Generator for my 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bendecco, May 11, 2017.
  1. May 13, 2017 at 11:29 PM
    Bendecco
    Bendecco [OP] Well-Known Member
    Warren
    North OC Southern Cali
    12 MGM Prerunner DCLB
    Wet Okole, Weathertech, TRD FJ Trail Team Wheels, 265-75-16 Michelin AT2, Nfab side steps, Blue Guy Console cover,Front billy 5100 coilovers, tailgate and bed hatch locks
    lol yea, I got issues.....once I get my mind on getting something I can't sleep till I get it....
    I have an $800 inverter sitting here that I don't need now..... lol
    The tuna we're catching are big this year and even IMG_4560.jpg the 150 quart didn't cut it last week....
  2. May 13, 2017 at 11:31 PM
    Muddinfun
    Muddinfun Well-Known Member
  3. May 13, 2017 at 11:44 PM
    Theloraxcross
    Theloraxcross "He's Got the Crazy Eye"
    Joseph
    San Angelo Tx
    08 AC TRD OR
    OP The Honda can also be converted to run on Propane for a little bit of money. Congratulations on finding one. Hope you have it for a long time and it serves you well.
    Bendecco[OP] likes this.
  4. May 14, 2017 at 9:54 AM
    TWENTYCO
    TWENTYCO Tree top flyer
    Tim
    North FL
    2015 TRD Off Road 4X4 Acess Cab
    Plenty mods on many vehicles since 1982. Current: 15 Tacoma 4X4 V6 TRD OR Access Cab Pyrite Mica- Icon full stage 7, All-Pro APEX sliders & rear Expedition Springs + custom Tampa Springs leaf spring upgrades, Timbren bump stops, u-bolt flip, Road Armor front stealth winch bumper & rear steel, Warn Vr 8000, Nitto Terra Grappler 285/75/r16, Off Grid Engineering Dual Battery system, SPod 6 switch, 2 pairs Rigid D2 spot & flood in bumper, ARE Expedition Cap, bedglide,Tru Cool 45K GVW add on transmission cooler, Re-gear to 4.56, rigid rear bumper floods, scan guage II, rigid ditch lights. full size spare on matching factory wheel, seat mods/insert, CB w/magnet mount.
    I used a big padlock and fastened it to the frame on the generator and connected it to a short cable then locked the other end to the tie down with another padlock. Super simple and cheap w/locks I had on hand.
  5. May 14, 2017 at 11:24 AM
    Bendecco
    Warren
    Appreciate the reply "Twentyco"
    Did you have to cut away a piece of the plastic housing to get to the frame?
    Or did you weld the padlock to the frame?
  6. May 14, 2017 at 12:49 PM
    Muddinfun
  7. May 14, 2017 at 1:30 PM
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    Here are some tips on how to keep that Honda running. I've been running a pair for close to 10 years so this is all from experience gained the painful way.
    1. NEVER use anything but pure gas in it. Even the 10% ethanol gas will cause you grief.
    2. Buy a spare carb for it. The metering holes in the carb are SUPER small and get clogged easily. It's a 10 minute or less job to swap out the carb then you can clean the clogged up one when you get home. This one trick has saved me numerous times. You'll know it's time when you need to run the genny at half choke to keep it running. It uses a lot more gas and you may not be able to use the eco setting because the engine can't spool up fast enough and you can trip the overload. Really a problem when running an RV AC unit.
    3. Change the oil often and use synthetic oil. I change the oil after an estimated 24 hours of run time with Mobil 1. No smoke and still good compression on the oldest one which I've owned for 9+ years and it was used when I got it. I carry a jug of Mobil 1 in the trailer just for the gennys (and I could use it in the truck too).
    4. Keep a spare spark plug that you have checked the gap in your kit. They seem to eat plugs (kinda like our Tacomas) pretty fast.
    5. If you're not going to use it for more than 30 days, empty the gas tank, run until it quits then make sure to drain the carb (there is a screw on the carb for that purpose).
    6. When you have drained the tank/carb and all for storage, it will be a bear to start the first time UNLESS you just put the switch in the "On" position, pull the cord once or twice slowly, then let it sit for about 5 to 10 minutes. It'll then start right up.
    7. Don't forget to open the gas cap switch to On or Run. It'll die if you forget. It takes about 20-30 minutes of runtime for this to happen but is very annoying!
    Hope this helps, if you follow these simple suggestions you'll get really good service and a very high level of dependability with the unit.
  8. May 14, 2017 at 3:27 PM
    Bendecco
    Warren
    Appreciate the info "Jaxjim"
    I watched maintenance videos for 3hrs last night on YouTube
    I checked the oil and plug and it appears the previous owner was telling the truth, it is pretty much new...
    About the gas....here in cali our only options are "E85" and "Flexfuel"
    It's wreaking havoc on our boat motors...
    I'm wondering if there is a way to retrofit or condition the gas to lessen the damage....
    I don't plan on using this unit very often so I don't think I'll need a spare carb but in your experience would you say I should have a spare bowl gasket/O ring on hand? Or do they hold up to being removed/replaced?
    And also, I don't see a "Prime bulb" on this unit, is there a way for me to add one?
    I don't like the idea of pulling a cord to fill the carb bowl.
    And if I store it "Dry" do I just tip this thing over and dump the tank out of the fuel fill? I don't like siphoning gas....
    Thanks for the great info......Warren
  9. May 14, 2017 at 3:29 PM
    Bendecco
    Warren
    ""Middinfun"
    I saw that security mounting plate ($250 on eBay) and passed right by it....
    I'm thinking I'll just crimp a heavy wire rope to it somewhere and lock that to the bed tie down...
    It's sitting in my garage till I can figure something out I'm comfortable with
  10. May 14, 2017 at 3:30 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    There are sources for ethanol free gas, call around. Start with small engine supply /sales places. In our area I know willits power sells E-free gas at about $0.40 over the price at the pump.
    Bendecco[QUOTED][OP] likes this.
  11. May 14, 2017 at 3:49 PM
    Muddinfun
  12. May 14, 2017 at 3:59 PM
    Bendecco
    Warren
  13. May 14, 2017 at 4:22 PM
    JaxJim
    Jim
    Jacksonville, FL
    Comments all in RED in the quote above.
  14. May 14, 2017 at 4:27 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You mentioned welding a tab, so I assume you're handy with a welder. Maybe you could weld up a cage for the generator out of some angle iron that bolts through the bed with a plate on the backside for reinforcement, and a hinged top so you can take it in and out. That'd be my suggestion at least if you're so worried about someone stealing it.
  15. May 14, 2017 at 4:38 PM
    #35
    sfcacique
    sfcacique Well-Known Member
    Florida
    4WD TRD Access Cab
    Thule Racks with Hullavator, Pioneer Stereo/Nav
    www.google.com/search?query=Honda+eu+lock&client=ms-android-hms-tmobile-us&hl=en
    Shows a lot of ways to secure Honda generstors.
  16. May 14, 2017 at 7:53 PM
    #36
    Bendecco
    Warren
    I think I've got it figured out
    My buddy has a CNC water jet table, I'm going to make a "Battery Tray" style mounting base and lock the perfect length strap over the top and through the handle. Should look pretty clean and be easy to remove....
    Appreciate all the info, maybe I can build a refrigerated fish box for my bed now that I have power
    Theloraxcross likes this.
  17. May 14, 2017 at 9:12 PM
    #37
    Muddinfun
    I read something earlier that was one of those, uh, OK, that would work moments. A smart thief will take an angle grinder, plug it into the generator, fire up the generator and cut the lock. I think you still better put in those pin switches.
  18. May 14, 2017 at 9:30 PM
    #38
    Justinlhc
    Justinlhc Not looking for a relationship
    Jesus I'd just give the damn thing to him at that point. o_O If he's bringing an angle grinder to steal shit out of my truck I'd rather he used it on a cheap lock than my door or tailgate.
    sfcacique likes this.
  19. May 14, 2017 at 10:07 PM
    #39
    Bendecco
    Warren
    Hahaha.....He wouldn't need to bring an angle grinder as I have a brand new brushless makita LXT model in the bed of my truck for him to use
  20. Sep 24, 2017 at 8:27 PM
    #40
    TWENTYCO
    Tim
    North FL
    I had the iu3000 with the external frame so it was super easy. The smaller generators should have a place where you can drill a hole in the plastic and wrap a cable around the internal frame? I've seen where a buddy of mine put in longer bolts on the vibration pads and installed a plate with a bent corner that had a hole drilled through it and bolted it down to a slide out platform. This should work to secure a cable or padlock as well.
