Get out of that hole! DIY seat risers...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mthopton, Feb 21, 2016.
  1. Feb 23, 2016 at 8:21 AM
    #41
    Hankstone
    Hankstone Well-Known Member
    2016 Tacoma Sport DCLB
    Am I the only one who wishes the seat was lower? I'm 5'11" and the rear view mirror blocks my view....
    Tucktuck8 likes this.
  2. Feb 23, 2016 at 8:26 AM
    #42
    DrFunker
    DrFunker Well-Known Member
    Jack that mirror up.
    CygnusX191 likes this.
  3. Feb 23, 2016 at 8:31 AM
    #43
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    8.8 bolts in a sheer application...that you're adding leverage to and removing seat contact surface area? :crazy:
  4. Feb 23, 2016 at 11:14 AM
    #44
    Hankstone
    Is that possible? I tried to push it up but it won't budge, just pivot.
  5. Feb 23, 2016 at 11:16 AM
    #45
    DrFunker
    Not sure if it will work in a 3rd gen, but I have an ImMrYo bracket in mine. Works great.
  6. Feb 23, 2016 at 11:22 AM
    #46
    Hankstone
    I'll have to look closer, maybe there's a screw holding it firm I can loosen to adjust.
  7. Feb 23, 2016 at 11:43 AM
    #47
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Like a. earlier poster said, TW member ImMrYo makes a nice looking bracket. On some models all you have to do to raise it is rotate the mirror 180 degrees.
  8. Feb 23, 2016 at 1:35 PM
    #48
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    This is a very common thing to do with Jeeps. Apparently they dropped the seats an inch and a half around ten years ago to properly position where the airbags would hit the occupants. Consequently its hard for the average person to see well over the hood when wheeling. Anyhow, a set I installed for a friend last year used rectangular machined risers that were about 1-1/2" long and around 1" wide. The holes were drilled to tightly fit the bolts without any slop. I dont recall what grade bokt they used. Overall it looked fairy solid. I definitely wouldn't use bushings that are built more like narrow towers or anything that didn't tightly fit the bolt.
    CygnusX191 and jberry813[QUOTED] like this.
  9. Mar 29, 2016 at 7:15 PM
    #49
    easbaysav
    easbaysav Well-Known Member
    Eddie
    Central Valley, CA
    2019 TRD Off Road AC Cement
    Did this to my driver's seat using the parts mentioned by the OP; except I wanted a bigger footprint against the body and rail so I used a 1/2" steel spacer and two big steel washers on top and below the spacer. Overall it's maybe a mm shy of 3/4" but close enough.
  10. Mar 29, 2016 at 7:21 PM
    #50
    neoflex
    neoflex Well-Known Member
    I too am 5'11 and I also wish the seat could be lower. I have a sunroof and my head is nowhere near the headline like others have complained about but overall I just feel like I am sitting too high compared to where the steering wheel and dash is placed. I wish I could drop the seat an inch rather than raise it. I also have the skewp and have zero issues seeing over like others have complained about as well. I still can't believe in 2016 the Tacoma still does not have power seats.
  11. Mar 30, 2016 at 9:49 AM
    #51
    Danielnc06
    Danielnc06 Well-Known Member
    NC
    2016 TRD DCLB
    Great write up!
    My .02:
    I dont know what hardware you used so this may be for other people that do it. I would definitely suggest using equal or preferably higher grade bolts and add blue locktite and try to torque to original amount..i would use high quality bolts, not lowes hardware...during a bad wreck, something may/will happen there. The goal is to only have it bent the bolts and crush your spacers at most (not shear off)..
  12. Mar 30, 2016 at 10:30 AM
    #52
    Member1Zillion
    Member1Zillion Involuntary Kamikaze Co-Pilot
    Big Whiskey, WY
    '01 TRD, '17 Tundra, '07 FJ Cruiser, 94 PU, '18 T4R, '84 PU
    This, that, & the other thing
    Just an FYI, a metric grade 8.8 is the equivalent of SAE grade 5 and metric grade 10.9 is the equivelent of SAE grade 8. A better solution would be a fat spacer that spreads the load of the mounting part of the seat bracket so that it will not over leverage the bolt and weaken the floor. Use grade 10.9 shoulder bolts from Fastenal or similar source.
    I've seen this happen as I've been building lift kits for seats for my trucks for over 20 years and have actually seen the sheet metal crack over time. I'm 5' 10" and have weighed a shade over 200lbs. for most of that time. Also, I've done the front and rear mounts on all of my Toyotas over the years, and there is a solution to raising the front with 1/2" plate steel, but it's a bit ugly unless you take the time to fab a nice bracket.
  13. Mar 30, 2016 at 10:02 PM
    #53
    easbaysav
    Eddie
    Central Valley, CA
    I'm actually thinking about replacing the spacers with washers for that reason; unless I can find some spacers/pucks like the Rough Country seat risers for the jeeps.
  14. Mar 31, 2016 at 6:54 AM
    #54
    Member1Zillion
    Big Whiskey, WY
    I usually just holesaw some 3/4 stock and then finish up on a bench grinder.
  15. Apr 12, 2016 at 9:22 PM
    #55
    easbaysav
    Eddie
    Central Valley, CA
    Update: I swapped the 1/2" spacers with 3/8" spacers several days ago and like this better. With the washers, it totals out to just a little shy of 1/2". The 3/4" setup sets the seat about level and I'd sometimes slide forward on the seat. At 1/2" the aft section of the seat is a little lower and don't get that feeling of sliding forward on the seat.
    Edit: Used shorter bolts as well. M10x40x1.25 grade 10.9 flange bolts.
    CygnusX191 and kybluejeep like this.
  16. Apr 12, 2016 at 9:56 PM
    #56
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    I am 5'9" 195 lbs 34" inseam and I wish I could lower the rear of the seat. Sits to flat for me if I raised the rear if feel like I was sliding forward. Trying to figure out how to raise the front. May have to machine some parts to deal with the offset of the bolts after raising.
    itsmermf likes this.
  17. Apr 18, 2016 at 5:28 PM
    #57
    sparkyv
    sparkyv Active Member
    Hey mjbuck and jjardina, besides trying to position the steering wheel as far up as it goes, do you think it will help to pull it out as well. This may give you a little more room. My 2 cents...
    CygnusX191 and Tacoma2GR like this.
  18. Jan 23, 2017 at 10:05 PM
    #58
    CactusHugr
    CactusHugr Member
    AZ
    2017 DCSB TRD Off Road
    Temporarily Stock
    This was a several thousand dollar mistake on my part. I'm 6', 32" inseam I think, 200lbs. Never owned a taco before, just jeeps and recently 2015 Ram 2500 - all solid axles and ride really rough on washboard and city roads. I sold that Ram, thinking this taco would do it all - daily driving, parking lots, rock crawling in Sedona and Florence, and easy dirt road driving all over the rest of the state. BIG Plans. But, this truck kills my back and hips after about 20 minutes. I've had a back injury, but other than the hard jolts to the spine from my solid axle vehicles, I've never had a backache like this before - never. I can't drive this truck. And that mirror does certainly get in the way.
    Colorado rides nice and has much better front seats - I may consider the zr2 but otherwise it's back to full size for me.
    This sucks bad as I had it alllll planned out. 2017 TRD 4x4 Off Road for sale!
  19. Jan 23, 2017 at 10:47 PM
    #59
    duckytw
    duckytw Well-Known Member
    For those wondering, biggest issue with using the bolts isnt the tensile strength (where even grade 5 will do), its the shear strength. Safety specs usually say something along the lines of 50% strength reduction in shear, so the reason for using a high grade bolt is to bring up the shear resistance. On top of that, static loads are nothing... its when you slam into a wall and you have upwards of 10x the static load being applied in an impulse that you start snapping things.
    That said, seatbelt hardware is 10.9 / grade 8. Use those in the appropriate length and you will be *fine* (again, Im covering my ass like the other guy said about insurance... if you get anything medical related and its your fault, your ins. carrier can easily cancel your coverage).
    CygnusX191, slns831 and GPsevinSixx like this.
  20. Jan 23, 2017 at 11:29 PM
    #60
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
    haven't gone through the thread, but are the new bolts the same grade or stronger than the stock bolts? My concern for people doing this mod is in an accident, weaker bolts can sheer...
