Get a Stiff One (In Bed) | 2nd & 3rd Gen Bed Stiffeners
Discussion in 'Victory 4x4' started by victory4x4, Mar 5, 2019.
  1. Mar 5, 2019 at 1:03 PM
    victory4x4
    victory4x4 [OP] Member Vendor
    Portage, MI
    Designed to strengthen the bed of the Tacoma. Comes coated with a 2 stage satin textured black powder coat over durable zinc primer finish.
    • Made from 3/16" steel
    • Easy installation, does require drilling
    • Adds additional tie down locations
    • Works with decked bed systems
    • Works with slide out refrigerators
    $119.00 (Free shipping)
    https://www.victory4x4.com/mm5/merchant.mvc?Screen=PROD&Product_Code=VT23-BST-PC
    Use the code "IntroPricing" to save 15%! (Expires 3/31/19)
  2. Mar 5, 2019 at 1:06 PM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    This works with bed extender? Year 2017 tacoma.. thanks
  3. Mar 5, 2019 at 1:10 PM
    victory4x4
    Portage, MI
    Most likely they won't work together without modification.
  4. Mar 5, 2019 at 1:15 PM
    Kabogski
    Bote
    Los Angeles
    Thank you.. Good product :thumbsup:
    I'll put these on my mod list.. :hattip:
    monkeyevil likes this.
  5. Aug 2, 2019 at 12:22 PM
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    I currently have a different set of bed stiffeners and would like to switch to these. Would I be able to get a pair that don't have holes on the vertical surface so I could drill them in to match the holes I already put in my Tacoma's bed?
  6. Aug 6, 2019 at 9:43 AM
    monkeyevil
    monkeyevil Victory 4x4
    Daryl
    Kalamazoo, MI
    We don't have a good way to do custom stuff like that, but if you get me a measurement of your mounts and hole locations I can see if there is any compatibility or interference.
  7. Aug 6, 2019 at 10:02 AM
    HelloMyNameIs
    Thanks, but I can tell from pictures that they will not line up.
    You guys are the closest fabricator to me that I know of making 3rd gen rock sliders and I was going to see if it would be possible to get a set of weld ons instead of bolt on. Guessing that's a no go too?
  8. Aug 6, 2019 at 10:27 AM
    monkeyevil
    Daryl
    Kalamazoo, MI
    Correct. The way our system here plans cutting and fabricating is on parts that have all of the engineering created for them. Any variation of those parts would need to have one of our engineers create a custom product, then everyone in production, coating, and shipping would have to know what is up with that product. Without someone holding its hand the whole way, I guarantee it would get messed up. When we were a smaller shop that kind of stuff was easy, but now it's not. Just what it takes to manage the volume. Sorry for that, but I just wanted to explain what was up.
    GonzoQuick likes this.
  9. Aug 21, 2019 at 3:58 PM
    Baja Barry
    Baja Barry Not actually Barry
    Ike
    Michigan
    2014 TX Baja DCSB
    Any chance you know the distance between the two upper-most tie-downs when these are installed? Looking for bed stiffeners that still allow 4'x8' sheet goods to be loaded, apparently that's not a huge consideration for most places manufacturing these.
    Thanks
