Getting 5100's?
Discussion in 'Suspension' started by RubberTank, Mar 25, 2012.
  1. Mar 25, 2012 at 12:39 PM
    RubberTank
    RubberTank [OP] Well-Known Member
    Thousand oaks, CA
  2. Mar 25, 2012 at 12:50 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    as far as i know you should be good to go. If you set the shocks to 0 u will obtain stock ride height and have a great ride. the rears you should be fine. I believe the shocks are only adjustable in the front so the lift people get in the rear is from an add a leaf or a new leaf pack.
    This is wat i know for 2nd gens atleats. dont no what you are.
  3. Mar 25, 2012 at 1:09 PM
    Large
    Large Red
    Those would be ideal. You may even bump the 5100s to the first notch for a more aggressive stance.
  4. Mar 25, 2012 at 1:09 PM
    Tbones taco
    Tbones taco Well-Known Member
    Tony
    Carrollton
    07 PreRunner ext cab
    Flowmaster 40 smittybuilt bull bar smittybuilt nerf bars hella lights crome custome grill
    That is correct. I just lifted my with the 5100's and on 0 you will keep the stock set up. I oppted to use an add a leaf from Pro comp. It was only another $79 more for the leafs. They are the right choice for the money.
  5. Mar 25, 2012 at 1:15 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    if you wanted to really upgrade everything you could do the add a leaf and get new coils as well (as stated above). But if you dont have the funds to do it all in one shot, the billies at 0 will be a great improvement for a pretty good price. You can alwasy get the coils and an add a leaf down the road, and adjust the billies as needed.
  6. Mar 25, 2012 at 1:29 PM
    RubberTank
    Thousand oaks, CA
    Thanks everyone, and yeah im second gen. Got a 2007 2wd Prerunner.
    thats most likely my route, I was gonna do it all in one shot, but since I broke my rear left shock I can't wait anymore lol.
  7. Mar 26, 2012 at 5:18 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Yea a broken shock is a good exscuse to upgrade:p . Good thing about the billies, is you can lift your truck in sections
  8. Mar 26, 2012 at 5:40 AM
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Greg
    Illinois
    05 Prerunner SR5 TRD off road
    can you do that without getting driveline vibes?
  9. Mar 26, 2012 at 8:45 AM
    Large
    Large Red
    Yes you can, properly torque all nuts & bolts, get an alignmnent and rebalance your tires. Vibes usually come from 2.5" of lift & up but I'm fairly certain you wouldn't have any any kind of vibe.
