Get Rid of That Squeak!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jason'sLawnCare, May 29, 2010.
  1. May 29, 2010 at 12:17 PM
    Jason'sLawnCare
    Jason'sLawnCare [OP] Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    First: Get all your supplies. You'll need a hammer and a big ass screwdriver or pry bar. A hammer(the big one isn't necessary).Grease(The stuff that goes into a grease gun). If you can find the stuff meant for boat trailers then that would be ideal. Popsicle sticks to apply the lube. A sponge and simple green or the equivalent. A place to wash the "silencer" pads. Pliers to help remove the maxi pads. A jack and jack stands.(This isn't 100% necessary it just makes it easier to get in there:eek:.) Vice grips to make sure the leafs are sitting together properly.
    Jack it up and find a proper place for the jack stands. Under the hitch is a good spot.
    Locate one of the 4 silencer pads and place the screw driver between the leaves and hammer away until she's in there. Then use the pliers and push from the bottom(There's a hole under each silencer pad) to get it out. Then either push it out or pull.
    Here's the culprit. Wash the silencer pad in the simple green and water with sponge(Don't use the one that you use for dishes, your wife will get pissed or in my case mom). At this time also wash in between the leaves.
    Get some grease on a popsicle stick and spread it around like icing on the top and bottom of where the silencer pad goes. I also applied grease to the pad itself just to make sure I had everything covered.
    The rest of the pics just show the location of the silencer pads. There are 4 on each side.
    To Reinstall the pads grab it with the pliers and place between the leaves. Then push it into it's spot and line it up with the hole on the bottom. It's easiest to get it in approximately the right spot then move it around from the bottom through the hole with the pliers. You'll have to make sure it's spun the right direction. Then remove the screwdriver and use the vise grips to make sure the leaves are sitting together properly. They should be able to touch if you clamp down on them enough. If you don't have them seated properly put the screwdriver back in and move the pad around to make sure it's in it's designated hole.:D
    For Wyatt,
    If you don't feel comfortable doing this feel free to ship your truck to me with the title in the glove box and an empty bill of sale. It will get done promptly and be on the road squeak less in no time.
  2. May 29, 2010 at 12:19 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Nice write up!
  3. May 29, 2010 at 12:21 PM
    Jason'sLawnCare
    Thanks. C'mon get to 10k already!:p
  4. May 30, 2010 at 4:29 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Great write-up! How long is this lasting for you? When I added a leaf I coated everything in grease and had squeaks start again after the next hard rain. Seems like as soon as there is dirt in there it comes back.
  5. May 30, 2010 at 5:38 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x2^^^^^^^^^^^^^^^^^^^^
    great write up........
  6. May 30, 2010 at 6:09 AM
    Jason'sLawnCare
    4-6 months. If you go mudding it will come back sooner. One of the many reasons I avoid mud now.
    I bet if you use marine grease it will last a lot longer. That's designed to repel water. If it can handle being dunked under water on a boat trailer I'm sure it can handle some rain.
    Thanks.
  7. Jun 3, 2010 at 11:22 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    Sweet, thanks! Will be doing this hopefully soon
  8. Jun 4, 2010 at 9:34 AM
    Jason'sLawnCare
    No prob. Your ears will appreciate it.
  9. Jun 4, 2010 at 9:37 AM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    nice...did the same thing pretty much as you! lol
    a putty knife works well too
  10. Jun 4, 2010 at 9:42 AM
    Jason'sLawnCare
    True that, good call.
    Almost any of the tools used could be substituted with something else I just wanted to give everybody some instructions to follow so they have an idea of what needs to be done.
  11. Jun 4, 2010 at 9:42 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    haha yah this is a good writeup and at least people can look at this now and answer their own questions lol....
  12. Jun 4, 2010 at 9:47 AM
    Jason'sLawnCare
    Yeah it gives the truck a little personality but it pisses me off more so
  13. Jun 4, 2010 at 10:08 AM
    Jason'sLawnCare
    interesting. I got neutral rep from this thread. WTH?
  14. Jun 4, 2010 at 10:16 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    Mmm... frosting.
    Now I know what to do if mine start squeaking. Thx
  15. Jun 4, 2010 at 10:34 AM
    Jason'sLawnCare
    I'm not accusing anybody I'm just confused.
    No prob.
  16. Jun 4, 2010 at 11:14 AM
    Jason'sLawnCare
    haha. Yeah we were all at one time. I still am in many respects when it comes to doing things on the truck
    Thanks. Hahaha. That's funny.:D
  17. Jun 4, 2010 at 11:16 AM
    Jason'sLawnCare
    oooo. I don't think I would have the balls to cut up the truck:eek:
  18. Jun 4, 2010 at 11:20 AM
    Jason'sLawnCare
    :laugh: Nice.
  19. Jun 4, 2010 at 11:21 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
    Thanks for writing this up. It will be very helpful in the future as my truck begins to squeak. :)
    The neutral rep was most likely positive rep from a noob who did not yet have any rep himself.
  20. Jun 4, 2010 at 11:23 AM
    Jason'sLawnCare
    You're welcome.
    That's what I was thinking but a confirmation would be nice. All well it's not a big deal just caused me some confusion.
    I saw that. I would be cringing.
