Generating smoke during high revs/pulling heavy shit
Discussion in '1st Gen. Tacomas (1995-2004)' started by ztwatson, Jul 27, 2023.
  1. Jul 27, 2023 at 6:32 PM
    ztwatson
    ztwatson [OP] Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Hey guys. So I've had an instance of generating a bunch of smoke rapidly while using my truck in the yard. One time I was getting close to the edge of a cliff and revved up good to get out of there. Today I was trying to pull a post and had it happen again. At the time I can't see where it comes from. I get the impression its from underneath the truck and not necessarily the exhaust but idk in the moment. It smells a bit like burning plastic or something like that. Doesn't exactly smell like what I know my leaking valve covers smells like. Coolant level is stable and color of coolant is pink. Where could this be coming from? I feel like the scent means it can't be condensation in the exhaust. The scent lingers a bit too. Pretty sure this has only occurred in 4WD.
    HondaGM likes this.
  2. Jul 27, 2023 at 7:15 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Is the back end of the truck really squatting low?
    Look for rub Marks above the rear tires might just be enough contact to burn what ever is above there.
    An idea.
    HondaGM and ztwatson[QUOTED][OP] like this.
  3. Jul 27, 2023 at 7:28 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is your truck a manual?
    Maybe the clutch is slipping?
    vern650 and HondaGM like this.
  4. Jul 27, 2023 at 8:19 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    If you revved up good, sounds like you have a clutch, and sounds like it could be getting burned up using high rpm’s to get no wheel spin. It’s a 4wd, are you using 4lo? If you see smoke and it’s your clutch, yikes.
    If it’s an auto, still need to use 4lo. I’d pull your automatic transmission dipstick to check your atf fluid to see if it smells burnt. Can’t really explain the smoke
    edit, meant to say pull the dipstick to check the fluid, not advising you pull the transmission.
  5. Jul 27, 2023 at 8:57 PM
    ztwatson
    Milwaukee, WI
    It is a manual. I was in 4Hi when this happened. Didn't feel like I was really pushing the truck in the moment. I don't think the rpms ever got past 2.0-2.5k before this happened. Tough to recall exactly how everything occurred. Definitely revved up high during the cliff incident. What about the clutch slipping would cause smoke? Should I check the transmission fluid? I changed it 20k miles ago.
  6. Jul 27, 2023 at 9:17 PM
    TnShooter
    Deogee
    STOCK
    The smoke is caused by the clutch material burning off while slipping on the flywheel.
    The fluid has nothing to do with it.
    Clutch material is basically like brake pad material.
    It wears.
    I’d use 4 Low when pulling heavy loads from a start.
    It won’t require you to rev the engine up as much.
    The more RPM you use when starting put the more you will wear the friction material off the clutch disk.
  7. Jul 27, 2023 at 9:21 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    4Hi is for 20 MPH or more. If it's low speed with high load, like pulling a post, definitely use 4Lo. Same for slow speed off road driving, but this may be less important in a stick. In autos it's a must to keep transmission temps down, but I don't imaging it'll hurt in a manual either.
    ztwatson[OP] likes this.
  8. Jul 27, 2023 at 9:37 PM
    Laxtoy
    Maltby, WA
    A clutch is basically a disk brake system in terms of metallurgy, the flywheel and the pressure plate act like rotors, the clutch disk is the brake pad. If you spool up the clutch without proper clamping force and excessive rpm’s it’s basically the same way disc brakes heat up and glaze on long grades of sustained use without giving the system a chance to cool
  9. Jul 27, 2023 at 9:37 PM
    eon_blue
    Azusa, CA
    Burnt clutch. Hard to avoid in some situations like that, use 4lo
  10. Jul 28, 2023 at 7:04 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Sounds like clutch is toast
  11. Jul 28, 2023 at 7:21 AM
    ztwatson
    Milwaukee, WI
    Thanks guys. So where is the smoke actually coming out of? Rear main seal or something? There a breather on the clutch?
  12. Jul 28, 2023 at 7:22 AM
    ztwatson
    Milwaukee, WI
    I mean, it still seems to work totally fine. Just nearing the end of it's life or something I'm missing?
  13. Jul 28, 2023 at 8:19 AM
    Bivouac
    You have never smelled a Hot Clutch or even Hot Brakes the 2 smells are close but not the same.
    If you had the clutch so Hot it smoked 2 times you would be seeing constant clutch slipping .
    ztwatson[QUOTED][OP] likes this.
  14. Jul 28, 2023 at 8:28 AM
    vern650
    brandon
    hyrum, ut
    the smoke would be coming from the clutch disk itself slipping between the pressure plate and flywheel. The friction of the disk rubbing the other two surfaces creates heat and glazes over the friction material on the disk. That is where the smoke comes from. It might not be completely shot yet, but once they start slipping it usually only gets worse. You can probably milk it out for a while if you’re not rough on it, I.e. no more pulling post and such, especially in 4 hi. Use 4 low for stuff like that, or anywhere that your going slow enough that your basically riding the clutch.
  15. Jul 28, 2023 at 1:54 PM
    TnShooter
    Deogee
    STOCK
    The smoke will come out between the engine and the transmission. (Bell housing)
    If it gets hot enough to smoke, you will have glazed the clutch material. Depending on the clutch condition, it can clear up and go back to “normal” holding capacity.
    I’ve never personally had a clutch smoke. But I played a part in one “being smoked”.
    Me and my buddy “worked” on his dads ford van. The next morning his dad didn’t make it 100 yards down the road and had to shut the van off. (We had the plug wires crossed.)
    Anyways, we used my buddy’s Honda civic to try to pull the 1-ton van back to the house.
    It didn’t work……we smoked the clutch. That civic just wasn’t going to pull it. :rofl:
  16. Jul 28, 2023 at 2:53 PM
    Bivouac
    In all my years I have never seen a clutch get hot enough to smoke!!:bananadead:
    Smell enough to burn your eyes no smoke and the clutches were completed done .
    Though I have seen clouds of smoke from hot brakes!!:anonymous: Real Embarrassing .
    TnShooter[QUOTED] likes this.
  17. Jul 28, 2023 at 2:59 PM
    eon_blue
    Azusa, CA
    I've had it happen in more extreme off-road scenarios - feathering the clutch in 4lo to climb steep rocky obstacles...if you go at it for a good bit the clutch will start to smoke. Knock a good several years off its lifespan lol.
    Its why heavy rock crawlers like to do dual cases for that extra low range, then don't need to worry about slipping the clutch in those situations
  18. Jul 28, 2023 at 3:00 PM
    TnShooter
    Deogee
    STOCK
    Now you have
    https://youtu.be/oebzAIZEfxQ
  19. Jul 28, 2023 at 3:01 PM
    eon_blue
    Azusa, CA
    There was a 3rd gen thread some time back on here where a guy was wondering why his clutch on his new 4x4 was already toast and Toyota wouldn't warranty it. Then he posted a video of himself doing a steep rocky hill climb in 4wd (before the clutch went out) and mentioned he was in 4hi the entire time. Could see the smoke under the truck. He learned a lesson there
  20. Jul 28, 2023 at 3:04 PM
    Bivouac
    rocknbil and TnShooter[QUOTED] like this.
