Georgia Classifieds
Discussion in 'Georgia' started by tacomarotto, Jun 21, 2013.
  1. Dec 11, 2019 at 7:44 AM
    #4601
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    PM for the Mod day has been sent out if you didn't get it and are coming let me know and I'll add you
  2. Dec 11, 2019 at 7:53 AM
    #4602
    MDB Taco
    MDB Taco Well-Known Member
    GA
    ‘05 TRDOR DC
    It sounds sketch AF, but I used a thick coat of black plasti dip as a primer (since not a whole lot sticks to chrome), then color matched several coats with an aerosol from a body shop. Clear coat on top of it all. It’s held up for quite a few years now.
  3. Dec 11, 2019 at 8:02 AM
    #4603
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    For a little more than $400, this might be the option I go with as a more permanent solution so I don't have to repaint it myself over and over again. I called Line-x and they quoted me about $400 also. If I can find a cheap MGM rear local then that would be great but I don't see that happening anytime soon. The Amazon bumper is cheap, looks decent, and if I need to pull something I'll just use the factory hitch.
    https://www.amazon.com/u-Box-Discovery-Bumper-Floodlights-2005-2015/dp/B07PFGWQYB/ref=sr_1_1_sspa?keywords=tacoma+rear+bumper&qid=1576079758&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzN0lYME1WODFNUFRRJmVuY3J5cHRlZElkPUEwMTIwMzY1MjExTDJJNzc2MVdXNiZlbmNyeXB0ZWRBZElkPUEwMDMwNTAxMjRYUDQ5TkVUQlpHSiZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU%3D
  4. Dec 11, 2019 at 8:14 AM
    #4604
    Tarvis
    Tarvis Well-Known Member
    Travis
    Bel Air, Maryland
    2018 Metallic Gray SR5 Double Cab
  5. Dec 11, 2019 at 8:19 AM
    #4605
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Not sure, they have it listed as textured black TPO.
  6. Dec 11, 2019 at 8:19 AM
    #4606
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Black spray paint! lol
  7. Dec 11, 2019 at 8:22 AM
    #4607
    Tarvis
    Travis
    Bel Air, Maryland
  8. Dec 11, 2019 at 8:31 AM
    #4608
    Chrisf06
    Chrisf06 Well-Known Member
    Bogart, Georgia
    2014 MGM Tacoma DC TRD Off Road
    I see you have an MGM. I did a specialty color (I think it was called anthracite? I can check on that) of plasti-dip as a quick fix a few years ago, and it matched almost perfectly and has worked so well I haven't even thought about changing it. I had someone back into me in a parking deck that scraped some of it off, but it only took a few min to prep and respray that small area (with cans I had left over) and it was right back to normal. I have been more than satisfied with it, although if an MGM bumper popped up somewhere for decent I would probably make the change.
  9. Dec 11, 2019 at 8:32 AM
    #4609
    Tarvis
    Travis
    Bel Air, Maryland
    That looks sweet. Yeah send me the color you used. Did you take them off or tape it off and spray it while still on the truck?
    JKU3000 likes this.
  10. Dec 11, 2019 at 8:40 AM
    #4610
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    I'm not sure about the carid bumpershellz. I looked and it looks like there isn't an option to pick the texture or color, plus the picture they have is real glossy. I'd order from the link I provided for sure. These fit so well, that I didn't even use the double sided tape, I just popped them under the lip of the bumper and reinstalled the 3 clips on the bottom. They ain't goin' nowhere!
  11. Dec 11, 2019 at 8:40 AM
    #4611
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    @Brian422 has plastidipped his rear bumper and it has held up great, despite going offroading a ton in the last few months!
  12. Dec 11, 2019 at 8:42 AM
    #4612
    Tarvis
    Travis
    Bel Air, Maryland
    Bumpershellz is the Ecoological brand, Carid is just the retailer... So its the same product, brand, and everything. Just weird that the options don't match.
  13. Dec 11, 2019 at 8:43 AM
    #4613
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    That looks pretty good. What all did you have to do prep work related or did you just go at it full throttle haha.
  14. Dec 11, 2019 at 9:05 AM
    #4614
    Chrisf06
    Bogart, Georgia
    I didn't take the whole bumper off. I took the black plastic cover pieces off (top of bumper, above hitch, tag lights) and the tag off, then wiped down with cleaner, taped up newspaper and sprayed. The kit I got (I did the wheels too) came with a cloth and some sort of cleaner, its probably just rubbing alcohol. I probably did 4-6 light coats, it doesn't take too long because the dry time in between coats wasn't very long. I think the website has exact instructions.
    I am almost positive it was this color, but I can double check the cans when I get home today: https://www.dipyourcar.com/collecti...ts/anthracite-grey-aerosol?variant=5631654340
  15. Dec 11, 2019 at 9:14 AM
    #4615
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Yes, please check on the color for us. I think this is the most affordable option so far that still looks good. Did you do the front chrome grills surround also?
  16. Dec 11, 2019 at 9:22 AM
    #4616
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Plasti dipp has worked well. Been holding up with all the offloading i do. Minor peals but i just break out the can and touch it up and it looks good as new.
    cubie[QUOTED] likes this.
  17. Dec 11, 2019 at 9:39 AM
    #4617
    gatriguy
    gatriguy Well-Known Member
    Paul
    GA
    2016 Black Tacoma SR5 DCSB
    +1 on these bumper caps.. got the gloss black for mine (matched my truck well). They fit over the chrome exactly and have been a great addition..
    Worth the money to me ..Do it!
  18. Dec 11, 2019 at 10:17 AM
    #4618
    Chrisf06
    Bogart, Georgia
    No, I just bought a sport surround that was color-matched from Camelbak Toyota and then sold my chrome one on ebay. That made it pretty cost effective, I saved the box and packaging from the new one to ship the old one.
  19. Dec 11, 2019 at 10:35 AM
    #4619
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    How much were you able to sell your chrome one for?
  20. Dec 11, 2019 at 10:50 AM
    #4620
    Chrisf06
    Bogart, Georgia
    Honestly cannot remember, it has been a while. I checked my ebay account but it doesn't list sales that far back apparently. If I had to guess I would say $140 or so.
