Getting a 2015 2.7 -- what gasoline? What oil filter?
Discussion in '4 Cylinder' started by Hublocker, May 2, 2015.
  1. May 2, 2015 at 11:21 AM
    Hublocker
    Hublocker [OP] Well-Known Member
    Ordered a new Tacoma. Should arrive in a month.
    What oil filter fits on this engine?
    What gas should I use?
    Regular, mid-grade or premium?
  2. May 2, 2015 at 11:21 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    0w-20, pick your poison for oil.
    Regular gas.
  3. May 3, 2015 at 7:13 AM
    gazingwa
    gazingwa Well-Known Member
    Slower Lower Delaware
    15 PreRunner Doublecab 2.7
    OEM: Backup Camera, Bed Mat, Wiper Switch. Aftermarket: Fog Lights, Pop and Lock, Truxport, MS2's Debadged
    Regular gas, shoot for top tier a brand if you care enough to(I do).
    Oil and Filter? I prefer OEM Filter and Pennzoil Platinum but who cares, first 6 oil changes are on the dealer with Toyotacare, they aren't going to give you any money back for not going in, might as well take advantage of it.
  4. May 3, 2015 at 8:06 AM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Dealer filter, I got dealer oil thats 0w 20 but Im sure there are others as good or better, and regular gas because really not vehicle thats not high compression needs more then 87
  5. May 3, 2015 at 10:23 AM
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    While it is under warranty, follow manufacturers recommendations.
    Any 0w20 will work. The filter size for the V6 is a little longer but either is fine.
    Once out of warranty you can play with the change intervals.
    I use 5w20 in the winter and 5w30 in the summer at 7500 mile intervals with a way-oversized Fram Ultra XG8A filter every 15000 miles. That is basically twice a year oil changes. The oil could go longer but the interval works for me. If I ever start using oil or seeing the oil get a lot darker from blow by then I will shorten up the filter interval, but that is a long time from now.
