Getting a slight odor of coolant
Discussion in 'Technical Chat' started by genxer36, Mar 10, 2009.
  1. Mar 10, 2009 at 6:27 PM
    genxer36
    genxer36 [OP] Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Ever now & then I'm getting a slight odor of coolant. Sometimes when I start my truck(when it is cold) & sometimes when I'm driving.
    I can't find any leaks. Nothing is dripping. The overflow was a little low, about an inch from full.
    Any ideas? I have 110,000 miles on my 05 DC.
    When is the proper time to change the water pump on the 2nd gen?
    Thanks,
    Sean
  2. Mar 10, 2009 at 6:34 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    There is a "weap hole" to let you know when the water pump has lived out its life. If you see dried coolant under the waterpump then it's time for a new one. I changed mine at 60K
  3. Mar 10, 2009 at 6:47 PM
    genxer36
    Sean
    Bethlehem,GA
    Thanks. How difficult was it to change? How much does a water pump for these trucks cost?
    I changed one on a 97 Jeep Grand cherokee. That was a bitch to change. No room to work.
  4. Mar 10, 2009 at 6:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its not too difficult, just time consueming...Here is some info:
  5. Mar 10, 2009 at 6:56 PM
    AK27
    AK27 Well-Known Member
    where bouts do you see this weap hole?
  6. Mar 10, 2009 at 7:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The water hole is on the left side of the pulley..about halfway down.
    INSPECTION​
    1. INSPECT WATER PUMP ASSEMBLY​
    (a) Visually check the water hole for coolant leakage.
    If leakage is found, replace the water pump
    assembly.
    (b) Turn the pulley and check that the water pump
    bearing moves smoothly and quietly.​
    If necessary, replace the water pump assembly.
  7. Mar 10, 2009 at 7:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Second link I gave, at the bottom.
  8. Mar 10, 2009 at 7:06 PM
    Monkeysuncle
    Kevin
    Florida
    I bought my 99 3.4 V6 at 57,000. First thing I did was to change timing belt, cam seals, and when I pulled the water pump I could see it was leaking. On a 3.4 the water pump is almost a required item (at time belt change)because it's already broken down to that point. Don't forget I was replacing cam gear seals and had to pull off the cam gears.(timeing belt also) so a h2o pump was the least of my cost or worry, just good insurance. By the way @ 57800 miles the belt was in great shape, no rot or cracks. I now have 100K and looking forward to the next 40K.
  9. Mar 10, 2009 at 7:22 PM
    Monkeysuncle
    Kevin
    Florida
    In my case I didn't even notice the leak (on a 3.4) with all the belts, fan and plastic on the front end. Once it was all removed,...crap I see my waterpump is leaking. No difference in cooling, but I "ASSUME" at factory intervals some mechanic would see it. Never assume anything. Just make a point to look at the water pump the next time the plastic is off your truck(somewhere in the 70-90 thousand mile range). That is my opinion.
  10. Mar 10, 2009 at 8:38 PM
    genxer36
    Sean
    Bethlehem,GA
    I'm passed the 70-90k range. Sitting at 110,000 miles.
  11. Mar 15, 2009 at 6:46 PM
    genxer36
    Sean
    Bethlehem,GA
    Update: Had my truck checked out. No leaks could be found. The water pump had no problems. The tech said the 2nd gen trucks have better components & last alot longer. The hoses & belt looked great.
    I took it to a new place in Atlanta. http://www.toyotechs.com/about-us/
    I had gotten some quotes if the water pump needed replacing.
    Atlanta Toyota quoted $766 :eek: WTF That is crazy.
    Athens Toyota $666 :eek: WTF That is crazy.
    Toyotech $466.
    Also I asked what they would charge to replace my shocks, if I brought in Bilstien 5100's. $350 to replace all 4. Goodyear quoted me $550.
    I will start using this place instead of the dealer for major repairs.
