Getting front bumper, do I change out Bilstein 5100s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jamie4x4, Dec 15, 2020.
  1. Dec 15, 2020 at 8:20 PM
    Jamie4x4
    Jamie4x4 [OP] Well-Known Member
    Jamie
    San Diego
    ‘18 MGM OR 4wd DCLB (Stolen), in market for new DCLB
    255's, 5100s w OME, full Martin Roof Rack, Snugtop
    Getting a relentless fabrications front bumper, (weighs 115lbs) and I'm worried Im going to get a ton of sag up front on my truck. I'm currently on billstein 5100s with OME 888 coils set at 0. Should I raise clip setting to 1 to compensate? Or should I get new coils? Thanks for help.
  2. Dec 15, 2020 at 8:31 PM
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    Install the bumper and see how it looks; the 5100 are already on the truck. And if you want to raise the front, then move the clip a few notices. And if that feels like shit, upgrade the coil.
    Jamie4x4[OP] likes this.
  3. Dec 15, 2020 at 8:37 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I just did the same thing, LOL. I went with 6112's, with 650 pound springs. My front bumper added 92 pounds over the stock bumper. I have a thread running, probably a page or so down,"Bilstein 6112's." Some photos and stuff, maybe some info for Ya to think on.
    GillyLink and Jamie4x4[OP] like this.
  4. Dec 15, 2020 at 8:59 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    It is strongly advised to not run aftermarket springs on any perch other than 0 with the 5100's especially when adding additional weight, too much stress and the 5100's are just not quite beefy enough for the stress.
    I'd upgrade to 6112's or 2+" adjustable coilovers should be plenty fine then amd much happier with the ride and capacity.
    I had my 5100's with 887 springs on 2nd notch and a front bumper (100lbs) no winch or anything else and I could tell the 5100's were stressed.
    Wouldn't trust them now with the winch and even more weight. I have coil overs maxed out on the 600lb springs and 700lb springs on order.
  5. Dec 15, 2020 at 9:08 PM
    CaptainBart45
    Bart
    Work in progress...
    I would add 1/2" spaders with stud extenders instead of putting the 5100's up a notch. If Ya want to keep it on budget for awhile. You will have to dis assemble the 5100's to add the longer studs on top. I was back and forth on this for awhile. Had to get an alignment either way etc etc. Knew I was going to go with 6112's in the long run. I wanted Kings, read up on Kings and decided maybe not. Looked at the Eibach pro lift ...and that would not be a bad way to go at all for Ya. Have those Eibach's assembled on the middle notch.
