Getting bad gas mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by huntercarpenter17, Oct 26, 2021.
  1. Oct 26, 2021 at 9:19 PM
    huntercarpenter17
    huntercarpenter17 [OP] New Member
    Hunter
    2008 Tacoma TRD Sport
    Hello, I’ve got a problem that’s been going on a while, around March I was getting really good gas mileage, sitting about 189 miles just under half a tank. Then I recently got a pressure control solenoid problem that got me 160 full tank and I fixed the solenoid and still get poor mileage now. Any suggestions why?
  2. Oct 26, 2021 at 9:22 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Get some short/long fuel trims on a scanner and go for a drive
    TnShooter likes this.
  3. Oct 26, 2021 at 9:23 PM
    huntercarpenter17
    Hunter
    I’ll try that. Thank you
  4. Oct 26, 2021 at 9:35 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You really need to pencil out the mileage better too. Just going by fuel gauge needle position and miles isn't really accurate.
    Next time you gas up, fill the tank until the nozzle clicks off. Set the trip meter to zero and start driving. Next time you gas up, fill it until the nozzle clicks off and compare gallons filled to your trip meter reading. If it takes 10 gallons and your trip meter reads 160 miles, you're getting 16 mpg. Write it down.
    Repeat this for several cycles. Over a few days or weeks you'll get a clearer picture of your actual mileage. This will also give you something to compare against later if you try some things like maf cleaning, oxygen sensors, etc
    Rick's 2012 and Lil Taco Guy like this.
  5. Oct 26, 2021 at 9:42 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Anything that reads codes and displays basic obd2 data. Most parts stores will have a cheapie model around 60-80$. There are a few available for your smart phone also
    Dekoy909 likes this.
  6. Oct 26, 2021 at 9:46 PM
    Waasheem
    Waasheem
    2007 xrunner
  7. Oct 26, 2021 at 10:29 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    How far your truck drives on 1/2 or even a full tank of gas is pretty meaningless. Do the math and tell us MPG's so we have real numbers to look at.
  8. Oct 27, 2021 at 6:19 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Clean throttle body. Be safe doing that can mess up if to sloppy
    Check MAF clean it up
    How old are plugs
    JMcFly likes this.
