getn ready to buy
Discussion in 'Wheels & Tires' started by pa blaster, Jan 30, 2012.
  1. Jan 30, 2012 at 7:06 PM
    pa blaster
    pa blaster [OP] Well-Known Member
    Scott
    central pa
    2015 DCSB TRD OR 4x4
    5100's front & rear , Eibach springs, LR uca,Icon progressive aal
    fab tech stage 2 the kit calls for 17x8 w/4 5/8 '' bs/ i wanna buy kmc-xd spy's 17x8 6x5.5 os 18mm bs 4.53'' im clueless as what the hell most of that shit means except 17x8:confused:
  2. Jan 31, 2012 at 6:25 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    And 18 mm offset on an 8" wide whel is NOT 4.5" BS, it is 5.25" BS.
  3. Jan 31, 2012 at 4:25 PM
    pa blaster
    Scott
    central pa
    yep i meant 17x9
  4. Jan 31, 2012 at 4:28 PM
    KPT
    09 Prerunner
    Okay on a 9" wide wheel 18 offset is 5.75" BS.
    If you want 4.5" BS, you need zero offset on an 8" wide wheel, or -12 offset on a 9" wide wheel
  5. Jan 31, 2012 at 4:29 PM
    pa blaster
    Scott
    central pa
    any how will they work or am i gonna need a spacer or something ???
  6. Jan 31, 2012 at 4:30 PM
    KPT
    09 Prerunner
    Need to know the real wheel specs, tire size, and amount of lift to tell you that
  7. Jan 31, 2012 at 4:57 PM
    pa blaster
    Scott
    central pa
    6'' fabtech stage2 kmc xd 17x9 6x5.5 os 12mm bs 4.53'' pro-comp m/t 35x12.50x17
  8. Jan 31, 2012 at 5:01 PM
    KPT
    09 Prerunner
    Will work with some trimming and a possible cab mount chop.
  9. Jan 31, 2012 at 5:10 PM
    pa blaster
    Scott
    central pa
    cab mount chop doesnt sound good???is there a rim size better fit for what i want? my local garage is doing the mods if that matters
  10. Jan 31, 2012 at 5:12 PM
    KPT
    09 Prerunner
    Nope that's pretty much the ideal rim. The need for some minor modification comes from wanting to run 35s instead of 33s. What I would do to get a better feel for what's needed is to check out our builds section and find folks with 6" lift and 35s and see what they had to cut.
  11. Jan 31, 2012 at 5:16 PM
    pa blaster
    Scott
    central pa
    k thanks... man i cant wait gonna dyno it then do the trd cai and the cat back then dyno again
  12. Jan 31, 2012 at 5:18 PM
    KPT
    09 Prerunner
    I don't suspect that will give you much hp based on what other people have experienced.
    Are you going to regear with the 35s? That would be a lot more worth it than the CAI and cat back for a little better acceleration.
  13. Jan 31, 2012 at 6:14 PM
    pa blaster
    Scott
    central pa
    any suggestions on gearing i only want to do this once and im really considering the s/c dependig on how it runs i have 33's now and it runs real good cant imagine 35's would b that different
  14. Jan 31, 2012 at 6:15 PM
    KPT
    09 Prerunner
    I know some guys regear and some don't with 35s.
  15. Jan 31, 2012 at 6:18 PM
    COMAtose HI
    COMAtose HI Well-Known Member
    2012 TRD SPORT 4x4
    6" Procomp Stage 1 Suspension Lift, Custom 6" Alcan Springs, N-Fab Side Steps, Husky Floor Liners, Wet Okole Seat Covers, Debadged, Weathertech Side Window Deflectors, 13" Antenna from AntennaX.com, 35% Tint for front windows, Procomp 7032 Series 18x9 wheels, 33x12.50 Nitto Mud Grappler tires
  16. Feb 1, 2012 at 5:02 AM
    pa blaster
    Scott
    central pa
    yea its my dd what would the 4.56 do at highway speed would i be tachn out?
  17. Feb 3, 2012 at 3:00 PM
    pa blaster
    Scott
    central pa
    lost the web site u gave me for the gears could u send me it again A&A auto couldt get a set for my trk thnks
