Getting frustrated. Can somebody simplify lifting my truck?
Discussion in 'Suspension' started by BarefootBandit, Sep 21, 2010.
  1. Sep 21, 2010 at 8:19 PM
    BarefootBandit
    BarefootBandit [OP] Well-Known Member
    TC UCA OME 884 5100 TSB+AAL 4.10 V6 6spd 285/75/16
    Please excuse me if anything in this post should be obvious to me.
    I have a 2006 Tacoma, and I want to lift it 3 inches. I will never go off roading with it, and I will never tow anything either. I'm going to leave the stock rims for now and get bigger tires. My truck has not had the rear leaf spring recall work done.
    What are my options? I'm trying to stay as cheap as possible. 200-300 dollars preferably.
    I know I could search around and read posts, but it's like reading another language to me. I don't understand any truck suspension specifics.
  2. Sep 21, 2010 at 8:20 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Highly recommend reading this post... lots of good info with ballpark prices to get you started in the right direction.
  3. Sep 21, 2010 at 8:21 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    3" lift for 200 bucks ? Put it on jackstands .
    J/K , what Slurp said above ^^^
  4. Sep 21, 2010 at 8:37 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You say you'll never go off-road. The purpose of lifting is to increase the *clearance* and *traction* of the truck off road, at the *expense* of on-road performance.
    I'm left thinking you want the lift for the look? You don't have to do a lift to customize your truck. There are lots of cool things you can do at stock ride height - including saving your money for some kick-ass rims that will set-apart your truck at stock ride height.
    At your price range, you're looking at a spacer lift/AAL. Lots of folks on the boards will run that down, but I won't.
    However, I will point out that ANY lift option opens the door to a host of alignment and vibration issues, and the higher the lift, the more likely the problems.
    I'm not trying to be mean, I'm trying to give you food for thought - obviously you'll do what you want no matter what I say. But answer me this: if you're having trouble simply figuring out what the lift options are, how will you fare when/if you need to run down some of those lift-related gremlins like weird driveline vibrations, premature CV failure etc...?
  5. Sep 21, 2010 at 8:38 PM
    BarefootBandit
    Ok so I'm deciding between the Toytec 3" front spacer lift or the coils.
    Would the coils be better? Whats the benefit of going with coils? Would spacers hurt the truck?
  6. Sep 21, 2010 at 8:46 PM
    OZ-T
    Peter North
    British Columbia
  7. Sep 21, 2010 at 8:59 PM
    BarefootBandit
  8. Sep 21, 2010 at 9:03 PM
    OZ-T
    Peter North
    British Columbia
    I wasn't suggesting one lift over the other . I thought the discussion of spacers in the other thread would give you some info .
  9. Sep 21, 2010 at 9:07 PM
    tacosupreme54
    tacosupreme54 Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    most of the guys on that thread with spacer problems did stupid things in their trucks. the results were not all because of the spacer, but more because of the driver, where they were driving, the capabilities of our trucks, and those type things. the coils are more for off roading. they give you more off roading capability. you said yourself that you will never go offroading. if that's the case, there is no sense in wasting all that money on a much nicer suspension that you will never need. get the spacers and add a lead and you will be fine. your ride will be more stiff, but that's about it. unless you do something stupid, you will have no trouble.
  10. Sep 21, 2010 at 9:18 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Not in this case, because of the length of the coils and the length of the spacer.
    If you add a coil that would give a 3" lift to a spacer designed to also give 3" lift, then yes, you'd be in lift hell. But in this case, it's a shorter coil (tho longer than stock, coupled with a short spacer)
  11. Sep 21, 2010 at 9:19 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    As spacer lifts go, Revtek is well regarded - it mixes a preload spacer with a top plate spacer and a diff drop so that no single component is over-stretched.
  12. Sep 21, 2010 at 9:21 PM
    BarefootBandit
    I decided on the coil + spacer lift with AAL. Thanks for the advice everybody.
