GET READY WORLD
Discussion in '1st Gen. Tacomas (1995-2004)' started by kerns 2495, Jun 13, 2012.
  1. Jun 14, 2012 at 10:05 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    But doesn't tha transfer case have to be engaged!? Otherwise its just sitting there right!? And why remove the driveshafts? Isnt the point of having neutral to be able to allow the truck to free roll??
  2. Jun 14, 2012 at 10:14 AM
    TRDBen
    TRDBen Mall Crawler of the Year
    Ben
    San Luis Obispo, CA
    02 Prerunner 4 Door TRD V6
    Front Window Tint KYB Monomax Shocks Blue Dome Light Valentine 1 Radar Detector
    OP will surely deliver....
  3. Jun 14, 2012 at 10:14 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Just a minor problem.
    Transfer case in neutral, transmission in neutral, with the rear end spinning and the drive shaft spinning, there's still going to be parts moving inside the transfer case and no oil pump to keep the lubricated. The oil pump is run off the input shaft. At least that was reasoning behind why you can't flat tow a Tacoma as I understand it.
  4. Jun 14, 2012 at 10:21 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Haha ok that's seems completely retarded but I gotcha!
    So just about the only ” realistic” option is dont flat tow it! Damn
  5. Jun 14, 2012 at 10:25 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    I'm in, I want to see the outcome!
  6. Jun 14, 2012 at 10:37 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    This yet another application where manual hubs are better. Good luck OP, I would do as others have suggested and only undo the diff side and ratchet strap it up to the underside of the truck somewhere.
  7. Jun 14, 2012 at 10:43 AM
    Pugga
    Massachusetts
    Manual hubs on the rear?!?! :confused:
  8. Jun 14, 2012 at 10:44 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    hmm that is right, forgot about that. :eek:
  9. Jun 14, 2012 at 10:44 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I had a retard moment!:)
  10. Jun 14, 2012 at 10:47 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    x2 lol.
  11. Jun 14, 2012 at 1:33 PM
    IronCladTRD
    IronCladTRD Consistently Irregular
    Corbin
    Hotel California
    2003 4x4 Manual V6 3.4L
    5100s/Eibach 3" lift, All-Pro Expo rear leafs, Elite front bumper & sliders, Smittybilt XRC8 winch, 33x10.5r15 BFG All terrains, Ultra Rogue 15x8 rims, homemade bed rack, Midland 1001z CB radio Deckplate mod, Century shell, train horn, debadged
    Done it! Turned out fine.
  12. Jun 14, 2012 at 4:50 PM
    IronCladTRD
    Corbin
    Hotel California
    Well have you did it? I done't think so. :stirthepot:
  13. Jun 14, 2012 at 5:30 PM
    kerns 2495
    kerns 2495 [OP] Member
    scott
    va
    2001 dbl. cab 4x4
    2" body lift, 2.5 " coil over with rear blocks
    Thanks guys , this is for real I just bolted the angle iron to the frame to allow for the tow bar to connect. It is a sweet set up. 59 bucks for the bar 25 for some steel and I am almost ready to roll. As I see it I am going to turn key one click, disconnect battery, remove 4 bolts at rear diff. strap the shaft securely to the frame, Set automatic transmission to park, set transfer case to neutral and roll. still have some light issues.
  14. Jun 14, 2012 at 5:30 PM
    kerns 2495
    scott
    va
    2001 dbl. cab 4x4
    tomorrow is test run
  15. Jun 14, 2012 at 5:32 PM
    #35
    kerns 2495
    scott
    va
    2001 dbl. cab 4x4
    some one told me that I can plug my rv 4 prong trailer plug directly to the taco plug and back feed the tail lites and signals
  16. Jun 14, 2012 at 5:38 PM
    #36
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The 2nd gen's rotary knob doesn't have a neutral setting. I don't think Toyota intended/designed for 2nd gens to be flat towed.
