**Gets stuck in reverse**
Discussion in '1st Gen. Tacomas (1995-2004)' started by skizman, Sep 27, 2016.
  1. Sep 27, 2016 at 9:41 AM
    skizman
    skizman [OP] Active Member
    ski
    2003 Tacoma 2.4
    Hello! My 03 2.4 Tacoma(128,000 miles) will get stuck in reverse when I'm on an incline maneuvering around. Shifts ok on flat surface. I drained old brake fluid out through the slave cylinder bleeder with new fluid. When it's stuck in reverse on an incline, letting the pedal up is very close to the floor where the clutch starts to disengage. On flat surface the pedal is higher when it starts to disengage the clutch.
    No noises...trans is quiet...all smoothe.
    Also....replaced the shifter lever bushing. Old one was completely disintegrated to crumbs. I vacumed out what was left. Majority of bushing pieces fell in to trans.
    I'm lost with this one.
    Your knowledge is certainly appreciated!
    Thank you!
