German coolant in Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Aug 1, 2024.
  1. Aug 1, 2024 at 6:57 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    Does anyone know if the chemistry is compatible?
    I have extra German coolant left over. Pink G13.
    Old Toyota dealer gave a good price. New Toyota dealer does not.
    Not interested in bending over.
    It was $12. Now it's somehow over $20. There is no legitimate reason.
    Thinking of putting this G13 in. I just don't know how well the chemistry would play.
    Worst case scenario going to research/shop around see if I can find something "spec" anywhere else such as Zerex from WalMart or something.
    Technically, Tacoma coolant is "red". But in real life it also looks pink. Both come pre-diluted 50/50.
    HondaGM likes this.
  2. Aug 1, 2024 at 7:08 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Oh goodie gumdrops, a Friday thread about fluids!
    Short answer: Just use the correct Toyota/Asian pink coolant. Difference in cost of like a cheeseburger, fer cripes sake stop being a cheap ass and just use the right stuff.
    Long answer: Same as above but there is some science to it too. Go read Bob Is The Oil Guy for differences on Si-OAT (VW) vs P-OAT (Toyota) and just know our “Japanese” motors are more happy sticking with the correct fluid. And again stop being cheap. An extra $20 for something that will last 100k intervals is inconsequential. Stop being cheap.
  3. Aug 1, 2024 at 7:52 PM
    TacoTuesday1
    FL
    I mean you're not wrong. Like I said gonna see if I can find it for a normal price
    that doesn't involve driving 1hr to pay $100 for a jug of milk at "dealer"
    just didn't know if coolant is coolant. Oil kind of is. I run random oil in my truck all the time no problem.
    I'd imagine aluminum is aluminum, and anti corrosion coolant is anti corrosion coolant, but who knows.
    Better safe than sorry does come into play for sure, don't want to learn such a lesson the hard way
  4. Aug 1, 2024 at 7:55 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I flushed mine completely and went to the regular green stuff years ago.
  5. Aug 1, 2024 at 7:58 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Use the right stuff, oriley auto parts/walmart etc have the proper Zerex Red Asian 50/50 coolant all day long without having to question will it work.
    Yup it used to be 12$, and now its 20... you can thank 81M people for that and the "strong economy" we have. #BuildBackBetter *rollseyes*
  6. Aug 1, 2024 at 8:18 PM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    You could mix a bit of each in a closed container and let it sit for a week to see what happens. Still no guarantee though.
  7. Aug 1, 2024 at 9:27 PM
    TacoTuesday1
    FL
    It's dealer mark up. It varies widely based on the dealer. Every dealer is run differently.
    One dealer for one brand will take a $300 part and mark it up to $500.
    Another dealer 20 miles north will mark the same part up, same brand, to $700.
    what regular green stuff?
    I've always heard green is bad.
    But hey if it works it works.
    And, probably another factor is doing an entire flush, versus mixing if something is reverse fluid incompatible
    That is a good idea. I could do that. It might settle in different layers without an engine pumping it.
    But yeah I get the above posts. A lot simpler to just stick to the FSM and find the right price.
  8. Aug 1, 2024 at 9:45 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Color doesn't mean anything anymore. It is just a dye that manufacturers use to distinguish their coolant from others. Your Toyota/Lexus manual states to use Toyota coolant or “a similar high quality ethylene glycol based non-silicate, non-amine, non-nitrite, and non- borate coolant”. An affordable antifreeze I have found that meets this criteria, verbatimly, is Walmart’s SuperTech antifreeze. I have been using it since my first Toyota vehicle - now my mom’s 98 Sienna. That being said, if you are changing brands, always flush out as much of the old coolant as you can.
    kidthatsirish likes this.
  9. Aug 1, 2024 at 9:50 PM
    Steves55
    Steves55 Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
    The Wuhan variant is cheaper. ;)
  10. Aug 1, 2024 at 10:32 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    G13 is said to be bad for water pumps and seals in Toyotas: https://bobistheoilguy.com/forums/threads/g13-coolant-in-toyota.349441/
    wi_taco likes this.
  11. Aug 2, 2024 at 5:33 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    wi_taco likes this.
  12. Aug 2, 2024 at 11:56 AM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    Coolant is cheap I would spend the extra $20 it will last you the next 5 years
    wi_taco likes this.
  13. Aug 2, 2024 at 12:31 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Nice job there
