"Get an alignment any time you do suspension work"
Discussion in '3rd Gen. Tacomas (2016-2023)' started by trabo, Nov 17, 2021.
  1. Nov 18, 2021 at 5:46 AM
    Cowdog
    Cowdog Well-Known Member
    How about Roadmaster active suspension in the back and sumos in the front? Would that require an alignment?
  2. Nov 18, 2021 at 6:15 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Alignment is cheap compared to buying new tires etc.
    brian2sun likes this.
  3. Nov 18, 2021 at 1:19 PM
    Cowdog
    Anyone? I ask because I'm thinking of installing these on my new sr5. I've read on here that the ras lifts the rear an inch and that the Sumos lift the front an inch. Thoughts?
  4. Nov 18, 2021 at 3:48 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I thought sumo springs were a bump stop replacement. If so, I would not expect them to provide a lift nor affect alignment.
    usmc2msu and Clearwater Bill like this.
  5. Nov 18, 2021 at 5:45 PM
    Cowdog
    They are a bump stop replacement. I thought I read that they lifted the front a half inch of so? Would an inch in back and a half inch in front make enough difference to require an alignment?
  6. Nov 18, 2021 at 6:02 PM
    gudujarlson
    Minnesota
    Something is wrong if a bump stop is giving you a lift. The purpose of a bump stop is to prevent metal on metal contact in emergency situations where you’ve hit the ground so hard that your shocks and springs can’t prevent the over compression of your suspension.
  7. Nov 18, 2021 at 6:06 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    The thing with sumos and superbumps, is that they are so big and squishy, that they contact the lcas in the front and basically touch the leafs in the rear on a bone stock truck. So, they "can" provide lift, but fully compressed they will have the same bottom out height as stock bumps.
  8. Nov 18, 2021 at 6:12 PM
    gudujarlson
    Minnesota
    Sounds like a very bad design if true. Why would you want a piece of polymer being a active part of your suspension on a regular basis?
  9. Nov 18, 2021 at 6:16 PM
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    Because they are so soft, that in the front you dont even realise them due to the motion ratio on them. The rear, they are slightly noticeable. But, they are progressive, so that is how they have to be.
  10. Nov 18, 2021 at 6:27 PM
    gudujarlson
    Minnesota
    That sounds like pseudo science. If polymer was viable as an active part of a suspension, you would see it in stock and/or race trucks.
    In any case, getting back to the question, if they change the ride height you might want to consider an alignment, but I’m not sure how much 0.5” throws it off.
    My own alignment has been out of whack from the dealer, after a 1” lift, and after a summer of frequent off road use.
    trabo[OP] and CherylJane like this.
  11. Nov 20, 2021 at 11:01 AM
    trabo
    trabo [OP] Well-Known Member
    Los Angeles
    2017 Silver DCLB OR
    I've been suspicious of those stops for these same reasons. I also don't feel like the material will last exposure to the roads for long.
  12. Dec 2, 2024 at 3:42 PM
    Claytonb
    Claytonb Well-Known Member
    Clayton
    2016 TRD Sport
    6” BDS Lift
    2016 Tacoma with 4” front lift, 3.5” rear
    I’m adding half inch spacers to the rear suspension because the new lifted springs I installed are lower by 1/2” than the previous springs with blocks.
    I wasn’t going to get an alignment because it’s the rear and it is so minimal it should have minimal affect on the front and when I have my canopy now and again it’s going to correct itself.
    any thoughts?
  13. Dec 9, 2024 at 4:05 PM
    bruhman
    bruhman Well-Known Member
    PDX
    '22 White TRD Pro MT
    SnugTop canopy
    Similar question...what about when only replacing the leaf packs...alignment required?
    koditten likes this.
  14. Dec 9, 2024 at 4:10 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    No. There is no adjustment in the rear.
    bruhman likes this.
  15. Dec 9, 2024 at 7:04 PM
    #35
    BigTang
    BigTang Well-Known Member
    C
    2022 SR
    I'd at least check it with a tape measure to see that you don't have a new axle centerline relative to the old setup and that its still square to the front.
    bruhman[QUOTED] likes this.
