Getting Head Replaced - Any pointers?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2toys, May 22, 2009.
  1. May 22, 2009 at 11:56 AM
    2toys
    2toys [OP] Well-Known Member
    Los Angeles
    01 Red Hot Double Taco
    OK, in brief. 2.7 01 DC. Truck started getting a 300&301 misfire code. Bad compression on #1. Then it ran hot (220 iirc) for a bit. Replaced Tstat, then 2 weeks later started throwing 303 code as well. Ran terrible.
    End of story, leaky head gasket turns into cracks in head at #1 & #3, $1100 laters... turns into head replacement.
    Question, should I look for anything when I pick up truck? Anything I should check? Should be finished today sometime.
    Then longer term, should I notice any improvement in gas mileage/power? I suspect I will as the misfire(s) will be gone.
  2. May 22, 2009 at 1:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Just make sure it runs good.
  3. May 22, 2009 at 3:06 PM
    2toys
    Los Angeles
    Hear dat!!!
