Getting an OTT tune, how Spicy did you go?
Discussion in 'Performance and Tuning' started by MrMustacho, Dec 2, 2024.
  1. Dec 4, 2024 at 6:50 PM
    RKierstead8
    RKierstead8 Member
    2019 Tacoma TRD Sport
    I did the lowest one( i forget the name) and spicy. Don't really need an in between.
    You will be happy regardless.
  2. Dec 5, 2024 at 12:28 PM
    Molina67
    Molina67 Well-Known Member
    Ken
    2022 Tacoma SR5
    I chose the mild and spicy setting love it
    DrewTRD likes this.
  3. Dec 5, 2024 at 12:56 PM
    Rednecktacoma22
    Rednecktacoma22 Well-Known Member
    Logan, UT
    22 TRD OR 6MT
    Correct-amundo! I would also look into the Accumulator Delete Mod (ADM) I mentioned in my previous comment. This has also allowed the clutch engagement to be consistent (and a little smoother). I used @Firn 's disk and I believe that to be the easiest way to delete the accumulator, if you have not done so already.
    Firn likes this.
  4. Dec 5, 2024 at 9:56 PM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    Might have better way to ADM for clutch. Use a steel braided hose from Amazon.
    https://youtu.be/eWI7cQkzd4U?si=QtzP0LpXvUNRrQRZ
  5. Dec 6, 2024 at 3:37 PM
    rbdudeman
    rbdudeman Well-Known Member
    I went moderate/spicy...it's awesome. Like someone said, you can always change your mind. Crazy the difference it makes vs. stock. I was heading to selling the truck until I did some research. Anyway, whatever you choose your gonna love the result. Good Luck
  6. Dec 7, 2024 at 6:52 AM
    BillyE
    BillyE Well-Known Member
    I did mild. Even medium seemed too hot for me.
  7. Dec 7, 2024 at 7:29 AM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    6MT TRD OR here. Stock tires and everything else.
    I got the medium, as the tuner stated that most MT's go with it. He also stated that the spicy levels are really for compensating tire sizes, so larger tires = higher spicy levels. The tuner I went to allowed me to drive around the block, and change spicy levels if I didn't like, or if I made changes later on down the line (regear, larger tires sizes), for no additional cost.
    I settled with medium, because I wanted to get used to the sensitive pedal
    1st week, the pedal was super sensitive. As I kept driving, I started to either get used to it, or the sensitivity started to wear off.
    My take away is that for 50% pedal input pre-tune, it is about 15-20% pedal input post tune. MPGs took a slight hit. During my commute (18 miles, 60/40 highway/city), I lost about 0.5mpgs. On longer drives, it evens out. I haven't gained any MPGs, maybe due to my driving style.
    Power is definitely available at lower rpms. Before I was shifting at 2700 rpms, now I am shifting at 2000-2100 rpms for normal driving.
    It has only been a month since I've been OTT tuned, but I've not buyers remorse. Was gonna make a separate thread regarding my experience, but this post suffices.
    Edit: I do wonder what mild would be like, but not enough for me to schedule an adjustment. I'm happy for the changes for a stock truck.
  8. Dec 7, 2024 at 10:43 AM
    MrMustacho
    MrMustacho [OP] Well-Known Member
    I have the disk, just need to put my big boy pants down and do it. Hopefully this Xmas break.
    Thank you for the input! Really appreciate it.
  9. Dec 7, 2024 at 10:44 AM
    MrMustacho
    Thanks for the info, this is what I was looking for to hear. Really appreciate everyone's input, love my taco bros!
    Rednecktacoma22 and BlueRibbonRM like this.
  10. Dec 9, 2024 at 6:19 AM
    Rednecktacoma22
    Logan, UT
    22 TRD OR 6MT
    Lol sounds good! Good opportunity to upgrade the clutch fluid to something more cold weather friendly, if you live in that type of area. I went with the Pentosin LV.
  11. Dec 13, 2024 at 8:25 PM
    MrMustacho
    Hehe, I live in FL so no need to change the fluid. Now just to watch more YouTube vids and get down to business.
  12. Dec 15, 2024 at 1:08 PM
    MrMustacho
    Well, went with Medium to begin with and so far it's nice, gotta give it some time so I get used to it, might have to dial it down to Mild to make sure it's a happy half way since I was running Sprint Booster and I would turn it off when I would drive around the city when it rains.
    Rednecktacoma22 and roboturner like this.
  13. Dec 15, 2024 at 1:55 PM
    6spd
    san diego
    2023 4x4
    Give it some time. You'll get used to it, or the initial bite of the peal will wear off. let the tune soak in your ecu. After a month, you'll know if you need to dial it back. It's about a month for me, and I am fine with the medium spicy level for mt 6MT.
    roboturner likes this.
  14. Dec 15, 2024 at 2:00 PM
    MrMustacho
    Yep, I figured just gotta get used to it and then decide. For now I’ll enjoy the faster pedal response :burnrubber:
  15. Dec 15, 2024 at 2:17 PM
    #35
    STEELeR43
    Hawaii
    I did not know get medium spicy for 6MT. Get Spicy and Super Spicy for manual, according to my tuner.
  16. Dec 15, 2024 at 2:23 PM
    #36
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Lite, when in 4 low I don't want to go full rtrd on the trails when I need traction
    MrMustacho[OP] likes this.
  17. Dec 15, 2024 at 2:31 PM
    #37
    6spd
    san diego
    2023 4x4
    The way it was explained to me, was to associate the spicy levels to your tire size. larger tire, higher spicy level. I have stock tires, so the medium was initially jumpy, but like I had said in my earlier post, I have gotten used to it...
  18. Dec 15, 2024 at 2:41 PM
    #38
    STEELeR43
    Hawaii
    My tuner set me up with Spicy from the start on my 6MT Tacoma. I got used to it, and luv it!:D
  19. Dec 15, 2024 at 9:00 PM
    #39
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    I went back and forth between #3 and #4 due to jumpy pedal from stop light.
    Doing this did not change the jumpy pedal, so I went back to #4 Medium/Spicy ECT and taught my foot to deal with it.
    I like it just fine.
  20. Dec 15, 2024 at 9:34 PM
    #40
    6spd
    san diego
    2023 4x4
    The tuner I went through, stated that the ATs have more levels of spicyness, whereas the MTs have fewer, or coarser levels of spicyness.
