GET READY WORLD
Discussion in '1st Gen. Tacomas (1995-2004)' started by kerns 2495, Jun 13, 2012.
  1. Jun 13, 2012 at 5:56 PM
    kerns 2495
    kerns 2495 [OP] Member
    scott
    va
    2001 dbl. cab 4x4
    2" body lift, 2.5 " coil over with rear blocks
    I am about to do the impossible. I am going to tow my 01 automatic 4x4 taco behind my RV. Just got the tow bar delivered today. Remco says this vehicle is not towable. ( we'll see) . I have spoke with a lot of people and no one really knows why. So stay tuned and tell your friends , the world will know the truth very shortly.
  2. Jun 13, 2012 at 6:02 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
  3. Jun 13, 2012 at 6:16 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Well I am about to tow my RV behind my Tacoma...
    jk I haven't even graduated yet.
  4. Jun 13, 2012 at 6:20 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    Is there not a little section in your manual that says not to tow your truck like that?
  5. Jun 13, 2012 at 6:21 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    remove the driveshafts.
  6. Jun 13, 2012 at 6:22 PM
    taco terror
    USA
    Doesn't you rv have a hitch? if so why not use it and get some kind of trailer.
  7. Jun 13, 2012 at 6:24 PM
    jandrews
    '09 FourDubDee TRD OR
    This. It's only non-towable if you don't know how bolts work.
  8. Jun 13, 2012 at 6:25 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    Will you teach me?
  9. Jun 13, 2012 at 6:28 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    I would rather load it on a trailer. Unbolting the driveshaft sounds like a chore if you have to install it everytime you park the RV somewhere and want to go somewhere in the truck, and then have to take it off when you move the RV to the next spot.
  10. Jun 13, 2012 at 6:30 PM
    SpazzyB
    SpazzyB Master of the Prius...
    Ryen
    neuf un six
    '04.5 vw stance machine
    ^This.
    ^also this.
  11. Jun 13, 2012 at 6:37 PM
    jandrews
    A fair point. Driveshaft removal isn't terribly difficult or time consuming, but frequency could make it annoying.
  12. Jun 13, 2012 at 6:47 PM
    jandrews
    Also:
    Your truck gon' blow up.
  13. Jun 13, 2012 at 6:50 PM
    medic2230
    Murph
    Bama! Roll Tide
    Was wondering where this was.... lol
  14. Jun 14, 2012 at 3:29 AM
    kerns 2495
    scott
    va
    2001 dbl. cab 4x4
    what about front drive shaft? can't I just set transfer case to neutral. Leave front shaft alone. rear shaft only has 4 bolts , I removed once for practice . 5 minutes
  15. Jun 14, 2012 at 4:32 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Transfer case in neutral, remove the rear drive shaft (or just unbolt it from the rear end and secure it up really really really well so it can't come loose and drag).
  16. Jun 14, 2012 at 9:44 AM
    Pugga
    Massachusetts
    Hey, pass some of that over here! Sounds like the OP might be having 2nd thoughts :laugh:
  17. Jun 14, 2012 at 9:45 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    doesn't it have something to do with lubricating parts? hopefully it works out for you
  18. Jun 14, 2012 at 9:47 AM
    Pugga
    Massachusetts
    Yes, at least for 2nd gens, the oil pump for the transfer case is run off the input shaft so when you flat tow it, everything is spinning away and no oil is being pumped.
  19. Jun 14, 2012 at 9:47 AM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    use one of these. just put in on the dolly with the rear end on, in neutral
  20. Jun 14, 2012 at 9:50 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    that could cause a problem huh?
