've been looking at all the gear as a few main kits:
    • Basic recovery - traction boards, shovel, etc.
    • On-board air - for traction or flat tires
    • Assisted recovery kit - added recovery points, snatch strap, etc.
    • Bottle jack kit
    • Hi-lift kit - plus bumpers and/or sliders, maybe winch kit
    • Winch setup
    I'm planning on traveling & camping, often just a single vehicle, maybe hit some gravel roads or snowy conditions. Not planning on getting crazy but I know people get stuck all the time (living in Minnesota).
    Which gear is actually necessary to deal with the general unexpected and stay safe? Avoiding breaking the bank, transforming the truck and carrying way too much. Any minimalist recovery experts out there?
  2. Apr 15, 2019 at 9:09 AM
    Shellshock
    Iowa
    Here's what I run with:
    4x maxtrax
    shovel
    ARB Compressor
    ARB tire repair kit
    Hitch recovery shackle
    I've been all over the country solo and it's been more than sufficient.
    uploadadventure and whatstcp like this.
  3. Apr 15, 2019 at 9:12 AM
    Wand3r
    Sean
    ARB Tire repair kit, ever used it?
    I've never seen a tire repaired without taking it off the rim.
  4. Apr 15, 2019 at 9:28 AM
    Shellshock
    Iowa
    yep I've used it. it works pretty well actually. you'd still want to get a proper patch when you get back to civilization but it'll definitely get you back home and then some if necessary.
    this is pretty much the process.
  5. Apr 15, 2019 at 9:31 AM
    Shellshock
    Iowa
    Forgot to mention that one. I also have a Garmin Inreach and a HAM radio. When you need help, you definitely aren't going to have cell phone coverage.
    A basic first aid kid is also good to have.
    whatstcp[QUOTED] likes this.
  6. Apr 15, 2019 at 9:54 AM
    Tigerian
    Tigerian Well-Known Member
    Iowa, unfortunately
    2024 GR Corolla
    If you get stuck in Minnesota is mostly because you were doing something dumb, weren’t equipped to do, or both. A nice set of tires, maxtraxx, and common sense will get you a long way. The only time I’ve been stuck up here was because I forgot to even think about the possibility of getting stuck, what I would do, and if I should just turn around.
    whatstcp likes this.
  7. Apr 15, 2019 at 9:59 AM
    Wand3r
    Sean
    Funny, I think that covers most situations.
  8. Apr 15, 2019 at 10:27 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Sounds like you have most of the basics thought of. Allow me to add some food for thought.
    Traction boards, shovel, maybe axe or bowsaw depending on the area
    Air deflator/Compressor of some sort
    Snatch strap ...and proper knowledge of where and how to use it
    Jack that works with your vehicle (lifted truck or bogged truck may not be able to use OEM jack)
    Hi-lift/winch if applicable - (look into how to construct a "flip flop" winch as an added bonus tool for your mental toolbox)
    winch accessories - snatch block, tree strap, etc for added winch factor
    Comms - Cell phone, SPOT/Inreach, HAM or other radio service
    Signal - VS Panel, mirror
    ALSO, a good first aid kit. One slipup with a hilift, bad day with a winch or snatch strap, etc and you may need one.
  9. Apr 15, 2019 at 10:35 AM
    Shellshock
    Iowa
    A slip up with a hilift, winch or snatch strap only requiring a first aid kit and not a helicopter ride would be a good day lol
    Dmela13, uploadadventure and Tigerian like this.
  10. Apr 15, 2019 at 10:39 AM
    Gunshot-6A
    Conner
    Everett, WA
    Well, true. But it is hard to pack a helicopter in your truck, so you could at least triage and stabilize while waiting #shortbedproblems :rofl:
  11. Apr 16, 2019 at 3:16 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Truly "Basic" would be a shovel, a folding saw, a recovery strap and a friend with another 4x4. Use the stock front tow hook, and if you have a rear hitch, stick a trailer pin in there and hook the strap to that. That's yer basic recovery kit.
    Then there are the things that I keep even in my wife's car: first aid, emergency blanket, water, etc... that's more of "safety" gear, not recovery gear tho.
    Anything after that is really just a "convenience". It's amazing how resourceful you get when you need to, lol... To illustrate the opposite of this, I once saw a pic (on this forum, actually) of a 3rd gen stranded and abandoned on a not very technical trail. Only thing I could see was a flat tire - no leaky fluids, nothing. Dude apparently couldn't change a flat tire. :anonymous: Don't be that guy.
    You don't "need" coms, a hi-lift, a winch or traction boards. Just tell someone where you're going and when to start looking for you, your stock jack actually works in a lot more situations than you'd think, and as long as you have a shovel and that friend with a 4x4, you don't "need" traction boards or a winch, either.
    Don't bother getting a hi-lift if you still have stock bumpers, lol
  12. Apr 16, 2019 at 3:44 PM
    DayTripper85
    DayTripper85 Well-Known Member
    2005 Tacoma DCSB Off Road
    Dustrude 30" Buck Saw
    Fiskars 28" Chopping axe
    Army issue E-Tool
    Snatch strap
    Tire plug kit with a T-handle tool
    Tiny Air compressor
    Fixed blade Knife
    Leatherman Rebar
    Duct Tape
    Zip-ties
    I've only truly been stuck once, and I was in a clay pit that looked like a dry road bed crossing over an artisian well. The truck sat down on the frame (89' Toyota 4x4 with buckshot mudders). I dug down past the tires and it never dried out. I was pulled out by a cousin a few miles up the trail. I was lucky he was Turkey hunting or it would have been a long walk back to pop's tractor.
  13. Apr 16, 2019 at 4:04 PM
    Wand3r
    Sean
    Thanks for the tips guys
  14. Apr 20, 2019 at 1:02 PM
    Meaty
    Meaty Well-Known Member
    Nate
    2019 SR dcsb 4x4
    Just make sure if you do have something you know how to use it. Dont wait until youre stuck to learn how a hi-lift works
  15. Apr 23, 2019 at 11:28 AM
    itzWicks
    itzWicks Active Member
    Bryan
    Southwest Oklahoma USA
    2019 Silver Tacoma TRD Off-Road 4X4 DCSB
    Absolutely THIS. And this sage advice is applicable to all tools and specialty gear.
    Hamer95USA and Wand3r[OP] like this.
  16. Apr 23, 2019 at 3:03 PM
    jbrandt
    Justin
    +1000
    I can imagine someone reading online about needing to take spare CV joints with you, but it's also good to know how to change them, lol
    The more you work on your truck replacing and upgrading parts, the more intuitive this becomes, but it doesn't hurt to do some basic repairs with the set of tools you take on your rig. Even something as simple as changing a tire. If you're the type that always uses an impact driver at home, you may end up not having the proper lug wrench. oops!
    If you find out you don't have a particular tool in your bag that you need to replace, say the CVs, go buy one! Even if you have that tool at home, it pays to have a completely separate set of tools for the trail. I've certainly "lost" a few tools here and there trying to keep straight which of my tools are where (shop or truck). And inevitably, you forget to pack a certain tool before heading to the trail.
  17. Jul 18, 2019 at 7:55 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I will add that the best tool is the one between your ears. Know your gear, how to use it and most importantly don't put yourself into a situation that is beyond whatever gear you have. The minimum is always based on what you plan on doing. If you have not planned for it don't do it. Additional advice after reading original post a second time. Since you said a single vehicle don't forget about supplies for an extended stay as well as gear for possibly leaving the vehicle and hiking out.
  18. Jul 18, 2019 at 8:01 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    2 shackles and a strap lol that's all I keep in the truck 24/7. If i go to the beach or something them i put my winch on but that's all i have ever used
  19. Jul 20, 2019 at 8:07 AM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    My basic kit that is usually in the truck:
    Tire repair kit
    Compressor
    ARB deflator
    TREDs x4 (traction boards)
    Snatch strap + necessary rigging
    Shovel
    I took out the high lift. It’s heavy and I’ve never used it. I don’t seek out the most difficult route so I’m doing without.
