Get me level?
Discussion in 'ToyTec Lifts' started by AtomicTrent, Sep 16, 2012.
  1. Sep 16, 2012 at 3:47 PM
    AtomicTrent
    AtomicTrent [OP] Member
    Edgewood, NM
    So, I purchased the Eibach/5100 setup that was over on swap and am getting ready to install.
    I have the 5100s on the second ring and the springs are the 1.5".. According to the tech guy I spoke to on the phone when I was setting up the front, he said that should get me right at 3" total up front.
    My question is which AAL setup is going to get me level? I do haul an enclosed Haulmark from time to time with a couple bikes.. Eventually I will get bags, but for now, I just want level.
    Thanks in advance!
  2. Sep 16, 2012 at 3:52 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Headlight mod, sound system. MB Motor Sport Rims. Black Tails. 5100's, 885, grill craft, Fogs, N-Fab Step Sides. BFG TKO Tires, Wet Oks, LED map lights and dome, LED gauge mod
  3. Sep 21, 2012 at 6:20 AM
    AtomicTrent
    Edgewood, NM
    So, I called Toytec and they recommended the 1.5 AAL for the rear.. Ordered it up and installed... well, I am pretty bummed as now my truck sits with a rake..
    So, I will ask this once again. What is it going to take to get this Taco to sit level? Should I move the C clip up to the THIRD ring, or add a spacer?
    New Taco owner needing help here and pretty frustrated at the moment!
  4. Sep 21, 2012 at 6:22 AM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    Give it some time grass hopper, aal will settle
  5. Sep 21, 2012 at 6:24 AM
    98tacoma27
    98tacoma27 is gooder 'en chicken Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+250k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Update your info so we know what truck you have, although I'm guessing 2nd gen. There's a big difference between 1st and 2nd gen Eibachs . Is the front higher or lower?
  6. Sep 21, 2012 at 6:29 AM
    AtomicTrent
    Edgewood, NM
    Thats what I was thinking, but to be honest the front is considerably lower.. I was hoping to get the front up where the rear is now..[​IMG]
  7. Sep 21, 2012 at 6:29 AM
    sinaptic
    sinaptic Well-Known Member
    Twin Cities, MN
    2011 Access Cab V6 4x4
    Fog lights, back-up camera, TRD cat-back exhaust, towing package, int. wiper stalk, Weathertech floor liners, color-matched the front bumper and grille, TSB leaf packs, Front Bilstein 5100's at 0", Eibach/Toytec coils (approx 1.25" front lift - sits almost level), rear Bilstein 5100's.
    I'm sure someone here will correct me if I'm wrong, but I don't think you're supposed to go up to the third setting on the 5100s if your're running the eibach coils.
    If you still have rake after the aal settles, toytec has front spacers in a bunch of different sizes.
  8. Sep 21, 2012 at 6:32 AM
    AtomicTrent
    Edgewood, NM
    Thats what I had initially set them to (as I only wanted to do this instal ONE time), but when I called Toytec to confirm, the rep said "2nd will get you level", so I dropped back and now hate the thought of taking this all apart.. AGAIN.. :confused:
  9. Sep 21, 2012 at 6:33 AM
    4banger09
    Alex
    Nb, Canada
    Leveled
    This is correct, do not over compress these springs
  10. Sep 21, 2012 at 6:35 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You're right. The second setting is as high as you should go.
  11. Sep 21, 2012 at 6:37 AM
    AtomicTrent
    Edgewood, NM
    So, basically I am going to need to put a spacer on top of my Eibachs and leave the c clip at the 2nd setting?
    I am just looking for a TRUE and even 3" of lift.
  12. Sep 21, 2012 at 6:40 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You should let the rear settle first. Try haulling a heavy load around for a week. Did you take any measurements to determine the height difference?
  13. Sep 21, 2012 at 6:42 AM
    AtomicTrent
    Edgewood, NM
    Haven't pulled measurements yet, figured I would let it settle out a bit.. But as it sits right now, can see I want the front higher.. Had a spacer lift in before, was hoping for another 1" of height out of this front setup.. that didn't happen.
  14. Sep 21, 2012 at 7:08 AM
    sinaptic
    Twin Cities, MN
    Just as a side note - I didn't really get as much out of these coils as I thought I would either. I'm running my 5100s at the 0" setting with the same eibach coils and only got about 1.1". The estimate was about 1.5" with this setup, and after little research, that is in fact what most people on these forums got as well. No idea why I got less. I don't have any added weight in the front either (plate bumpers, etc.). :confused:
    My truck is pretty much the same as yours, 4x4 access cab.
    In my case, it doesn't really bother me (yet) because I wasn't after a whole lot of lift, but I understand your frustration. It's disconcerting to be the guy with the same same parts, same truck, but different end result.
  15. Sep 21, 2012 at 8:21 AM
    4banger09
    Alex
    Nb, Canada
    Leveled
    If you adding spacers to the top of the strut would be the easiest option for you now, and not huge spacers , I think the front seems low because the rear is high let it settle and see how it is then
  16. Sep 21, 2012 at 8:38 AM
    AtomicTrent
    Edgewood, NM
    22 front, 25.5 in the rear is what my truck measures at now. Center of hub to wheel well.
  17. Sep 21, 2012 at 10:33 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    3.5"??? WOW!! Do you have a TSB leaf pack?
  18. Sep 21, 2012 at 10:38 AM
    AtomicTrent
    Edgewood, NM
    Yep, when I ordered the AAL, the tech told me the 1.5 is what I needed.
    I guess I need to read a lot more here.. so many threads to weed through! Figured calling Toytec woulda fixed me up first go around.. live and learn I suppose:rolleyes:
  19. Sep 21, 2012 at 10:42 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I wouldn't be too concerned just yet. When I put 5100's at 2.5" on my Tundra it initially gave me over 4" of lift. It took roughly a week to settle down.
  20. Sep 21, 2012 at 10:47 AM
    4banger09
    Alex
    Nb, Canada
    Leveled
    i just installed this same set up yesterday, after taking it off road abit today i measure 22.5 in the front and 24 in the back. i have 5100 front and rears, did you go with the 5100 rear?
    maybe post photos of the shock themselves, did you put them together or did a shop do it?
