getting 285/75/16 what uca? will i need a wheel spacer?
Discussion in 'Wheels & Tires' started by Quast, May 8, 2010.
  1. May 8, 2010 at 8:09 PM
    Quast
    Quast [OP] Well-Known Member
    Dustin
    Mission, BC
    03 toyota tacoma 3.4L
    3'' OME lift, Deck plate mod, spidertrax wheel spacers, 12'' alpine type S sub.
    i just installed my OME 3'' lift and need new tires. i really want to get the 285/75/16 duratracs but after reading around it seems like they would rub stock uca's so i went to the local tire shop and asked them to test one on to see. well it was close i could fit my finger in there thats a bout it. sooo i figure i may as well get new uca's cause when i installed my lift i punctured both of the ball joint boots with the tie rod fork lol just wondering who has done something similar to their first gen and if they needed wheel spacers if so what size would you recommend? Ive been thinking LR uca's but wondering about ppls experience with them.
  2. May 8, 2010 at 9:44 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Alot people like the LR UCA's, but you will def. need either wheel spacer's or new wheels with a 4" backspacing. spidertrax spacers are the best.
    The LR's are still a ball-joint and the LR's are mainly for correcting allignment after lifting. And you wont get the full articulation you would get from a Uni-ball UCA like TC's or Camburg. But If you dont off road alot, then I wouldnt worry about it.
  3. May 9, 2010 at 5:53 PM
    Quast
    Dustin
    Mission, BC
    alright that helps thanks but i think to avoid any major issues i might just go with 265 cause at the moment i have stock ucas and i wouldnt get the spacers for a while you wouldnt happen to know anyone with a similar truck with pics of how that would look would you ?
  4. May 9, 2010 at 7:25 PM
    ETaco23
    Evan
    PNW
    You can run the 285's for a little while, you wont rub the UCA's to bad, but it will be close. Def. get your spacer's asap so your not destroying your tires by rubbing on your Frame and UCA's.
    You mainly rub on your UCA's when your flexing and turning, like when you pull into a parking lot or driveway.
    Dont go with 265's!! It doesnt look that great. Kinda goofy. :)
  5. May 9, 2010 at 7:28 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    I havnt had any trouble rubbing on the UCA, but if you have the cash definantly grab a set. Im going to as soon as the $$ comes together
  6. May 9, 2010 at 7:31 PM
    ETaco23
    Evan
    PNW
    But you got after market wheels right Dylan?
  7. May 9, 2010 at 8:42 PM
    Quast
    Dustin
    Mission, BC
    alright so what size of spacer should i go with you think? and the tires are 10 ply is that a bad thing is it going to make mpg even worse?
  8. May 20, 2010 at 12:32 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    1 1/2" :)
